LCD Refurbish All things related to LCD / Screen refurbish and repair |
11-17-2017, 18:01 | #1 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2382021 Status: Offline Thanks Meter: 0 | replacement glass Samsung S8 G950 I have a problem taping the back of the display After striping, the stripes (vertical lines) remain as shown During disassembly I use isopropanol Is this a mistake? Are there molds for the press without taping the tape from the display? |
11-20-2017, 09:43 | #2 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | i have also same problem after removing S7 edge from middle frame... now touch not responding... same happened with 2 sets...all care taken while unframe wbr... |
The Following User Says Thank You to ..:MumbaiGsm:.. For This Useful Post: |
11-20-2017, 10:28 | #3 (permalink) |
Member: 2382021 Status: Offline Thanks Meter: 0 | I had a problem with the first piece in the s7 edge. I left for the night with the window open and the chemistry evaporated. The temperature was about 5-7 degrees celcius. He started to touch what method do you use? Will you put a patch OCA on the display or on the glass? Last edited by piitel; 11-20-2017 at 10:33. |
