02-26-2024, 20:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 451 | iPhone 6S Plus icloud bypass no signal Done I have disabled drivers (have restarted windows pressing shift etc) but software stop at Checking PWNDFU , in that moment manualy put the phone in DFU and software continue the job normaly. Test Signed Drivers is....ON Preparing.....OK Fix Drivers.........OK Check BOOT.....NO Checking iDevices.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated BuildVersion: 19H380 CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-7459.140.15 Device IMEI: 35333607791xxxx Device MEID: 3533360779xxxx Product Name: iPhone OS Product Type: iPhone 6s Plus IOS Version: 15.8.1 SIM Status: kCTSIMSupportSIMStatusReady Device Serial Number: C39RLNU9GRX5 DeviceID: 9a3bbc465c8eecfb13e73e9b72613a61fd23b897 MEID Status: Supported Preparing Hello....OK Generating Activation Files....OK Preparing.....OK Fix Drivers.........OK Reading iDevice info.....OK Device NAME: iPhone 6s Plus Product NAME: iPhone8,2 Device MODEL: n66map Device ECID: 0x1e3846040b8226 Device CPID: 8003 Device SRTG: IBOOT-2234.0.0.2.22 Device MODE: DFU Device CPU: A9 Waiting for server.....OK Checking PWNDFU.....NO iDevices PWNDFU :..... Checking Drivers .....Ok Device CPU: A09 Preparing.....OK Fix Drivers.........OK PWNDFU IS.....Ok Preparing.....OK Fix Drivers.........OK Exploiting Device [1].... Sending File (iBSS.img4).....OK Sending File (iBEC.img4).....OK Sending File (devicetree).....OK Sending File (ramdisk).....OK Sending File (trustcache).....OK Sending File (kernel).....OK Successfully! Checking iDevices.....OK Checking SSH......P:16..OK Waiting for server.....OK Mounting IPhone/Ipad partition (Hello/Passcode).......OK BuildID:9F36F13A-9BEA-11EE-A586-E7AE515F6752 ProductBuildVersion:19H380 ProductCopyright:1983-2023 Apple Inc. ProductName:iPhone OS ProductVersion:15.8.1 SystemImageID:4DF3749A-8A14-4301-98E5-D07ACF018E31 Checking iDevices.....OK Preparing paths.....OK Checking SSH......P:16..OK Path:Backups/9a3bbc465c8eecfb13e73e9b72613a61fd23b897 Wildcard File:Not Found Activation Files (Hello Screen).......OK Skip Setup...OK Disable Reset Settings and Updates....OK Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: CAF2D46AB38CA953 Elapsed time 08:03 -- Version 4.6.8 Build 002 |
The Following User Says Thank You to ct3im For This Useful Post: |
