06-10-2022, 15:55 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: italy
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | Problem after being reset p10 vtr-l09 |
06-13-2022, 07:58 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | If simple full stock ROM flash does not help, then you probably need to try board software flash and go from there, if the phone boots into the factory home screen then the phone is still possible to salvage. Board software files that we have may check here https://www.dc-unlocker.com/firmware-catalog |
06-13-2022, 18:15 | #3 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | at the moment i am with this version, i wanted to know if i should use the downgrade board? Device found: WPG7N17210004746 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :VTR-L09 9.1.0.275(C432E2R1P9) Model: VTR-L09 Vendor/Country: hw/eu Battery state: 6005mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked |
06-14-2022, 10:25 | #4 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | If the phone is still flashable via fastboot after using temp load / unlock bootloader on DC-phoenix then no, full stock ROM instead of board software via testpoint should help. |
06-14-2022, 21:09 | #5 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | I tried to do the reflash but with negative results, I always have the same problem !!!!!!!!!!! https://files.fm/u/8nm4g6nts#/view/b443sakw9 14/06/2022 21:51:03 Starting to write device in UPGRADE mode... Device found: WPG7N17210004746 Old slow algo NOT selected 14/06/2022 21:51:04 start to write update file File to update: C:\Users\PC\Desktop\VTR-L09 9.1.0.275(C432E2R1P9T8)_Firmware_EMUI9.1.0_05014JG C\Software\dload\UPDATE.APP File size: 3.952.547.900 bytes Current version(CURVER): VTR_Global-CUST 9.0.1(C999) Process identifier:46168589 Validating file... Looking for attached port... Preparing to write... Writing file 1 of 46: SHA256RSA...OK Writing file 2 of 46: CRC...OK Writing file 3 of 46: VERLIST...OK Writing file 4 of 46: CURVER...OK Writing file 5 of 46: PACKAGE_TYPE...OK Writing file 6 of 46: HISIUFS_GPT...OK Software written 14/06/2022 21:51:10 start to write update file File to update: C:\Users\PC\Desktop\VTR-L09 9.1.0.275(C432E2R1P9T8)_Firmware_EMUI9.1.0_05014JG C\Software\dload\UPDATE.APP File size: 3.952.547.900 bytes Current version(CURVER): VTR_Global-CUST 9.0.1(C999) Process identifier:46168591 Validating file... Looking for attached port... Preparing to write... Writing file 1 of 46: SHA256RSA...OK Writing file 2 of 46: CRC...OK Writing file 3 of 46: VERLIST...OK Writing file 4 of 46: CURVER...OK Writing file 5 of 46: PACKAGE_TYPE...OK Writing file 6 of 46: HISIUFS_GPT...OK Writing file 7 of 46: XLOADER...OK Writing file 8 of 46: FW_LPM3...OK Writing file 9 of 46: FASTBOOT...OK Writing file 10 of 46: VECTOR...OK Writing file 11 of 46: VBMETA...OK Writing file 12 of 46: MODEMNVM_UPDATE...OK Writing file 13 of 46: TEEOS...OK Writing file 14 of 46: TRUSTFIRMWARE...OK Writing file 15 of 46: SENSORHUB...OK Writing file 16 of 46: FW_HIFI...OK Writing file 17 of 46: DTS...OK Writing file 18 of 46: KERNEL...OK Writing file 19 of 46: RECOVERY_RAMDISK...OK Writing file 20 of 46: RECOVERY_VENDOR...OK Writing file 21 of 46: RECOVERY_VBMETA...OK Writing file 22 of 46: ENG_VENDOR...OK Writing file 23 of 46: ENG_SYSTEM...OK Writing file 24 of 46: CACHE...OK Writing file 25 of 46: SYSTEM...OK Writing file 26 of 46: CUST...OK Writing file 27 of 46: ISP_FIRMWARE...OK Writing file 28 of 46: MODEM_FW...OK Writing file 29 of 46: HISEE_IMG...OK Writing file 30 of 46: HISEE_FS...OK Writing file 31 of 46: VENDOR...OK Writing file 32 of 46: VERSION...OK Writing file 33 of 46: ODM...OK Writing file 34 of 46: PRODUCT...OK Writing file 35 of 46: PREAS...OK Writing file 36 of 46: PREAVS...OK Writing file 37 of 46: PRETS...OK Writing file 38 of 46: PRETVS...OK Writing file 39 of 46: PRELOAD...OK Writing file 40 of 46: ERECOVERY_KERNEL...OK Writing file 41 of 46: ERECOVERY_RAMDISK...OK Writing file 42 of 46: ERECOVERY_VENDOR...OK Writing file 43 of 46: ERECOVERY_VBMETA...OK Writing file 44 of 46: USERDATA...OK Writing file 45 of 46: UFSFW...OK Writing file 46 of 46: PATCH...OK Software written 14/06/2022 22:02:15 start to update cust file File to update: C:\Users\PC\Desktop\VTR-L09 9.1.0.275(C432E2R1P9T8)_Firmware_EMUI9.1.0_05014JG C\Software\dload\VTR-L09_hw_eu\update_VTR-L09_hw_eu.app File size: 1.151.473.696 bytes Current version(CURVER): VTR_Global-CUST 9.0.1(C999) Process identifier:46168686 Validating file... Looking for attached port... Preparing to write... Writing file 1 of 8: SHA256RSA...OK Writing file 2 of 8: CRC...OK Writing file 3 of 8: VERLIST...OK Writing file 4 of 8: CURVER...OK Writing file 5 of 8: PACKAGE_TYPE...OK Writing file 6 of 8: VERSION...OK Writing file 7 of 8: PRELOAD...OK Writing file 8 of 8: USERDATA...OK Software written 14/06/2022 22:05:12 Writing device finished OK |
06-16-2022, 17:44 | #9 (permalink) | ||
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | then I flashed the board firmware, and everything went fine, immediately after I flash the normal rom but I still have the same problem I have not solved anything !!!!!!!!!!!!! Quote:
06-17-2022, 07:54 | #10 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | If you flash board software and the phone boots up into the factory home screen with several apps on the screen then all is good, and you only flash incorrect stock rom. After you find the correct one it will be normal. If the phone does not boot up into factory homes creen after board software flash then need to change the main board on mobile. |
