03-26-2019, 18:07 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: portugal Age: 32
Member: 595808 Status: Offline Thanks Meter: 7 | imac bios backup needed i ve made backup from old efi but backup corrupt , when i reflash efi in imac it wont power help will be very apreciated i will upload the backup that if has in case of anyone can repair it thanks in advance i can pay smal amount for it https://ufile.io/uxb65 |
03-28-2019, 23:13 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello First lets us try the easy way in fixing it. After flashing your backup file, try to perform and NVRAM/PRAM Reset, also SMC resets ( in some cases SMC reset did do the trick ). Full details on resets: https://www.macworld.com/article/288...m-and-smc.html Now, if that does not work, and your computer still wont start, Lets continue with advanced way ... I have downloaded your file, and i see it is a bin file, and not our product HDBOX compressed format '.hdb' . We use this format ( the '.hdb' ) , because we save about 40-50% space by using our format , and full computer info is stored at the begging of the file, allowing our users to search by those infos. I was able to retrive your computer SN, and Model number from your file, and I will try to find a donor file to match it as best as possible, then change that file to match your computer info. After that I will give it to you as .hdb file and you have to use your HDBOX to flash it. Best regards, HDBOX Support Team. |
04-15-2019, 17:48 | #6 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, Toke a while to find the donor file, but we finally did, changed the SN to your SN and upload it. I have PM-ed you the download link. As usual, after flash, do a verify to confirm write was 100% correct. After flash, on first boot do the NVRAM / PRAM reset, and computer should be up and running 100%. Best Regards, HDBOX Support Team. |
04-20-2019, 14:35 | #8 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | If you already have HDBox,then there should be any problem with the format.If you do not have HDBox yet,then you can purchase one set. Thanks & Best Regards! HDB Team |
