11-09-2018, 10:44 | #1 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | B310s-927_{Network Lock}_Successfully Removed ... Quote:
The Following User Says Thank You to lyes_albert For This Useful Post: |
11-09-2018, 21:27 | #3 (permalink) | |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Quote:
Pinouts and Wire soldering stuff is not that hard to achieve. Make sure you’re using an original cable to avoid, unknown device errors. Short the two points as shown in the pic below, When all that is done, plug your USB, followed by plugging the routers charger, the computer will recognize it and begins installing the necessary drivers. | |
11-09-2018, 21:45 | #4 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Flashing and downgrading steps: After the computer has finished installing the drivers, you should get a comport like: «*«HUAWEI Mobile Connect - 3G PC UI Interface*». This is the bootmode. In that case, if the firmware version is higher, you should use HIsilicon DC flasher, to write the firmware (21.300.01.00.00) both available at support area. When all that is done, download the following script which would reboot your router to download mode, Where more drivers, including the modem one, will pop up. Open Dc client, click scan, it should then read the basic info of your device. Hit network unlock. I hope I was clear, if you still have any ambiguities, don’t hesitate to ask . https://mega.nz/#!ywxlGaSQ!Ui5a2BLIK...raDETUa77PXkUY |
11-09-2018, 21:51 | #5 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Describing how the script functions: Download the file attached above, extract it. You find an app. Click and open the content. Inside, hold Shift button on your keyboard, and click the right button with your mouse, then click open a new command. Copy the command inside the text file which is: balang_usbdload -p42 usbloader-b310.bin then paste it in the Cmd window, leave it as it is, except change the port number to correspond with the port of your router on boot mode, open device manager you can see it. Best of lucks..... |
