Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 10-08-2020, 15:26   #31 (permalink)
Member: 383320
Thank you Thank you Thank you
Thank you
Old 05-04-2021, 01:56   #32 (permalink)
Member: 2127933
hi sir i am from morocco ineed oca pol laminating
can you give me price pls and what can i do to get one
Old 05-20-2021, 09:15   #33 (permalink)
Member: 2988637
wow....Thank you my Friend . . .
Old 12-02-2021, 11:24   #34 (permalink)
Member: 2403204
Hi guys, hope this message is clear and i can get a proper reply on it.
So, basically i have always been having an issue with iPhone lcds like first the touch works good, after cutting also it works good and after lamination also it works well. Specially on 7/8 and plus series.
However, once the laminated screen is kept as ready on a side, They stop working after few weeks or days. Can someone guide me what could be the reason.
Old 09-08-2022, 08:49   #35 (permalink)
Member: 3009116
Thanks Meter: 4
In-cell technology:The method of em******* touch panel functions into liquid crystal layer, that is, em******* touch sensor functions inside the display screen. The innovation of the In-cell touch panel is that the circuit is loaded on the liquid crystal, so that the liquid crystal screen has the perception and touch screen input capabilities of the traditional touch screen. The In-cell touchpad is not only more accurate, but also eliminates the need for a touchpad, making the entire touchscreen thinner and lighter. Traditional touchscreens are difficult to see clearly in sunlight, but now that there is no touchpad, naturally Without parallax, readability is also improved.
On-cell technology: Refers to the solution of em******* the touch screen between the color filter substrate and the polarizer of the display screen, that is, the touch sensor is equipped on the liquid crystal panel. The technical difficulty is simpler than that of Incell. In terms of products, the technology has not yet overcome the problems of thinning and uneven color during touch.
Out-cell technology:Integrate the touch layer and the protective layer glass lens together.
Old 08-03-2023, 08:09   #36 (permalink)
Crazy Poster
Member: 1544686
Thanks Meter: 16
if you a rich technician you buy the tool.
Old 11-06-2023, 12:21   #37 (permalink)
Member: 3030130
Hey friends, I am from Bulgaria and here no one offers this kind of equipment, so I'll have to order from China anyway. But I want to ask you for your opinion, which machine is good, I see there is a machine M20+ which has a good price, but I can't find reviews at all, do you think it is good, also are these 3 in 1 types, for example the Mechanic iMark6 with the build in vacuum pump and air compressor, are they good enough and able to do the job? Or I need to spend more on separate laminating and bubble removing machines.. Any opinion will be very helpful to me, thank you in advance
Old 11-20-2023, 22:41   #38 (permalink)
Bigbrothers2000's Avatar
Member: 487
Thanks Meter: 65
Thank you sir or madam
Page generated in 0.14968 seconds with 9 queries
