Kick out of disabled state iPhone 4 iOS 7.1.2 I have one iPhone 4 with iOS 7.1.2 locked on disabled state (connect to iTunes). In which way i can unlock it? I have tried with light sensor, but when BF starts, phone came on emergency call screen and BF fails. |
Well, when you brute force iphone4, start with the screen off, and phone should remain in disabled screen. If move to emergency is not good as the code is not tested there. You can check if its working or not, by monitoring if phone vibrates after one code or not. But in order for the phone to vibrate make sure the mute switch is not activated. if the mute is activated the phone wont vibrate. If the issue is not resolved, you can post a video and pm us the link then the video could give us much more information and allow us to assist you even better. Best regards, HDBox support team. |
This is situation of iPhone 4 http://immagini.italyteamforum.net/t...2017090910.jpg In which way i have to continue? |
Sir, do you have a procedure for me? |
Hello, How did you try to enter the codes? From HDBOX manager, or from box itself ? We need to narrow down the issue, because 7.1.2 is full supported. The normal procedure will be:
http://i63.tinypic.com/2d9ye0w.jpg Red zones = Stay away from it Green Zone = Best , as on unlock there the iphone will show its menu bar, and 100% it wont be black after unlock Blue Zone = Decent, but risky if after unlock iphone got a black icon, or black picture in the spot where you placed sensor, it might not detect the unlock. |
I have sent in pm video of operation |
This is situation http://immagini.italyteamforum.net/t...2017091316.jpg Pin found but phone still disabled |
Update situation: Solved "disabled" problem. Now iPhone show passcode field, and it is an alphanumeric code. Any idea to solve it? iPhone was jailbroken and i have SSH access on it |
i can't get it started for bruteforce..it just stops after few seconds,,and give ma always wrong coddes |
I have solved with other method... What phone do you have? |
