09-07-2017, 08:57 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | Kick out of disabled state iPhone 4 iOS 7.1.2 In which way i can unlock it? I have tried with light sensor, but when BF starts, phone came on emergency call screen and BF fails. |
09-08-2017, 09:18 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Well, when you brute force iphone4, start with the screen off, and phone should remain in disabled screen. If move to emergency is not good as the code is not tested there. You can check if its working or not, by monitoring if phone vibrates after one code or not. But in order for the phone to vibrate make sure the mute switch is not activated. if the mute is activated the phone wont vibrate. If the issue is not resolved, you can post a video and pm us the link then the video could give us much more information and allow us to assist you even better. Best regards, HDBox support team. |
09-12-2017, 11:38 | #5 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, How did you try to enter the codes? From HDBOX manager, or from box itself ? We need to narrow down the issue, because 7.1.2 is full supported. The normal procedure will be:
Red zones = Stay away from it Green Zone = Best , as on unlock there the iphone will show its menu bar, and 100% it wont be black after unlock Blue Zone = Decent, but risky if after unlock iphone got a black icon, or black picture in the spot where you placed sensor, it might not detect the unlock. |
09-13-2017, 21:40 | #9 (permalink) |
Member: 329458 Status: Offline Thanks Meter: 153 | Update situation: Solved "disabled" problem. Now iPhone show passcode field, and it is an alphanumeric code. Any idea to solve it? iPhone was jailbroken and i have SSH access on it |
09-16-2017, 10:11 | #10 (permalink) | |
Freak Poster Join Date: May 2014 Location: baia mare romania Age: 40
Member: 2195859 Status: Offline Thanks Meter: 19 | Quote:
i can't get it started for bruteforce..it just stops after few seconds,,and give ma always wrong coddes | |
