Old 10-12-2020, 15:51   #1 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,710
Cannot Root A505FN Android 9 and 10, LDU ( SOLVED )
Problem is that with Anroid 9 i've gained for very little time the ROOT, for this i've done "DEMO ADB Procedure" w/o problem and Patched with Chimera later.
Since i was losting the ROOT each 10 mins, have Upgrated to Android 10, but haven't gain the root only one time with this FW: A505FNXXU4BTC9 and his root file.
with Android 9:
Connecting to device.....OK
Reading device info.....OK
Baseband Version: A505FXXS3A***,A505FXXS3A***
Serial Number: R58M34QGRBE
Device Arch: exynos9610
Device bootloader: A505FNXXS3A***
Device selinux: enforcing
Device warranty bit: 1
Device Firmware: A505FNXXS3A***
Android version: 9
Device SDK: 28
Device data encryption: encrypted
Firmware Country: ITALY
Device Hardware: exynos9610
Device CPU: arm64-v8a
Device Factory: samsung
Device Model: SM-A505F
Device IMEI: 352698116117883
Root status.....Rooted { 3.19:EFTSU }
Operation {Read Info} ID: 41E90E5217A74C1D
Elapsed time 00:00 -- Version 3.4.5
Android version: 9
Device SDK: 28
Patching LDU security.....OK
Operation {Fix Demo devices Network} ID: 8BADF14D63714ED1
Elapsed time 00:01 -- Version 3.4.5
With Android 10 No one time i've gain the Root and now "EFTSU" sayng "Internet issue try again later"
I need of Remove LDU from *#0011# otherwise never i can have Signal, how can do since have tryed all?
allumts
Old 10-12-2020, 21:19   #2 (permalink)
Thanks Meter: 15,377
Already A505F is rooted so many times , Provide log for creating and flashing root file android 10 !
Notice , You MUST create root file with EFT Pro from same firmware on device , dont use files from eftsu for now !
The Following User Says Thank You to easy-team For This Useful Post:
Old 10-13-2020, 08:35   #3 (permalink)
allumts's Avatar
Member: 1564612
Yes, i've tryed to root with Magisk and later Finally EFT have repaired in one click LDU Flag1, but very strange, after repaired lost Root, (TWRP gived one error in one file), and IMEIS turn back to : 0000000000.
I've rotted many device in one click with file of EFTSU and LDU Patched Perfect.
Ok i've seen thet EFTSU have some issue, (sure you are working in it), so i want create, how you suggest, Root file from same Firmware have in device and let know you.
allumts
Old 10-13-2020, 12:30   #4 (permalink)
allumts's Avatar
Member: 1564612
Wink All Solved, Thanks to EFT :)
Finally Rotted by Boot Method of BEST EFT
Analyzing file [C:/Users/Max/Desktop/SM-A505FN_1_20200407200615_qy13kk1ugj_fac/AP_A505FNXXU4BTC9_CL18098116_QB30088087_REV00_user _low_ship_meta_OS10.tar.md5].....OK
Extracting files.....OK
Decompressing LZ4.....OK
Checking output file.....OK
File to process [C:/Users/Max/Desktop/recovery.img]
Unpacking image.....OK
Checking ramdisk status.....OK
Patching ramdisk.....OK
Patching dm-verity flags.....OK
Patching protections.....OK
Applying patches.....OK
Repacking image.....OK
Repacking second image.....OK
Rooted image saved to [C:/Users/Max/Desktop/SM-A505FN_1_20200407200615_qy13kk1ugj_fac/RootedBoot.oEFT]
Analyzing [C:/Users/Max/Desktop/SM-A505FN_1_20200407200615_qy13kk1ugj_fac/RootedBoot.oEFT].....OK
Searching for Samsung ODIN protocol.....Detected {COM3}
Reading PIT.....OK
Flashing [data 1].....OK
Flashing [data 2].....OK
Flashing [data 3].....OK
Rebooting device.....OK
Operation {Make Rooted boot} ID: 2AFD01F10890A83A
Elapsed time 01:18 -- Version 3.4.5
LDU REMOVED By EFT
Imei Repaired and patched by chimera thx to ROOT of EFT
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 10-13-2020, 17:22   #5 (permalink)
Glad you made it , you are most welcome !
Page generated in 0.24639 seconds with 7 queries
