Cannot Root A505FN Android 9 and 10, LDU ( SOLVED ) Problem is that with Anroid 9 i've gained for very little time the ROOT, for this i've done "DEMO ADB Procedure" w/o problem and Patched with Chimera later. Since i was losting the ROOT each 10 mins, have Upgrated to Android 10, but haven't gain the root only one time with this FW: A505FNXXU4BTC9 and his root file. with Android 9: Code: Connecting to device.....OK I need of Remove LDU from *#0011# otherwise never i can have Signal, how can do since have tryed all? https://i.imgur.com/zCOCNlQ.jpg Br allumts |
Already A505F is rooted so many times , Provide log for creating and flashing root file android 10 ! Notice , You MUST create root file with EFT Pro from same firmware on device , dont use files from eftsu for now ! |
I've rotted many device in one click with file of EFTSU and LDU Patched Perfect. Ok i've seen thet EFTSU have some issue, (sure you are working in it), so i want create, how you suggest, Root file from same Firmware have in device and let know you. Br allumts :) |
All Solved, Thanks to EFT :) Finally Rotted by Boot Method of BEST EFT Quote:
LDU REMOVED By EFT Imei Repaired and patched by chimera thx to ROOT of EFT Br allumts |
Glad you made it , you are most welcome ! |
