Are your customers satisfied after "glass only" refurbish method? Share your experiences and opinion about the results of refurbished lcd-touch set. it worth the time to spend for refurbishing? Touch response has acceptable result? How many of them returned because of defective reason after X-time? |
My customers have been very happy(not had any back) with the glass repair, only takes me 20 min to do so its a quick repair and very good profit. Could i ask if you have had issues with this type of repair? WBR |
Results are 80% compared with original displays and this is unacceptable for me, especially for phones like galaxy S4 and Note 2 . In service test menu, sensitivity and stability is poor and many times you have to touch twice. |
I haven't had any of those issues. Been perfect for me. Must remind customer if they want perfect job then pay for full screen replacement. Want to pay for cheaper job then is going to be a cheaper finish? WBR |
Yap, no complain. Pay more to get more! Sent from my GT-I9505 using Tapatalk |
Have been using loca glue and yes the repair is a lot cheaper and with the use of loca glue gives a better finish. It's all about learning the right techniques. Other people use tape only around the edges and it looks bad and the touch sensibility is affected. |
dear MFC which tool do you use to replace the glass lens in 20 min? can you share your experience? |
I used finest quality. |
Model: YOUYUE 948, i don't think it is better than any other but practice makes perfect and i had a lot of damaged screens to test on before hand. Get correct temp and time, also for Samsung's i don't use wire to separate. I use two iSesamo opening tools. Actually takes me under 5min to separate, most of my 20min is taken by cleaning (Perfectionist :D). WBR |
For me I am using air gun only to remove the glass |
Very risky with hot air gun and not as good a job. WBR |
i use IRDA rework bootom heat , plus holder plate, result almost as good as the lcd/screen separator machine |
Bro. .... up lode video please. ....... |
for me i changed it perfactly with hot air gun in 20min but some time it not perfactly working but its better from ic inbuilt wired touch because it take more time and less result for me however i remove it in less time and change d quickly but most time it not working perfactly. glass result is 80% positive and wired touch result 50% positive for me |
