11-27-2018, 23:22 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | Found chip for clamp on the other side of motherboard. But box cannot read chip: Quote:
11-28-2018, 03:03 | #3 (permalink) | |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Quote:
1, Please upgrade the management software to the last version. For your model,there are the guide for which connector.https://hdb-team.com/support/# 2,The most important part is to connect to the computer chip and get the control for it also. Check the troubleshooting on this page. And please try al those combinations until you get the connection and control to this chip. https://hdb-team.com/remove-icloud-4...d-isp-adapter/ Thanks & Best Regards! HDB Team | |
11-28-2018, 13:43 | #5 (permalink) | |
Member: 1300847 Status: Offline Thanks Meter: 547 | Quote: Your connection between ISP adaptor and motherboard is right. But the ISP adaptor need work together with HDBox. You need plug this ISP adaptor into HDBox. And then operate as the guide in the official website guide. Thanks & Best Regards! HDB Team | |
11-29-2018, 04:07 | #7 (permalink) | |
When you operate,have you tried all 8 power states carefully? As the troubleshooting https://hdb-team.com/remove-icloud-4...d-isp-adapter/ 2# & 3# ? | |
11-29-2018, 09:52 | #8 (permalink) | |
Member: 329458 Status: Offline Thanks Meter: 153 | Quote:
No, i have not tried all 8 power state, because this mac does not recognize battery. The problem of this mac is the filevault password active on hdd. There is a possibility that i can found it in BIOS? Or this type of password was stored in another place? | |
11-29-2018, 13:44 | #9 (permalink) | |
Could you read the bios and send the file? We will check that for you. Thanks & Best Regards! HDB Team | |
11-29-2018, 14:31 | #11 (permalink) | |
You could send the file to "[email protected]" .Thanks Best Regards! HDB Team | |
11-29-2018, 18:26 | #12 (permalink) |
Member: 329458 Status: Offline Thanks Meter: 153 | I have an update: withouth battery, when i attach charger macbook start automatically. In which mode i can put it in sleep mode and try to read bios with adapter? |
12-04-2018, 15:23 | #15 (permalink) | |
After some checking looks like filefault cannot be recovered, and to get rid of it you can use our tool to remove firmware password / icloud lock if present, and then : Erase via Recovery. Hold down Command-R at startup (Option by itself won’t work on a FileVault-protected Mac), and then erase the FileVault partition using Disk Utility, and then reinstall macOS. This may not always work, in which case you have two other options. Erase via another startup drive. FileVault protects the startup drive from access, but you can hold down Option at startup and select other attached drives’ volumes that have valid macOS (or OS X) startup partitions. Boot from one of those, and you simply wipe the FileVault drive. You’ll need to reinstall macOS entirely on that drive to wipe out the Recovery Disk settings. Use Internet Recovery. At startup, hold down Command-Option-R, and you can select Reinstall macOS. This retrieves macOS over the Internet, which can take a while if you have a slow connection. Thanks & Best Regards! HDB Team | |
