LCD Refurbish All things related to LCD / Screen refurbish and repair |
03-10-2019, 14:16 | #241 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | but after that , it show some bubble. then i put it agin at bubble remover , it gone, but it keep coming back after hour. same position. |
The Following User Says Thank You to CellM@n For This Useful Post: |
04-22-2019, 17:24 | #243 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Quote:
Most probably a dust/sand grain left between the glass and the LCD. Also what Qmad3 wrote: NEVER use an oil based liquid to clean; `better an alcohol based liquid. Regards, X4ce | |
The Following User Says Thank You to excessive For This Useful Post: |
08-25-2019, 12:54 | #245 (permalink) |
Insane Poster Join Date: Apr 2009 Location: Delhi Age: 41
Member: 1006358 Status: Offline Sonork: 100.1583633 Thanks Meter: 74 | Dear I try below method and for me its 100% working 1. Oca size bigger then lcd size 0.50 mm all 4 side 2. Pasting machine vacumm at least -98.5 Vacumm time 6 sec , pasting time 8 sec 3. Deformer ( de-bubbler ) temp 40c , pressure 5, time 10 miniutes. Note. Oca take out of only 30 miniutes before use. Oca store temp 4c Pasting machine whether its plate or ballon must be good aline LCD side of lcm during pasting must be at balloon or plate side At a time of pasting tp must be do not touch any corner and centre of lcd Try and replay if it's also work for you May be help other tooo |
08-25-2019, 13:12 | #246 (permalink) | |
Member: 1006358 Status: Offline Sonork: 100.1583633 Thanks Meter: 74 | Quote:
02-28-2021, 00:18 | #248 (permalink) |
Junior Member Join Date: Apr 2008
Member: 760856 Status: Offline Thanks Meter: 0 | I am using a AK pro machine, the screen apear waves when finish. 1. apply oca to glass and do laminate and bubble remove together as the machine doing this way, no bubbles 2. place the oca done glass on lcd and do laminate and bubble remove, no bubbles. but see lcd waves if someone help me, much appreciated |
01-29-2022, 01:57 | #249 (permalink) |
Junior Member Join Date: Feb 2001 Location: Hamburg Age: 57
Member: 3263 Status: Offline Thanks Meter: 0 | Hello, I have since some month problems with the iPhone OCA Touchscreens an Glasses, after vacuuming bubbles appear again.... of 10 displays appear at 5 and more again the bubbles at the Glass. These always disappear when you vacuum them again, but after a few minutes / hours they come back. I have tested all possible settings... used all possible qualities of OCA... really tested a lot. Can anyone help me? |
06-12-2022, 07:48 | #250 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | infinix Note 7 (X690) Broken Touch Glass Replacement (Only Touch Glass Not Panel) infinix Note 7 (X690) Broken Touch Glass Replacement (Only Touch Glass Not Panel) |
06-13-2022, 16:11 | #251 (permalink) | |
Freak Poster Join Date: Jun 2011 Location: Dominican Republic
Member: 1607116 Status: Offline Sonork: 100.1617729 Thanks Meter: 52 | Quote:
you can create Telegram gorup is better !!! | |
