Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > HDBox
Old 12-03-2018, 17:20   #1 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Question A1534 EMC 2746 NOT connecting SPi
hello
mac A1534 was remotely erased before.
disassembled and followed this video from HDB section
so mobo completely removed from mac, only flex attched is for usb port.
tried with RED connector on both positions, but wont connect.
also mobo gets very hot.
using Genuine A1718 61W USB-C Power Adapter. although is for PRO, it has 3 different types of power on it
also tried with mobo mounted on mac,but same result : WONT detect SPi.
pls help
thanks
Old 12-03-2018, 17:39   #2 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Question
and sometimes it seems is connected but not identified...
anyway is not stable so next DETECT SPI will show NOT detected
Old 12-04-2018, 13:57   #3 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
any supported around ? or admin ? any ideea ?
thanks
Old 12-04-2018, 14:45   #4 (permalink)
HDB
Member: 1300847
Thanks Meter: 547
thanks
Hello,
First of all, give us the board number, to see if you have the board view for it ( it is a number something like 800-12345 )
Second, this step should be after you have confirmation only, if you completly removed the board , do no power it externally.Instead use our HDBOX + Flex + Right Adaptor + Right Position only.
- If Our HDBOX if not detecting power, it will provide power the chip, so external power no required and if you have it connected backwards...it might damage the board, or the HDBOX itself.
Please note: We do not know what will happen with your mobo when you power it up, and all the other components are not connected, it might damage your power supply on the board, so that might be a reason why it is getting hot, we do not encourage people to remove the mobo from computer.
Third, with computer put together, connect usb c charger or internal battery.
and using only Adaptor + Flex + SPI adaptor see in which position the RED light on SPI adaptor turns on. That way you can detected where the power line in that debug port.
Only after this step, where you got right position, right adaptor, then you could try the step 2, if you cannot read/write the chip in any of the states mentioned.
Thanks & Best Regards!
HDB Team
Old 12-04-2018, 16:06   #5 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Arrow
here you go :
820-00045-11
Old 12-05-2018, 13:06   #6 (permalink)
HDB
Member: 1300847
Thanks Meter: 547
here you go :
820-00045-11
Dear Sir,
We need the info on the backside of the outer casing of the computer. Not the NO on the PCB board. Please resend us the info.
HDB Team
Old 12-05-2018, 13:27   #7 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Arrow 820
hello
this will help ?
-Photo Link Removed BY HDB- We removed the Link to the picture with your SN number, please keep that one private next time. Sent it via email/private Email in the future.
thanks
Old 12-06-2018, 13:14   #8 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
hello
some news on this situation ?
thanks
Old 12-06-2018, 18:23   #9 (permalink)
HDB
Member: 1300847
Thanks Meter: 547
Hello,
Thank you for the informations, and now we have all the information we needed for your macbook 12" (Model Board, EMC, Computer SN).
The issue with this specific board is that the board is having 2 spi chips on it ( one 3.3v and one 1.8v), and both are accessible via debug port. We are still verifying more things before we can give you a clear course of action with this mac.
Best regards
HDBOX Support Team.
Old 12-16-2018, 15:18   #10 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Hello
Any news on this mac ?
Thanks
Old 12-16-2018, 15:50   #11 (permalink)
HDB
Member: 1300847
Thanks Meter: 547
Hello
Thanks
Tomorrow ,will update to you.
HDB Team
Old 12-17-2018, 21:55   #12 (permalink)
HDB
Member: 1300847
Thanks Meter: 547
Hello, we worked till we find an mac A1534 with firmware password and we removed the firmware passowrd to check everything. After talking with the engineer in charge of this mac (A1534) he suggest you could try like this:
0-Put it together, and using smart search from our software to confirm position and connector (Make sure no FLEX is damaged, nothing is broken, etc)
1-He DID NOT removed anything from the board, he just lifted 1-2cm enough to connect the connector ( the battery is still connected, but without USB C charger )
2-Then he pressed power to power on, and when apple logo appreared, he pressed power again, until computer went to sleep,
3- KEEP HOLDING power button at all times, he started pressing read ID, 4 times read bad IDs, 5th was good ID, then he was able to read it, remove firmware password, and write back... AND HE WAS STILL HOLDING THE POWER BUTTON.
4- WHen he was done removed everything, put the board back in, and the computer started without firmware password.
5- He passed me the file, and i will prepare it for your computer so you could write this file if the content of your chip is corrupted ( I will send you the file via PM )
6- KEEP PRESSING POWER BUTTON until you are completly done, otherwise start from point1.
IF your computer is not starting, simply connect everything, lift the board a little, connect connector, press and hold power.... after 20 secs, press read ID (still hold the power) .... click it a couple of timers with a 1-3 seconds between them, after you get ID, click read, unlock, etc, and HOLD the power pressed at all times, only remove when you are ready.
Best regards
HDBOX Support Team.
Old 09-29-2019, 03:17   #13 (permalink)
Member: 2557371
excelente
Best regards
HDBOX Support Team.
Batalle mucho con esta. Pero el secreto esta en mantener presionado el boton de POWER.. Y hacer todo con la HD BOX y en segundos queda listo
Old 01-15-2020, 21:56   #14 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Question
Best regards
HDBOX Support Team.
hi. have same laptop now. tried to push power button but nothing is happening. power button is NOT ACTIVE while laptop is opened.
checked flex,etc.. and as back cove is mounted, power button is good and working.
whats wrong here ?
pls help
thanks
Old 01-15-2020, 22:08   #15 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
somehow managed to connect it and READ, but another error now :
[23:05:59] -> Detect SPI starting ...
[23:06:00] -> CHIP ID: 00 EF 40 17 (W25Q64FV - 8 MB)
[23:06:00] -> Detect SPI finish.
[23:06:04] -> Reading SPI starting ...
[23:06:04] -> CHIP ID: 00 EF 40 17 (W25Q64FV - 8 MB)
[23:06:42] -> Reading data done. Stats:
[23:06:42] -> Data: 8388608 bytes
[23:06:42] -> Time: 37.91 s, avg speed: 221.29 KB/s
[23:06:42] -> Verifying data starting ...
[23:06:44] -> Max Read Retrys(10) Used @ 00000000
[23:06:44] -> Reading SPI done
at this point i cannot save file, and no other ation can be done.
pls help
thanks
Page generated in 0.26546 seconds with 8 queries
