03-02-2021, 11:38 | #1 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2873904 Status: Offline Thanks Meter: 0 | MacBook A1466 locked EFI i have a macbook air 1466 2012, i have the connector moved to wifi module is not centred to motherboard, i try all 3 connector but is not working, any idea? |
03-03-2021, 12:42 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Our 2 big lovely helper already give you the right suggestion 1, Show us how you connect and how did you operate. 2, Give us the screenshot how the management showed. Thanks |
03-14-2021, 13:07 | #7 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello strato55, Looking at the picture of the board you provided, i think the right connector is number 2, the blue one. Now, using only the connector 2 + flex + spi adapter ( Not connected to HDBOX yet), connect it your mac while mac is sleeping / off ( NO fan spinning) then see if the red light on the SPI adapter comes on. If it does not comes one, rotate it 180 and try again. Now it should light up. Now you know the position and connector required to connect it. After this, connect SPI adapter to HDBOX, and from HDBOX manager, 1) detect SPI - Confirm it is a good ID, 2) Read SPI Chip, 3) (optional) Save a back file, 4) Do all the unlocks you need, 5) Click Write SPI Chip, All should be done now. After this remove SPI Chip, and also is recommended to an NVRAM reset ( Command-Option-P-R ) Best Regards, HDBOX Support Team |
03-14-2021, 13:09 | #8 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | That picture is from one of our testing A1466 macs, and is for reference. To be 100% i will need you to find the board number of the logic board, write it here, and if I can find a schematic for that board, i can confirm you the connector and direction. |
