Liquide nitrogen glass separation / glass only replacement for SONY XPERIA models This tutorial will show you how to replace the glass in Xperia Z2 using nitorgen machine: |
Interesting... no damage at all to liquid crystal / omoled cells or electronics? |
No damage at all. Everything works as new again. |
Any additional tools for this machine? |
No need to use additional tools the machine itself do the all work. |
Are you working with this machine ? Can it help to remove complete folder from set with broken touch ? |
Yes, if you get handy with it you can separate anything you like. Take time and learn. |
I'm beginner which one will be better for me (freezing or heating machine)? |
This machine makes my job much easier, good job you share your experience with us. |
Will it work with HUAWEI phones properly? I've started to repair a lot of them and I'm planning to invest in such a machine. |
Is it possible to use a freeze spray such as MAX Professional 7777 **** Off Freeze Spray Electronic Component Cooler an alternative to liquid nitrogen? |
It will be not efficient, the glass should be frozen at the same temperature at the whole screen |
