oppo f5 cph1723 imei null unknown baseband solution oppo f5 cph1723 imei null unknown baseband solution needed, nv file & sec file writeng not supported mrt,nck, infinity cm2.etc device anyone have tested solution please share |
Fixed 100% I fixed 15 kits after 4 days work |
taseer really are you do it ,i want solution this problem i do not understand what can i do ? give me the right way thanks in advnce |
open miracle salect imei option <on> set on conect with pc and inter code *#800# salect atci enable atci once slide to select usb acm close port click use open gs0 port write imei |
Please Turn on your phone by battery before pressing START Waiting for USB Port... Set MediaTek USB VCOM (Android) (COM11) >>please turn off the phone, and hit the little window |
You Cant Do It If You Are New Security... |
f5 cph1723 new security imei repair 100% possible with DB,AP file |
pls brief little more and can i have link to file pls |
f5 1723 data mismatch during flashing and dead only mtk com port show plz solution |
Where can found these file security 2018 |
Try This Method Hope it will work for you 100% Tested New - Oppo Unknown Baseband IMEI Null Repair Full Solution Oppo Offline Flashing Without Credit |
oppo F5 cph1723 after flash baseband unknown i have tested solution |
i repair my null imer and baseband from market now it recover imei and baseband but when i insert sim in phone. then all thing ok mobile data ok incoming calls ans messages ok but when i dial any numer its error . plz have you any solution for this problem. thanks in advance |
brother updating system will solve your issue |
