Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 06-09-2020, 12:06   #1 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 13,905
Nova 3 Kirin 970 after repair imei imei went into (00000)
Hello
After succfull imei repair phone shows imei with 000000 and network lock
I follow repair guide here
https://www.dc-unlocker.com/modem-secure-flash
with same result
here is repair log
6/9/2020 2:04:45 PM
HCU Client   v1.0.0.0362
Account: abodov1
Before operation turn phone to TestPoint mode:
Turn off phone, then short TestPoint on phone pcb
and plug USB cable
Wait for device "HUAWEI USB COM 1.0" in Ports
Repair
New IMEI 1 : 352762057083759
New IMEI 2 : 352762057083767
New downgrade/customization limitations : UNLOCKED
2020-06-09 14:04:46.455 Connecting to server...
2020-06-09 14:04:46.644 Connected!
2020-06-09 14:04:47.038 Not found HUAWEI device in Test Point mode!
2020-06-09 14:04:47.158 Found fastboot device: B5M5T18B16001350
2020-06-09 14:04:47.211 Reading info...
2020-06-09 14:04:53.330 PIHeadFile.hash invalid hash!
2020-06-09 14:04:53.330 ImeiFile_I0.hash invalid hash!
2020-06-09 14:04:53.346 ImeiFile_I1.hash invalid hash!
2020-06-09 14:04:53.346 Done!
Fastboot provided info:
Model: PAR-LX1M
Firmware: PAR-LX1M 9.1.0.349(C185E4R1P3)
MEID:  00000000000000
SN: B5M5T18B16001350
PCB SN: 5T5JKT18BH010037
WIFI MAC: 902BD29B57A5
BT MAC: 902BD29B5DCF
Bootloader FB lock: unlocked
Bootloader User lock: locked
FBLOCK: 1
CPU: kirin970
Theme color: black
Device color: purple
Found signed IMEI:
IMEI1: 861197047811122
IMEI2: 861197047811122
SIM NW_LOCK status: UNLOCKED
Found NV data:
Modems: 3
IMEI1: 352762057083759
IMEI2: 352762057083767
IMEI3: 000000000000000
PESN: 00000000
Phone ID: 1E2B9706E195852
2020-06-09 14:04:54.117 Repairing...
2020-06-09 14:04:54.888 error - invalid length
Memo log saved to C:\Users\Rabieh\Desktop\HCU_362\Logs\20200609_140454_HCU_XloaderRepair_1E2B9706E195852.txt
what is your advice now anyway to restore backup
thank in advance
Old 06-09-2020, 12:27   #2 (permalink)
Member: 95960
Sonork: 100.1574721
here is log with flasher
DC Phoenix 0.0.0.132
user:xxxxx
Standard update
Not Reboot NOT cheked
Update Verlist to server on file load NOT checked
Try Rescue Recovery checked
Bypass version check NOT checked
Old slow algo checked
Device found: B5M5T18B16001350
6/9/2020 2:25:55 PM Starting to write device in FASTBOOT mode...
File to update: C:\Users\Rabieh\Desktop\modem_secure.dgtks
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
SN:B5M5T18B16001350
IMEI:352762057083759
IMEI1:352762057083767
MEID:00000000000000
Build number: :PAR-LX1M 9.1.0.349(C185E4R1P3)
Model: PAR-LX1M
Vendor/Country: hw/meafnaf
Battery state: 0
OEM lock state info:
 FB LockState: UNLOCKED
 USER LockState: LOCKED
OEM get bootinfo:
 unlocked
Device with unsupported security patch
Process identifier:25084671
Erasing ver .. .
Erasing modem_secure partition
Partition modem_secure erased
Writing modem_secure partition
MODEM_SECURE partition update ...OK
Software written
6/9/2020 2:26:03 PM Writing device finished OK
Old 06-09-2020, 14:34   #3 (permalink)
Member: 2958962
Thanks Meter: 27
same issue here...................
Old 06-09-2020, 15:43   #4 (permalink)
Member: 2023196
Thanks Meter: 1,813
After flashing that file you need to repeat repair on HCU and then reset phone. This is not a 100% working solution, your phone may be beyond repair possibility
The Following User Says Thank You to Namelocked For This Useful Post:
Old 06-09-2020, 15:44   #5 (permalink)
Member: 95960
Sonork: 100.1574721
tried that as you wrote in tutorial with no luck any chance to restore Original imei for that Phone
but what is wrong why this happened all went ok ???
Old 06-10-2020, 09:49   #6 (permalink)
Member: 2023196
Thanks Meter: 1,813
Means it can not be solved for your unit, it happens because something has been done to device- board file flashed etc, been modified.
Old 06-10-2020, 10:38   #7 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,011
And how about board firmware to repaire it
The Following User Says Thank You to rebainoor For This Useful Post:
Old 06-25-2020, 11:31   #8 (permalink)
Member: 1097964
Thanks Meter: 124
you will regret this decision
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.13628 seconds with 7 queries
