LG K10 2017 screen glass replacement only / lcd refurbish video guide To complete the glass only replacement in LG K10 2017 FOLLOW THE STEPS FROM THE GUIDE: |
My screen is cracked and touch does not work. If I replace the screen will it work? |
No, if touch doesn't work then you have to replace whole assembly. Digitizer is part of the display in K10 2017. |
My touch work but screen is completely shattered, so I can follow the tutorials, yes? |
If by screen you mean just the glass and you're able to see everything just fine on the screen then yes, you can. Keep in mind that you need laminator and autoclave to properly do this with OCA. |
The touch must work properly to perform such a repair. |
Yes, the touch works properly, I will try to do it along with the tutorial, I hope I will be able to do it, thanks! |
