EFT Dongle By Easy-Firmware Team What are the advantages https://i2.wp.com/www.eft-dongle.com...size=768%2C482 https://i0.wp.com/i.imgur.com/b0dPBa...43%2C223&ssl=1 SAMSUNG Features : - Extract TAR ROMs - Extract .img files - Dump ROM using ADB - Fix Wi-Fi errors - Add Mobile Data toggle - Remove Secure Storage - Add Arabic & Farsi languages to samsung keyboard - Fix contacts errors for general and Docomo series - Remove T-Mobile bootlogo - Enable hidden languages - Fix TouchWizHome errors - Enable LTE connection - Fix read SIM errors - Repair S-Health on tripped knox - Set SIM count to dual | single - Repair USSD codes - Dump bootlogo and flash it - Dump keyboard languages and write them - Active some useful CSC features - Disable notifications (security updates, SIM card not from and security reports) - Flash factory firmwares - Flash single .img - Read PIT - Reset KNOX - Repair DRK - Remove ScreenLock if FRP ON / OEM ON without data loss - Remove ScreenLock if Data is Encrypted without data loss - Remove FRP for UFS based devices - Remove FPR for EMMC based devices - Remove FRP on ADB - Remove MDM (Knox Configuration Setup Wizard) - Remove Please Call Me - Repair IMEI for SPD based devices - Repair IMEI for Some Qualcomm based devices (not all supported ) - Read CERT for SPD based devices - Write CERT for (Exynos, Qualcomm, SPD) based devices (not all supported ) - Write (nv_data) - Unlock network for (SPD, China, Exynos, Qualcomm, Sprint) based devices - Patch IMEI Certification for SPD based devices - Enable UART connection - Reset MSL for (Exynos, Qualcomm) devices (not all supported ) - Restore original IMEI - Read / Write EFS - Read / Write Security - Reset EFS - Reset Security - Read SPC code - Backup / Restore DRK - Fix EFS errors mount in recovery - Repair dm-verity - Make EFT-SU rooted kernel - Root with prevent RMM from enabling - Make Kernel to remove ScreenLock - Make Kernel to enable ADB - Make Kernel to bypass dm-verity - Make kernel to Backup data to Ext. SdCard - Make Rooted ADB Recovery - Make Recovery to remove ScreenLock on Encrypted data - Unlock bootloader on ADB - Enable DIAG mode - Unbrick Qualcomm based devices (not all) - Extract LZ4 compressed files - Reboot to download mode - Factory Reset HTC Features : - Enable hidden languages - Enable hidden keyboard languages - Read Info - Get identifier token - Unlock / Relock bootloader - Reboot RUU mode - Flash RUU ROM ZIP - Flash unlock code.bin - Flash boot.img - Flash recovery.img - Flash sideload ZIP HUAWEI Features : - Read info - Flash update.app - Reset FRP Online - Reset FRP Offline using MTP - Factory Reset - Remove ScreenLock on locked bootloader MTK Features : - Read info - Format cache - Format userdata - Run Memory test - Format custom partition - Reset FRP - Read / Write Flash - Read data & contacts - Repair IMEI - Supports select custom DA file - Reset ScreenLock (Supports Encrypted data) - Make Rooted Kernel - Read / Write NVRAM - Flash Scatter - Make Kernel to remove ScreenLock LG Features : - Extract (KDZ, DZ) ROMs - Read / Write Flash - Supports Root explorer - Supports ScreenLock reset - Reset FRP - Factory Reset - Supports send custom Command to download mode MOTOROLA Features : - Flash XML ROMs - Reset FRP - Fix Comm Server error ASUS Features : - Flash RAW ROMs XIAOMI Features : - Flash ROMs in EDL mode - Flash ROMs in fastboot mode (TGZ) - Erase Mi Account (Supports custom FireHouse file) - Remove (Pattern, Password, PIN) in Recovery mode - Flash sideload ZIP - Reboot fastboot to EDL - Unlock bootloader - Remove Mi Account with format userdata - Reset MiCloud - Reset Mi Account with FRP QUALCOMM Features : - Flash XML ROMs - Supports use FireHouse - Read info - Read partitions - Reset ScreenLock (Supports Encrypted data) - Read data and contacts - Factory Reset - Reset FRP - Reset config - Make Rooted Kernel - Make Kernel to remove ScreenLock Direct FASTBOOT Features : - Reset FRP (Supports Lenovo brand) - Factory Reset (Supports Lenovo brand) - Repair IMEI - Unlock VIVO bootloader - Unlock LYF bootloader Direct ADB Features : - Factory Reset - Reset ScreenLock (Root) - Reboot to (bootloader, fastboot, download, recovery and EDL) - Open Developer Options directly when system boot Samsung Support Models : GT-I9060C Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) GT-I9060I Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) GT-I9060M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) GT-S5280 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) GT-S5282 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) GT-S5611 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) GT-S5611V Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) GT-S7262 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G110B Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G110H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G110M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130BT Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130BU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130E Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130HN Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130U Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313HY Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313HZ Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313ML Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313MU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313MY Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313U Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G316H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G316HU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G316ML Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G316MY Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G313U Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G318H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G318HZ Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G318ML Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G318MZ Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G130E Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G355H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G355HN Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G355HQ Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G355M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G360H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G360HU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G361H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G361HU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-G531H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J100H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J100ML Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J105B Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J105F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J105H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J105M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J105Y Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J106B Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J106F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J106H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J106M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J110H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J110L Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J111F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J111M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J120H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J200H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J210F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J210FD Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J320F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J320FN Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J320G Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J320H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J320M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-J320MU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T113 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T116 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T116BU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T116IR Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T116NQ Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T116NU Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T116NY Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T280 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T280Q Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T280QZ Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T285 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T285M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T285YD Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T287 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T560 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T561 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T561M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T561Y Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-T562 Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z130H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z200F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z200M Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z200Y Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z300F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z300FD Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z300H Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z400F Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) SM-Z400Y Added(Read/Write EFS – Read/Write/Patch CERT -Read/Write IMEI- Unlock Network) Reset FRP UFS Supported Devices : SM-A810F SM-A810S SM-A810YZ SM-G920A SM-G920AZ SM-G920F SM-G920FD SM-G920FQ SM-G920I SM-G920K SM-G920L SM-G920S SM-G920T SM-G920T1 SM-G920W8 SM-G925A SM-G925F SM-G925FQ SM-G925I SM-G925K SM-G925L SM-G925S SM-G925T SM-G925W8 SM-G9287 SM-G9287C SM-G928A SM-G928C SM-G928F SM-G928G SM-G928I SM-G928K SM-G928L SM-G928N0 SM-G928S SM-G928T SM-G928W8 SM-G930F SM-G930FD SM-G930K SM-G930L SM-G930S SM-G930W8 SM-G935F SM-G935FD SM-G935K SM-G935L SM-G935S SM-G935W8 SM-N9208 SM-N920A SM-N920C SM-N920F SM-N920G SM-N920I SM-N920K SM-N920L SM-N920S SM-N920T SM-N920W8 Reset FRP EMMC Supported Devices : SM-A310F SM-A310FD SM-A310M SM-A310N0 SM-A310MD SM-A310Y SM-A510F SM-A510FD SM-A510M SM-A510MD SM-A510Y SM-A510YD SM-A510S SM-A510K SM-A510L SM-A710F SM-A710FD SM-A710M SM-A710MD SM-A710Y SM-A710S SM-A710K SM-A710L SM-G570F SM-G570FD SM-G570M SM-G570MD SM-G570Y SM-G610F SM-G610FD SM-G610FZ SM-G610M SM-G610L SM-G610K SM-G610S SM-G610YSM SM-J710F SM-J710FQ SM-J710FZ SM-J710FD SM-J710FN SM-J710GN SM-J710K SM-J710MN Write IMEI Supported Devices : GT-B7510 GT-B7510L GT-I5500 GT-I5500B GT-I8150 GT-I8150B GT-I8150T GT-I8160 GT-I8160L GT-I8160P GT-I8190 GT-I8190L GT-I8190N GT-I8190T GT-I8200 GT-I8200L GT-I8200N GT-I8200Q GT-I8260 GT-I8260E GT-I8260L GT-I8262 GT-I8262B GT-I8262D GT-I8320 GT-I9000B GT-I9000M GT-I9000T GT-I9001 GT-I9003 GT-I9010 GT-I9020 GT-I9070 GT-I9070P GT-I9100 GT-I9100G GT-I9100P GT-I9100T GT-I9108 GT-I9190 GT-I9192 GT-I9195 GT-I9195L GT-I9195T GT-I9197 GT-I9200 GT-I9205 GT-I9208 GT-I9210 GT-I9210T GT-N7000 GT-N7000B GT-N7005 GT-N7100 GT-N7100T GT-N7102 GT-N7105 GT-N7105T GT-N8000 GT-N8005 GT-P1000 GT-P3100 GT-P5200 GT-P6800 GT-P6810 GT-S5570 GT-S5570B GT-S5570L GT-S5578 GT-S5660 GT-S5660L GT-S5660M GT-S5660V GT-S5670 GT-S5670L GT-S5690 GT-S5690L GT-S5690R GT-S5690R GT-S5830B GT-S5830D GT-S5830 GT-S5830L GT-S5830T GT-S5838 GT-S6310 GT-S6310L GT-S6310N GT-S6310T GT-S6312 GT-S6500 GT-S6500D GT-S6500L GT-S6500T GT-S6812I GT-S7500 GT-S7500L GT-S7560 GT-S7560M GT-S7562 GT-S7562I GT-S7562L GT-S7710 GT-S7710L GT-S8500 SC-02C SC-02E SC-03E SC-04E SC-04F SC-05D SC-06D SGH-I257 SGH-I257M SGH-I317 SGH-I317M SGH-I337 SGH-I337M SGH-I407 SGH-I497 SGH-I527 SGH-I527M SGH-I537 SGH-I547 SGH-I547C SGH-I577 SGH-I727 SGH-T399 SGH-T399N SM-C101 SM-C105 SM-G361F SM-G3812 SM-G3818 SM-G388F SM-G531F SM-G531Y SM-G7102 SM-G730a SM-G730W8 SM-J100F SM-J100FN SM-J100G SM-J100M SM-J100MU SM-J100MV SM-J100Y SM-J110F SM-J110G SM-J110M SM-T111 SM-T111M SM-T111NQ SM-T211 SM-T211M SM-T217A SM-T217S SM-T217T SM-T232 SM-T2397 SM-T311 SM-T312 Write CERT Supported Devices : GT-B7510 GT-B7510L GT-I5500 GT-I5500B GT-I8150 GT-I8150B GT-I8150T GT-I8160 GT-I8160L GT-I8160P GT-I8190 GT-I8190L GT-I8190N GT-I8190T GT-I8200 GT-I8200L GT-I8200N GT-I8200Q GT-I8260 GT-I8260B GT-I8260E GT-I8260L GT-I8262 GT-I8262B GT-I8262D GT-I8262E GT-I8320 GT-I9000 GT-I9000B GT-I9000M GT-I9000T GT-I9001 GT-I9003 GT-I9003L GT-I9010 GT-I9020 GT-I9070 GT-I9070C GT-I9070H GT-I9070P GT-I9100 GT-I9100G GT-I9100M GT-I9100P GT-I9100T GT-I9103 GT-I9108 GT-I9168I GT-I9190 GT-I9192 GT-I9195 GT-I9195L GT-I9195T GT-I9197 GT-I9198 GT-I9200 GT-I9205 GT-I9206 GT-I9207 GT-I9208 GT-I9210 GT-I9210T GT-N7000 GT-N7000B GT-N7005 GT-N7100 GT-N7100T GT-N7102 GT-N7105 GT-N7105T GT-N8000 GT-N8005 GT-P1000 GT-P1000L GT-P1000M GT-P1000N GT-P1000R GT-P1000T GT-P3100 GT-P3100B GT-P5200 GT-P6800 GT-P6810 GT-P7300 GT-P7300B GT-P7300C GT-S5570 GT-S5570B GT-S5570L GT-S5578 GT-S5660 GT-S5660L GT-S5660M GT-S5660V GT-S5670 GT-S5670B GT-S5670L GT-S5690 GT-S5690L GT-S5690M GT-S5690R GT-S5690R GT-S5830B GT-S5830C GT-S5830D GT-S5830 GT-S5830L GT-S5830T GT-S5830V GT-S5838 GT-S6310 GT-S6310L GT-S6310N GT-S6310T GT-S6312 GT-S6500 GT-S6500D GT-S6500L GT-S6500T GT-S6812I GT-S7500 GT-S7500L GT-S7500T GT-S7508 GT-S7560 GT-S7560M GT-S7562 GT-S7562I GT-S7562L GT-S7572 GT-S7710 GT-S7710L GT-S8500 SC-01C SC-01D SC-01F SC-02C SC-02E SC-03D SC-03E SC-04E SC-04F SC-05D SC-06D SCH-I435 SCH-I535 SCH-I545 SCH-I959 SCH-N719 SCH-R960 SGH-I257 SGH-I257M SGH-I317 SGH-I317M SGH-I337 SGH-I337M SGH-I337Z SGH-I407 SGH-I497 SGH-I527 SGH-I527M SGH-I537 SGH-I547 SGH-I547C SGH-I577 SGH-I727 SGH-T399 SGH-T399N SM-C101 SM-C1010 SM-C105 SM-C105A SM-C105K SM-C105L SM-C105S SM-G361F SM-G3812 SM-G3812B SM-G3815 SM-G3818 SM-G3819 SM-G388F SM-G531BT SM-G531F SM-G531Y SM-G7102 SM-G730A SM-G730M SM-G730W8 SM-G800HQ SM-G9006V SM-G9006W SM-G9008V SM-G9008W SM-G9009D SM-G9009W SM-G900A SM-G900F SM-G900FD SM-G900FG SM-G900H SM-G900I SM-G900K SM-G900L SM-G900M SM-G900MD SM-G900S SM-G900T SM-G900W8 SM-G901F SM-J100F SM-J100FN SM-J100G SM-J100M SM-J100MU SM-J100MV SM-J100Y SM-J110F SM-J110G SM-J110M SM-N900 SM-N9000Q SM-N9005 SM-N900A SM-N900K SM-N900L SM-N900S SM-N900T SM-N900V SM-N900W8 SM-T111 SM-T111M SM-T111NQ SM-T211 SM-T211M SM-T217A SM-T217S SM-T217T SM-T230 SM-T230NT SM-T230NU SM-T231 SM-T232 SM-T237P SM-T2397 SM-T310 SM-T311 SM-T312 SM-T315 SM-T315T SM-N910F SM-N910P SM-N910C SM-N910T SM-N920C SM-N920P SM-N920V SM-N920T MTK Supported CPUs : MT6570 MT6571 MT6572 MT6580 MT6581 MT6582 MT6592 MT6595 MT6735 MT6739 MT6750 MT6752 MT6753 MT6755 MT6757 MT6758 MT6763 MT6771 MT6775 MT6795 MT6797 MT6799 MT8127 MT8167 MT8590 MTK Supported Devices : Huawei CRO-U00 C636 — Secure Boot Huawei CRO-U00 C185 — Secure Boot Huawei CRO-L02 — Secure Boot Huawei CRO-L03 — Secure Boot Huawei CRO-L22 — Secure Boot Huawei CRO-L23 — Secure Boot Huawei CUN-L01 — Secure Boot Huawei CUN-L02 — Secure Boot Huawei CUN-L03 — Secure Boot Huawei CUN-L21 — Secure Boot Huawei CUN-L22 — Secure Boot Huawei CUN-L23 — Secure Boot Huawei CUN-U29 — Secure Boot Huawei LUA-L01 — Secure Boot Huawei LUA-L02 — Secure Boot Huawei LUA-L21 — Secure Boot Huawei LUA-L22 — Secure Boot Huawei LUA-U22 — Secure Boot Huawei LUA-U23 — Secure Boot Huawei LYO-L01 — Secure Boot Huawei LYO-L02 — Secure Boot Huawei LYO-L21 — Secure Boot Huawei TAG-AL00 — Secure Boot Huawei TAG-CL00 — Secure Boot Huawei TAG-TL00 — Secure Boot Huawei TAG-L01 — Secure Boot Huawei TAG-L03 — Secure Boot Huawei TAG-L13 — Secure Boot Huawei TAG-L21 — Secure Boot Huawei TAG-L22 — Secure Boot Huawei TAG-L23 — Secure Boot Asus P001-Z170MG — Secure Boot Asus P00A-Z380M — Secure Boot Asus P00C-Z300M — Secure Boot Asus X002 — Secure Boot Asus X005-T551TLC — Secure Boot Asus X008-ZC520TL — Secure Boot Asus X008D-ZC520TL — Secure Boot Asus x008da-zc520tl — Secure Boot Asus x008dc-zc520tl — Secure Boot Asus X008_1-ZC520TL — Secure Boot Asus z00sd-zc451tg — Secure Boot Asus z00vd-zc500tg — Secure Boot Asus z00yd-G500TG — Secure Boot Acer A20 — Secure Boot Acer A30 — Secure Boot Acer B3 — Secure Boot Acer Z500 — Secure Boot Alcatel OT-4034 — Secure Boot Alcatel OT-5010 — Secure Boot Alcatel OT-5012 — Secure Boot Alcatel OT-5015 — Secure Boot Alcatel OT-5016 — Secure Boot Alcatel OT-5022 — Secure Boot Alcatel OT-5023 — Secure Boot Alcatel OT-5025 — Secure Boot Alcatel OT-5116 — Secure Boot Arshos -101e — Secure Boot Arshos -55 Graphite — Secure Boot Arshos -sense 50dc — Secure Boot Lenovo a1010 — Secure Boot Lenovo A2016a40 — Secure Boot Lenovo A2016b30 — Secure Boot Lenovo A2016b31 — Secure Boot Lenovo A6600D40 — Secure Boot Lenovo A6600A40 — Secure Boot Lenovo A7010A48 — Secure Boot Lenovo A7700 — Secure Boot Lenovo A8-50LC — Secure Boot Lenovo K10a40 — Secure Boot Lenovo P1MA40 — Secure Boot Lenovo PB2-650M — Secure Boot Lenovo PB2-670M — Secure Boot Lenovo S1LA40 — Secure Boot Lenovo TB3-730 — Secure Boot Lenovo TB3-850M — Secure Boot Lenovo TB3-850F — Secure Boot Lenovo TB3-X70L — Secure Boot Lenovo TB3-X70F — Secure Boot MICROMAX Q4311 — Secure Boot MICROMAX YU5011 — Secure Boot MICROMAX YU5012 — Secure Boot MICROMAX C1 — Secure Boot MICROMAX Q404 — Secure Boot MICROMAX Q453 — Secure Boot MICROMAX Q4260 — Secure Boot MICROMAX Q4261 — Secure Boot MICROMAX Q4310 — Secure Boot MICROMAX V51 — Secure Boot Moto xt1721 — Secure Boot Moto xt1723 — Secure Boot Moto xt1724 — Secure Boot Moto xt1725 — Secure Boot Moto xt1726 — Secure Boot Moto xt1721 — Secure Boot Moto xt1723 — Secure Boot Moto xt1724 — Secure Boot Moto xt1725 — Secure Boot Moto xt1726 — Secure Boot Moto xt1750 — Secure Boot Moto xt1754 — Secure Boot Moto xt1755 — Secure Boot Moto xt1756 — Secure Boot Moto xt1757 — Secure Boot Moto xt1758 — Secure Boot Moto xt1754 — Secure Boot Moto xt1755 — Secure Boot Moto xt1756 — Secure Boot Moto xt1757 — Secure Boot Moto xt1758 — Secure Boot Moto xt1754 — Secure Boot Moto xt1755 — Secure Boot Moto xt1756 — Secure Boot Moto xt1757 — Secure Boot Moto xt1758 — Secure Boot Moto xt1754 — Secure Boot Moto xt1755 — Secure Boot Moto xt1756 — Secure Boot Moto xt1757 — Secure Boot Moto xt1758 — Secure Boot Moto xt1760 — Secure Boot Moto xt1761 — Secure Boot Moto xt1762 — Secure Boot Moto xt1763 — Secure Boot Moto xt1766 — Secure Boot Moto xt1770 — Secure Boot Moto xt1771 — Secure Boot Moto xt1772 — Secure Boot Moto xt1773 — Secure Boot TECNO CX AIR — Secure Boot TECNO I3 — Secure Boot TECNO I3 PRO — Secure Boot TECNO I5 PRO — Secure Boot TECNO W5 — Secure Boot WIKO V3720 — Secure Boot WIKO V3953 — Secure Boot WIKO V3961 — Secure Boot WIKO V3971 — Secure Boot ZTE-Blade A520 — Secure Boot ZTE-Blade A6 — Secure Boot ZTE-A660 — Secure Boot ZTE-blade A601 — Secure Boot ZTE-blade A610 — Secure Boot ZTE-blade A610C — Secure Boot Lenovo A7-30DC (Tab 2 A7-30DC 3G Call) Lenovo A7-30F (Tab 2 A7-30F WiFi) Lenovo A7-30GC (Tab 2 A7-30GC 3G Call) Lenovo A7-30H (Tab 2 A7-30H 3G) Lenovo A7-30HC (Tab 2 A7-30HC 3G Call) Lenovo A8-50LC (Tab 2 A8-50LC LTE DS Call) Lenovo A10-70F (Tab 2 A10-70F WiFi) Lenovo A10-70L (Tab 2 A10-70L LTE) Lenovo A10-70LC (Tab 2 A10-70LC LTE Call) Lenovo A10-80HC (Tab A10-80HC 3G Call) Lenovo A269 (A269 3G DS) Lenovo A269i (A269i 3G DS) Lenovo A308T (A308T 3G DS) Lenovo A316 (A316 3G DS) Lenovo A316i (A316i 3G DS) Lenovo A318T (A318T 3G) Lenovo A319 (A319 3G) Lenovo A319-DS (A319 3G DS) Lenovo A320T (A320T 3G) Lenovo A327i (A327i 3G DS) Lenovo A328 (A328 3G DS) Lenovo A369i (A369i 3G DS) Lenovo A399 (A399 3G DS) Lenovo A516 (A516 3G DS) Lenovo A526 (A526 3G DS) Lenovo A529 (A529 3G DS) Lenovo A536 (A536 3G DS) Lenovo A606 (A606 3G) Lenovo A616 (A616 3G DS) Lenovo A628T (A628T 3G DS) Lenovo A680 (A680 3G DS) Lenovo A708T (A708T 3G DS) Lenovo A766 (A766 3G DS) Lenovo A820 (A820 3G DS) Lenovo A830 (A830 3G DS) Lenovo A850 (A850 3G DS) Lenovo A850+ (A850+ 3G DS) Lenovo A858 (A858 LTE DS) Lenovo A858t (A858t LTE DS) Lenovo A859 (A859 3G DS) Lenovo A880 (A880 3G DS) Lenovo A889 (A889 3G DS) Lenovo A916 (A916 3G DS) Lenovo A936 (A936 Note 8 LTE DS) Lenovo A1010a20 (Vibe A Plus 3G) Lenovo A1010a20-DS (Vibe A Plus 3G DS) Lenovo A2010 (A2010 LTE DS) Lenovo A2010l36 (A2010 LTE) Lenovo A2016a40 (Lenovo B LTE DS) Lenovo A3000 (IdeaTab A3000 3G) Lenovo A3000-F (IdeaTab A3000F WiFi) Lenovo A3000-H (IdeaTab A3000H 3G Call) Lenovo A3300-GV (Tab A7-30 A3300GV 2G Call) Lenovo A3300-H (Tab A7-30 A3300H 3G) Lenovo A3300-HV (Tab A7-30 A3300HV 3G Call) Lenovo A3300-T (Tab A7-30 A3300T 3G) Lenovo A3500-F (Tab A7-50 A3500F WiFi) Lenovo A3500-FL (Tab A7-50 A3500FL WiFi) Lenovo A3500-H (Tab A7-50 A3500H 3G) Lenovo A3500-HV (Tab A7-50 A3500HV 3G Call) Lenovo A3600-D (A3600D 3G DS) Lenovo A3690 (A3690 LTE DS) Lenovo A3800-D (A3800D 3G DS) Lenovo A3860 (A3860 LTE DS) Lenovo A3890 (A3890 LTE DS) Lenovo A5000 (A5000 3G DS) Lenovo A5500-F (Tab A8-50 A5500F WiFi) Lenovo A5500-H (Tab A8-50 A5500H 3G) Lenovo A5500-HV (Tab A8-50 A5500HV 3G Call) Lenovo A5600 (A5600 LTE DS) Lenovo A5800-D (A5800D LTE DS) Lenovo A5890 (A5890 LTE DS) Lenovo A6600a40 (A6600+ LTE DS) Lenovo A6600d40 (A6600+ LTE DS) Lenovo A7000-A (A7000 LTE DS) Lenovo A7000+ (A7000+ LTE DS) Lenovo A7010a48 (Vibe K4 Note LTE DS) Lenovo A7020a40 (Vibe K5 Note LTE DS) Lenovo A7020a48 (Vibe K5 Note LTE DS) Lenovo A7600 (S8 A7600 LTE DS) Lenovo A7600-M (S8 A7600M LTE DS) Lenovo A7600-F (Tab A10-70 A7600F WiFi) Lenovo A7600-H (Tab A10-70 A7600H 3G) Lenovo A7700 (A7700 LTE DS) Lenovo B6000-F (Yoga Tab 8 WiFi) Lenovo B6000-H (Yoga Tab 8 3G) Lenovo B6000-HV (Yoga Tab 8 3G Call) Lenovo B8000-F (Yoga Tab 10 WiFi) Lenovo B8000-H (Yoga Tab 10 3G) Lenovo B8000-HV (Yoga Tab 10 3G Call) Lenovo K10a40 (Lenovo C2 LTE) Lenovo K10a40-DS (Lenovo C2 LTE DS) Lenovo K50a40 (K3 Note LTE DS) Lenovo K50-T3s (K3 Note LTE DS) Lenovo K50-T5 (K3 Note LTE DS) Lenovo K51c78 (Vibe X3 Lite LTE DS) Lenovo K52e78 (Vibe K5 Note LTE DS) Lenovo K52t38 (Vibe K5 Note LTE DS) Lenovo P1ma40 (Vibe P1m LTE DS) Lenovo P70-A (P70 LTE DS) Lenovo P70-T (P70 LTE DS) Lenovo P380 (P380 3G DS) Lenovo P780 (P780 3G DS) Lenovo PB2-650M (Phab 2 LTE DS) Lenovo PB2-670M (Phab 2 Plus LTE DS) Lenovo S1a40 (Vibe S1 LTE DS) Lenovo S1La40 (Vibe S1 Lite LTE DS) Lenovo S650 (S650 3G DS) Lenovo S660 (S660 3G DS) Lenovo S668T (S668T 3G DS) Lenovo S750 (S750 3G DS) Lenovo S820 (S820 3G DS) Lenovo S850 (S850 3G DS) Lenovo S858T (S858T 3G DS) Lenovo S860 (S860 3G DS) Lenovo S898T (S8 3G DS) Lenovo S898T+ (S8+ 3G DS) Lenovo S920 (S920 3G DS) Lenovo S930 (S930 3G DS) Lenovo S938T (S938T 3G DS) Lenovo S939 (S939 3G DS) Lenovo S960 (Vibe X 3G) Lenovo S5000-F (IdeaTab S5000F WiFi) Lenovo S5000-H (I deaTab S5000H 3G) Lenovo S6 Alcatel 4003A (Pixi 3-4 3G) Alcatel 4003J (Pixi 3-4 3G) Alcatel 4009A (Pixi 3-3.5 3G) Alcatel 4009D (Pixi 3-3.5 3G DS) Alcatel 4009E (Pixi 3-3.5 3G DS) Alcatel 4009F (Pixi 3-3.5 3G) Alcatel 4009I (Pixi 3-3.5 3G) Alcatel 4009K (Pixi 3-3.5 3G DS) Alcatel 4009M (Pixi 3-3.5 3G) Alcatel 4009S (Pixi 3-3.5 3G) Alcatel 4009X (Pixi 3-3.5 3G) Alcatel 4013D (Pixi 3-4 3G DS) Alcatel 4013E (Pixi 3-4 3G DS) Alcatel 4013J (Pixi 3-4 3G) Alcatel 4013K (Pixi 3-4 3G DS) Alcatel 4013M (Pixi 3-4 3G) Alcatel 4013T (Pixi 3-4 3G) Alcatel 4013X (Pixi 3-4 3G) Alcatel 4014A (Pixi 2 3G) Alcatel 4014D (Pixi 2 3G DS) Alcatel 4014E (Pixi 2 3G) Alcatel 4014K (Pixi 2 3G) Alcatel 4014M (Pixi 2 3G) Alcatel 4014X (Pixi 2 3G) Alcatel 4015A (Pop C1 3G) Alcatel 4015D (Pop C1 3G DS) Alcatel 4015N (Pop C1 3G DS) Alcatel 4015T (Pop C1 3G) Alcatel 4015X (Pop C1 3G) Alcatel 4016A (Pop C1 3G) Alcatel 4016D (Pop C1 3G DS) Alcatel 4016X (Pop C1 3G) Alcatel 4017A (Pixi 4-3.5 3G) Alcatel 4017D (Pixi 4-3.5 3G DS) Alcatel 4017E (Pixi 4-3.5 3G DS) Alcatel 4017F (Pixi 4-3.5 3G) Alcatel 4017S (Pixi 4-3.5 3G) Alcatel 4017X (Pixi 4-3.5 3G) Alcatel 4018A (Pod D1 3G) Alcatel 4018D (Pod D1 3G DS) Alcatel 4018E (Pod D1 3G DS) Alcatel 4018F (Pod D1 3G) Alcatel 4018M (Pod D1 3G) Alcatel 4018X (Pod D1 3G) Alcatel 4022D (Pixi 3-3.5 Firefox 3G DS) Alcatel 4022X (Pixi 3-3.5 Firefox 3G) Alcatel 4027A (Pixi 3-4.5 3G) Alcatel 4027D (Pixi 3-4.5 3G DS) Alcatel 4027N (Pixi 3-4.5 3G DS) Alcatel 4027X (Pixi 3-4.5 3G) Alcatel 4028A (Pixi 3-4.5 3G) Alcatel 4028E (Pixi 3-4.5 3G DS) Alcatel 4028J (Pixi 3-4.5 3G DS) Alcatel 4028S (Pixi 3-4.5 3G) Alcatel 4031D (Flash Mini 3G DS) Alcatel 4031X (Flash Mini 3G) Alcatel 4032A (Pop C2 3G) Alcatel 4032D (Pop C2 3G DS) Alcatel 4032E (Pop C2 3G DS) Alcatel 4032X (Pop C2 3G) Alcatel 4033A (Pop C3 3G) Alcatel 4033D (Pop C3 3G DS) Alcatel 4033E (Pop C3 3G DS) Alcatel 4033X (Pop C3 3G) Alcatel 4034A (Pixi 4-4 3G) Alcatel 4034D (Pixi 4-4 3G DS) Alcatel 4034E (Pixi 4-4 3G DS) Alcatel 4034F (Pixi 4-4 3G) Alcatel 4034G (Pixi 4-4 3G DS) Alcatel 4034M (Pixi 4-4 3G) Alcatel 4034N (Pixi 4-4 3G) Alcatel 4034X (Pixi 4-4 3G) Alcatel 4035A (Pop D3 3G) Alcatel 4035D (Pop D3 3G DS) Alcatel 4035X (Pop D3 3G) Alcatel 4035Y (Pop D3 3G) Alcatel 4036E (Pop D3 3G DS) Alcatel 4037A (Pop D3 3G) Alcatel 4037X (Pop D3 3G) Alcatel 5010D (Pixi 4-5 3G DS) Alcatel 5010E (Pixi 4-5 3G DS) Alcatel 5010G (Pixi 4-5 3G) Alcatel 5010S (Pixi 4-5 3G) Alcatel 5010U (Pixi 4-5 3G DS) Alcatel 5010X (Pixi 4-5 3G) Alcatel 5011A (A3 Plus 3G) Alcatel 5012F (Pixi 4-5.5 3G) Alcatel 5012G (Pixi 4-5.5 3G) Alcatel 5015A (Pop 3-5 3G) Alcatel 5015D (Pop 3-5 3G DS) Alcatel 5015E (Pop 3-5 3G DS) Alcatel 5015X (Pop 3-5 3G) Alcatel 5016A (Pop 3-5 3G) Alcatel 5016J (Pop 3-5 3G DS) Alcatel 5017A (Pixi 3-4.5 LTE) Alcatel 5017B (Pixi 3-4.5 LTE) Alcatel 5017D (Pixi 3-4.5 LTE DS) Alcatel 5017E (Pixi 3-4.5 LTE DS) Alcatel 5017G (Pixi 3-4.5 LTE) Alcatel 5017O (Pixi 3-4.5 LTE) Alcatel 5017W (Pixi 3-4.5 LTE) Alcatel 5017X (Pixi 3-4.5 LTE) Alcatel 5019D (Pixi 3-4.5 LTE DS) Alcatel 5022D (Pop Star 3G DS) Alcatel 5022E (Pop Star 3G DS) Alcatel 5022F (Pop Star 3G) Alcatel 5022N (Pop Star 3G) Alcatel 5022X (Pop Star 3G) Alcatel 5023E (Pixi 4 Plus Power 3G DS) Alcatel 5023F (Pixi 4 Plus Power 3G DS) Alcatel 5025D (Pop 3-5.5 3G DS) Alcatel 5025E (Pop 3-5.5 3G DS) Alcatel 5025G (Pop 3-5.5 3G) Alcatel 5025N (Pop 3-5.5 3G) Alcatel 5025X (Pop 3-5.5 3G) Alcatel 5036A (Pop C5 3G) Alcatel 5036D (Pop C5 3G DS) Alcatel 5036F (Pop C5 3G) Alcatel 5036X (Pop C5 3G) Alcatel 5037A (Pop C5 TV 3G) Alcatel 5037E (Pop C5 TV 3G DS) Alcatel 5037X (Pop C5 TV 3G) Alcatel 5038A (Pop D5 3G) Alcatel 5038D (Pop D5 3G DS) Alcatel 5038E (Pop D5 3G DS) Alcatel 5038X (Pop D5 3G) Alcatel 5041D (Pixi 4-5 4G LTE DS) Alcatel 5045A (Pixi 4-5 4G LTE) Alcatel 5045D (Pixi 4-5 4G LTE DS) Alcatel 5045F (Pixi 4-5 4G LT Alcatel 5045G (Pixi 4-5 4G LTE) Alcatel 5045I (Pixi 4-5 4G LTE) Alcatel 5045J (Pixi 4-5 4G LTE DS) Alcatel 5045T (Pixi 4-5 4G LTE DS) Alcatel 5045X (Pixi 4-5 4G LTE) Alcatel 5045Y (Pixi 4-5 4G LTE) Alcatel 5070D (Pop Star LTE DS) Alcatel 5070S (Pop Star LTE DS) Alcatel 5070T (Pop Star LTE DS) Alcatel 5070X (Pop Star LTE) Alcatel 5116J (Pop 3-5 3G DS) Alcatel 5138E (Pop D5 3G DS) Alcatel 6012A (Idol Mini 3G) Alcatel 6012D (Idol Mini 3G DS) Alcatel 6012E (Idol Mini 3G DS) Alcatel 6012X (Idol Mini 3G) Alcatel 6032A (Idol Alpha 3G) Alcatel 6032X (Idol Alpha 3G) Alcatel 6037B (Idol 2 3G) Alcatel 6037K (Idol 2 3G DS) Alcatel 6037Y (Idol 2 3G) Alcatel 6040A (Idol X 3G) Alcatel 6040D (Idol X 3G DS) Alcatel 6040E (Idol X 3G DS) Alcatel 6040X (Idol X 3G) Alcatel 6042D (Flash 3G DS) Alcatel 6043A (Idol X Plus 3G) Alcatel 6043D (Idol X Plus 3G DS) Alcatel 7040A (Pop C7 3G) Alcatel 7040D (Pop C7 3G DS) Alcatel 7040E (Pop C7 3G DS) Alcatel 7040F (Pop C7 3G) Alcatel 7040K (Pop C7 3G DS) Alcatel 7041D (Pop C7 3G DS) Alcatel 7041X (Pop C7 3G) Alcatel 7042A (Pop C7+ 3G) Alcatel 7042D (Pop C7+ 3G DS) Alcatel 7042E (Pop C7+ 3G DS) Alcatel 7045A (Pop S7 3G) Alcatel 7045Y (Pop S7 3G) Alcatel 7047A (Pop C9 3G) Alcatel 7047D (Pop C9 3G DS) Alcatel 7047E (Pop C9 3G DS) Alcatel 7049D (Flash 2 LTE DS) Alcatel 7054T (Flash+ LTE DS) Alcatel 8008D (Scribe HD 3G DS) Alcatel 8008X (Scribe HD 3G) Alcatel 8020D (Hero 3G DS) Alcatel 8020X (Hero 3G) Alcatel 8030B (Hero 2 3G DS) Alcatel 8030Y (Hero 2 3G DS) Alcatel 8050D (Pixi 4-6 3G DS) Alcatel 8050E (Pixi 4-6 3G DS) Alcatel 8050G (Pixi 4-6 3G) Alcatel 8050X (Pixi 4-6 3G) Alcatel 9002A (Pixi 3-7 3G) Alcatel 9002W (Pixi 3 VIVO-X3S W (X3S W 3G DS) VIVO-X5 MaxS (X5 Max S LTE DS) VIVO-X5 MaxPlus (X5 Max Plus LTE DS) VIVO-X5 ProD (X5 Pro D LTE DS) VIVO-X5S L (X5S L LTE DS) VIVO-X5L (X5L 3G DS) VIVO-Y11 (Y11 3G DS) VIVO-Y11iT (Y11iT 3G DS) VIVO-Y11iW (Y11iW 3G DS) VIVO-Y11T (Y11T 3G DS) VIVO-Y13 (Y13 3G) VIVO-Y13T (Y13T 3G DS) VIVO-Y15 (Y15 3G) VIVO-Y15bW (Y15bW 3G) VIVO-Y15cW (Y15cW 3G) VIVO-Y15S (Y15S 3G) VIVO-Y15T (Y15T 3G) VIVO-Y17T (Y17T 3G DS) VIVO-Y17W (Y17W 3G DS) VIVO-Y20T (Y20T 3G DS) VIVO-Y21 (Y21 3G DS) VIVO-Y22 (Y22 3G DS) VIVO-Y22iL (Y22iL 3G) VIVO-Y28 (Y28 3G DS) VIVO-Y31 (Y31 3G DS) VIVO-Y31i (Y31i 3G DS) VIVO-Y33 (Y33 LTE DS) VIVO-Y35L (Y35L LTE DS) VIVO-Y613 (Y613 3G DS) VIVO-Y622 (Y622 3G DS) INNJOO-2 (InnJoo 2 3G DS) INNJOO-5 (InnJoo 5 LTE DS) INNJOO-Fire 3G (Fire 3G DS) INNJOO-Fire 2 3G (Fire 2 3G DS) INNJOO-Fire 2 LTE (Fire 2 LTE DS) INNJOO-Fire 2 Plus LTE (Fire 2 Plus LTE DS) INNJOO-Fire 3 LTE (Fire 3 LTE DS) INNJOO-Fire 3 Air LTE (Fire 3 Air LTE DS) INNJOO-Fire Plus 3G (Fire Plus 3G DS) INNJOO-Fire Plus LTE (Fire Plus LTE DS) INNJOO-Fire Pro LTE (Fire Pro LTE DS) INNJOO-Halo LTE (Halo LTE DS) INNJOO-Halo 2 LTE (Halo 2 LTE DS) INNJOO-i1 (i1 3G DS) INNJOO-i1k (i1k 3G DS) INNJOO-i1s (i1s 3G DS) INNJOO-i2 (i2 3G DS) INNJOO-i2s (i2s 3G DS) INNJOO-Max 3 3G (Max 3 3G DS) INNJOO-Max 3 LTE (Max 3 LTE DS) INNJOO-Max 3 Pro (Max 3 Pro LTE DS) INNJOO-Note (Note 3G DS) INNJOO-Note 2 3G (Note 2 3G DS) INNJOO-Note E (Note E 3G DS) INNJOO-Note Pro (Note Pro 3G DS) INNJOO-One HD 3G (One HD 3G DS) INNJOO-One HD LTE (One HD LTE DS) INNJOO-Pro (Pro LTE DS) INNJOO-Two 3G (Two 3G DS) INNJOO-Two LTE (Two LTE DS) INNJOO-X2 (X2 3G DS) INNJOO-Max (3G (Max 3G DS) INNJOO-Max 2 3G (Max 2 3G DS) INNJOO-Max 2 Plus 3G (Max 2 Plus 3G DS) INNJOO-Pro 2 (Pro 2 LTE DS) INNJOO-3 (InnJoo 3 LTE DS) INNJOO-4 (InnJoo 4 LTE DS) Huawei LUA-U22 TEST1 Huawei LUA-U22 TEST2 ZTE-BA611C (Voyage 4S LTE DS) ZTE-BA611T (Voyage 4S LTE DS) ZTE-Blade A110 (Blade A110 LTE DS) ZTE-Blade A210 (Blade A210 LTE DS) ZTE-Blade A315 (Blade A315 LTE DS) ZTE-Blade A410 (Blade A410 LTE DS) ZTE-Blade A430 (Blade A430 LTE) ZTE-Blade A450 (Blade A450 LTE) ZTE-Blade A452 (Blade A452 LTE DS) ZTE-Blade A465 (Blade A465 LTE DS) ZTE-Blade A475 (Blade L4 Pro LTE DS) ZTE-Blade A476 (Blade A476 LTE DS) ZTE-Blade A510 (Blade A510 LTE DS) ZTE-Blade A511 (Blade A511 LTE DS) ZTE-Blade A515 (Blade A515 LTE DS) ZTE-Blade A520 (Blade A520 LTE DS) ZTE-Blade A601 (Blade A601 LTE DS) ZTE-Blade A610 (Blade A610 LTE DS) ZTE-Blade A610C (Blade A610 LTE DS) ZTE-Blade A610 Plus (Blade A610 Plus LTE DS) ZTE-Blade A612 (Blade A612 LTE DS) ZTE-Blade A910 (Blade A910 LTE DS) ZTE-Blade Buzz (Blade Buzz 3G DS) ZTE-Blade G Lux (Blade G Lux 3G) ZTE-Blade L2 (Blade L2 3G DS) ZTE-Blade L2 Plus (Blade L2 Plus 3G DS) ZTE-Blade L3 (Blade L3 3G DS) ZTE-Blade L3 Lite (Blade L3 Lite 3G DS) ZTE-Blade L3 Plus (Blade L3 Plus 3G DS) ZTE-Blade L370 (Blade L370 3G DS) ZTE-Blade L4 Pro (Blade L4 Pro LTE DS) ZTE-Blade L5 (Blade L5 3G DS) ZTE-Blade L5 Plus (Blade L5 Plus 3G DS) ZTE-Blade L6 (Blade L6 3G DS) ZTE-Blade Q Lux 3G (Blade Q Lux 3G DS) ZTE-Blade Q Lux 4G DS (Blade Q Lux LTE DS) ZTE-Blade Q Lux 4G SS (Blade Q Lux LTE) ZTE-Blade V6 (Blade V6 LTE DS) ZTE-Blade V7 (Blade V7 LTE DS) ZTE-Blade V7 Lite (Blade V7 Lite LTE DS) ZTE-Blade V7 Max (Blade V7 Max LTE DS) ZTE-Blade V7 Plus (Blade V7 Plus LTE DS) ZTE-Blade V8 Lite (Blade V8 Lite LTE DS) ZTE-Blade Vec (Blade Vec 3G DS) ZTE-Blade VecPro (Blade Vec Pro 3G DS) ZTE-NX535J (Nubia Z11 Max CE LTE DS) ZTE-NX541J (Nubia N1 LTE DS) ZTE-NX573J (Nubia M2 Lite LTE DS) ZTE-NX575J (Nubia N2 LTE DS) ZTE-NX597J (Nubia N1 Lite LTE DS) ZTE-P172A10 (V809, Blade C2 3G) ZTE-P172B20 (Blade C2 Plus 3G DS) ZTE-P172R10 (T815 Telstra Tempo 3G) ZTE-S158 (S158 LTE DS) ZTE-T520 (T520 3G DS) ZTE-T620 (Blade X3 LTE DS) ZTE-T630 (Blade X5 LTE DS) ZTE-T660 (Blade X7 LTE DS) ZTE-T815 (Telstra Tempo 3G) ZTE-V0730 (Blade A610 Plus LTE DS) ZTE-V580 (Blade V Plus LTE DS) ZTE-V765M (V765M 3G) ZTE-V815W (Blade Buzz 3G DS) ZTE-V816W (Blade Buzz 3G DS) ZTE-V829 (Blade G Plus 3G DS) ZTE-V830W (Blade G Lux 3G DS) ZTE-V993W (Blade V5 3G DS) HISENSE TEST HISENSE-F30 (PureShot Lite LTE DS) HISENSE-L675 (L675 LTE DS) HISENSE-U602 (U602 3G DS) HISENSE-U608 (Starshine 4 3G DS) HISENSE-U939 (Glory U939 3G DS) Nokia NE1 (Nokia 3 LTE) Nokia NE1-DS (Nokia 3 LTE DS) Nokia TA-1020 (Nokia 3 LTE) Nokia TA-1028 (Nokia 3 LTE LA) Nokia TA-1032 (Nokia 3 LTE DS)) Nokia TA-1038 (Nokia 3 LTE LA DS)) LYF-LS-4004 (Flame 2 LTE DS) LYF-LS-5013 (Wind 5 LTE DS) LYF-LS-5017 (Water 11 LTE DS) LYF-LS-5020 (Water 10 LTE DS) LYF-LS-5506 (Water 9 LTE DS) LYF-LS-5507 (Water 7 LTE DS) LYF-LS-5512 (LS-5512 LTE DS) LYF-LS-6001 (Wind 2 LTE DS) LEAGOO-Elite Y (Elite Y LTE DS) LEAGOO-KIICAA Power (KIICAA Power 3G DS) LEAGOO-M5 (M5 3G DS) LEAGOO-M5 Edge (M5 Edge LTE DS) LEAGOO-M5 Plus (M5 Plus LTE DS) LEAGOO-M7 (M7 3G DS) LEAGOO-M8 (M8 3G DS) LEAGOO-M8 Pro (M8 Pro LTE DS) LEAGOO-P1 (P1 3G DS) LEAGOO-T1 (T1 LTE DS) LEAGOO-T1 Plus (T1 Plus LTE DS) LEAGOO-T5 (T5 LTE DS) LEAGOO-Venture1 (Venture 1 LTE DS) LEAGOO-KIICAA Mix (KIICAA Mix LTE DS) LEAGOO-T10 (T10 LTE DS) LEAGOO-S8 (S8 LTE DS) Symphony V120 Symphony P8 pro Symphony P9 pro Symphony i10+ Symphony G20 Infinix X606B (Hot 6) Infinix X5514D (Smart 2 pro) Infinix X5515 (Smart 2) TECNO-7C (DroiPad 7C 3G) TECNO-7CS (DroiPad 7CS 3G) TECNO-7H (DroiPad 7H 3G) TECNO-8H (DroiPad 8H 3G) TECNO-A7 (Phantom Z 3G DS) TECNO-A7S (Phantom Z 3G DS) TECNO-A9 (Phantom 6 Plus LTE DS) TECNO-AL58 (Festa 5 CM LTE DS) TECNO-AL59 (Festa 5 CU LTE DS) TECNO-AX8 (Phantom 8 LTE DS) TECNO-AX8S (Phantom 8S LTE DS) TECNO-C5 (Camon C5 LTE DS) TECNO-C7 (Camon C7 LTE DS) TECNO-C8 (Camon C8 LTE DS) TECNO-C9 (Camon C9 LTE DS) TECNO-C9 Plus (Camon C9 Plus LTE DS) TECNO-CA6 (Camon CM LTE DS) TECNO-CA7 (Camon X LTE DS) TECNO-CA8 (Camon X Pro LTE DS) TECNO-DP7CPRO (DroiPad 7C Pro 3G DS) TECNO-DP8D (DroiPad 8D LTE DS) TECNO-F1 (F1 3G DS) TECNO-F2 (F2 3G DS) TECNO-F3 (F3 POP1 3G DS) TECNO-F3 pro (F3 pro POP1 3G DS) TECNO-F6 (F6 3G DS) TECNO-H6 (H6 3G DS) TECNO-H7 (H7 3G DS) TECNO-H7 Plus (H7 Plus 3G DS) TECNO-H7S (H7S LTE) TECNO-IN2 (Camon iSky LTE DS) TECNO-IN3 (Camon iAir LTE DS) TECNO-IN5 (Camon I LTE DS) TECNO-IN6 (Camon iClick LTE DS) TECNO-J5 (Boom J5 3G DS) TECNO-J7 (Boom J7 3G DS) TECNO-J8 (Boom J8 LTE DS) TECNO-K7 (Spark 9 K7 3G DS) TECNO-K8 (Spark Pro K8 LTE DS) TECNO-K9 (Spark Plus K9 3G DS) TECNO-KA7 (Spark 2 3G DS) TECNO-KA7 (Spark 2) TECNO-KA9 (Spark CM LTE DS) TECNO-L5 (L5 3G DS) TECNO-L6 (L6 3G DS) TECNO-L7 (L7 3G DS) TECNO-L8 (Power Max L8 3G DS) TECNO-L8 Lite (Power Max L8 Lite 3G DS) TECNO-L8 Plus (Power Max L8 Plus 3G DS) TECNO-L9 (Power Max L9 3G DS) TECNO-L9 Plus (Power Max L9 Plus 3G DS) TECNO-LA6 (Pouvoir 1 3G DS) TECNO-LA7 (Pouvoir 2 LTE DS) TECNO-M6 (M6 3G DS) TECNO-M6S (M6S 3G DS) TECNO-N2 (N2 3G DS) TECNO-N2S (N2S 3G DS) TECNO-N8 (N8 LTE DS) TECNO-N8S (N8S LTE DS) TECNO-N9 (N9 3G DS) TECNO-P5 (P5 3G DS) TECNO-P5 Plus (P5 Plus 3G DS) TECNO-P5S (P5S LTE DS) TECNO-P6 (P6 3G DS) TECNO-P701 (DroiPad 7D 3G DS) TECNO-P9 (P9 3G) TECNO-Phantom5 (Phantom 5 LTE DS) TECNO-Phantom5S (Phantom 5S LTE DS) TECNO-PP7E (PhonePad 7E LTE DS) TECNO-PTM-Z Mini (Phantom Z Mini 3G DS) TECNO-R5 (R5 3G DS) TECNO-R6 (R6 LTE DS) TECNO-R7 (R7 3G DS) TECNO-S1 (S1 3G DS) TECNO-S1E (S1E Pro 3G DS) TECNO-S1M (S1M 3G) TECNO-S1S (S1S Lite 3G DS) TECNO-S9 (S9 3G DS) TECNO-S9S (S9S 3G) TECNO-W1 (W1 3G DS) TECNO-W2 (W2 3G DS) TECNO-W3 (W3 3G DS) TECNO-W3 LTE (W3 LTE DS) TECNO-W4 (W4 3G DS) TECNO-W5 Lite (W5 Lite 3G DS) TECNO-WX3 (WX3 3G DS) TECNO-WX3P (WX3P 3G DS) TECNO-WX4 (WX4 3G DS) TECNO-Y2 (Y2 3G DS) TECNO-Y3 (Y3 3G DS) TECNO-Y3S (Y3S 3G DS) TECNO-Y4 (Y4 3G DS) TECNO-Y5 (Y5 3G DS) TECNO-Y5S (Y5S 3G DS) TECNO-Y6 (Y6 3G DS) MICROMAX-A37 (Bolt A37 3G DS) MICROMAX-A37B (Bolt A37B 3G DS) MICROMAX-A46 (Bolt A46 3G DS) MICROMAX-A47 (Bolt A47 3G DS) MICROMAX-A58 (Bolt A58 3G DS) MICROMAX-A63 (Canvas Fun 3G DS) MICROMAX-A74 (Canvas Fun 3G DS) MICROMAX-A76 (Canvas Fun 3G DS) MICROMAX-A77 (Canvas Juice 3G DS) MICROMAX-A79 (Bolt A79 3G DS) MICROMAX-A82 (Bolt A82 3G DS) MICROMAX-A93 (Canvas Elanza 3G DS) MICROMAX-A96 (Canvas Power 3G DS) MICROMAX-A99 (Canvas Xpress 3G DS) MICROMAX-A068 (Bolt A068 3G DS) MICROMAX-A069 (Bolt A069 3G DS) MICROMAX-A082 (Bolt A082 3G DS) MICROMAX-A089 (Bolt A089 3G DS) MICROMAX-A093 (Canvas Fire 3G DS) MICROMAX-A096 (Canvas Fire 3 3G DS) MICROMAX-A102 (Canvas Doodle 3 3G DS) MICROMAX-A104 (Canvas Fire 2 3G DS) MICROMAX-A106 (Unite 2 3G DS) MICROMAX-A107 (Canvas Fire 4 3G DS) MICROMAX-A108 (Canvas L 3G DS) MICROMAX-A109 (Canvas XL 2 3G DS) MICROMAX-A110Q (Canvas 2 Plus 3G DS) MICROMAX-A114 (Canvas 2.2 3G DS) MICROMAX-A116 (Canvas HD 3G DS) MICROMAX-A116i (Canvas HD 3G DS) MICROMAX-A117 (Canvas Magnus 3G DS) MICROMAX-A119 (Canvas XL 3G DS) MICROMAX-A120 (Canvas 2 3G DS) MICROMAX-A177 (Canvas Juice 3G DS) MICROMAX-A190 (Canvas HD Plus 3G DS) MICROMAX-A200 (Canvas Turbo Mini 3G DS) MICROMAX-A210 (Canvas 4 3G DS) MICROMAX-A240 (Canvas Doodle 2 3G DS) MICROMAX-A250 (Canvas Turbo 3G DS) MICROMAX-A255 (Canvas Selfie 3G DS) MICROMAX-A290 (Canvas Knight Cameo 3G DS) MICROMAX-A300 (Canvas Gold 3G DS) MICROMAX-A310 (Canvas Nitro 3G DS) MICROMAX-A311 (Canvas Nitro 3G DS MICROMAX-A315 (Canvas 4 Plus 3G DS) MICROMAX-A316 (Canvas Hue 2 3G DS) MICROMAX-A350 (Canvas Knight 3G DS) MICROMAX-AQ4501 (Canvas A1 3G DS) MICROMAX-AQ4502 (Canvas A1 3G DS) MICROMAX-AQ4750 (AQ4750 3G DS) MICROMAX-AQ5000 (Canvas Hue 3G DS) MICROMAX-AQ5001 (Canvas Juice 2 3G DS) MICROMAX-C1 (Canvas 1 LTE DS) MICROMAX-C1A (Canvas 1 LTE DS) MICROMAX-D303 (Bolt D303 3G DS) MICROMAX-D304 (Bolt D304 3G DS) MICROMAX-D305 (Bolt D305 3G DS) MICROMAX-D306 (Bolt D306 3G DS) MICROMAX-D320 (Bolt D320 3G DS) MICROMAX-D321 (Bolt D321 3G DS) MICROMAX-D340 (Bolt D340 3G DS) MICROMAX-E311 (Canvas Nitro 2 3G DS) MICROMAX-E313 (Canvas Xpress 2 3G DS) MICROMAX-E352 (Canvas Nitro 3 3G DS) MICROMAX-E353 (Canvas Mega 3G DS) MICROMAX-E451 (Canvas Pulse 4G LTE DS) MICROMAX-E453 (Canvas Evok Note LTE DS) MICROMAX-E481 (Canvas 5 LTE DS) MICROMAX-E484 (Canvas 6 Pro LTE DS) MICROMAX-E485 (Canvas 6 LTE DS) MICROMAX-E491 (Canvas Fabes LTE DS) MICROMAX-E4815 (Evok Dual Note LTE DS) MICROMAX-E4817 (Evok Dual Note LTE DS) MICROMAX-F666 (Fantabulet F666 3G DS) MICROMAX-P470 (Canvas Tab P470 3G DS) MICROMAX-P480 (Canvas Tab P480 3G) MICROMAX-P580 (Funbook Ultra HD 3G) MICROMAX-P650 (Canvas Tab P650 3G) MICROMAX-P660 (Canvas Breeze Tab 3G) MICROMAX-P701 (Canvas Tab P701 LTE) MICROMAX-P702 (Canvas Tab P702 LTE) MICROMAX-P70221 (Canvas Tab P70221 3G) MICROMAX-P802 (Canvas Tab P802 LTE) MICROMAX-Q303 (Bolt Q303 3G DS) MICROMAX-Q332 (Bolt Q332 3G DS) MICROMAX-Q334 (Canvas Spark 2 3G DS) MICROMAX-Q338 (Bolt Q338 3G DS) MICROMAX-Q340 (Canvas Selfie 2 3G DS) MICROMAX-Q345 (Canvas Selfie Lens 3G DS) MICROMAX-Q348 (Canvas Selfie 3 3G DS) MICROMAX-Q349 (Canvas Selfie 4 3G DS) MICROMAX-Q350 (Canvas Spark 2 Plus 3G DS) MICROMAX-Q350R (Canvas Spark 2 Plus 3G DS) MICROMAX-Q352 (Bolt Supreme 4 3G DS) MICROMAX-Q352+ (Bolt Supreme 4 Plus 3G DS MICROMAX-Q354 (Bolt Q354 3G DS) MICROMAX-Q355 (Canvas Play 3G DS) MICROMAX-Q371 (Canvas Pep 3G DS) MICROMAX-Q372 (Unite 3 3G DS) MICROMAX-Q375 (Canvas Fire 3 3G DS) MICROMAX-Q380 (Canvas Spark 3G DS) MICROMAX-Q386 (Canvas Fire 5 3G DS) MICROMAX-Q391 (Canvas Doodle 4 3G DS) MICROMAX-Q392 (Canvas Juice 3 3G DS) MICROMAX-Q394 (Canvas Juice 3 Plus 3G DS) MICROMAX-Q395 (Canvas Amaze 3G DS) MICROMAX-Q404 (Canvas Q404 LTE DS) MICROMAX-Q409 (Bolt Supreme 6 LTE DS) MICROMAX-Q411 (Canvas Fire 4G Plus LTE DS) MICROMAX-Q412 (Canvas Fire 4G Plus LTE DS) MICROMAX-Q413 (Canvas Express 4G LTE DS) MICROMAX-Q413+ (Canvas XP 4G LTE DS) MICROMAX-Q414 (Canvas Blaze 4G Plus LTE DS) MICROMAX-Q417 (Canvas Mega 4G LTE DS) MICROMAX-Q421 (Canvas Magnus HD LTE DS) MICROMAX-Q424 (Bolt Selfie Q424 LTE DS) MICROMAX-Q427 (Canvas Unite 4 LTE DS) MICROMAX-Q427+ (Canvas Unite 4 Plus LTE DS) MICROMAX-Q428 (Canvas Fire 6 LTE DS) MICROMAX-Q437 (Q437 LTE DS) MICROMAX-Q438 (Q438 LTE DS) MICROMAX-Q440 (Q440 LTE DS) MICROMAX-Q441 (Q441 LTE DS) MICROMAX-Q452 (Spark 4G Prime LTE DS) MICROMAX-Q453 (Q453 LTE DS) MICROMAX-Q461 (Canvas Juice 4G LTE DS) MICROMAX-Q462 (Canvas 5 Lite LTE DS) MICROMAX-Q463 (Canvas 5 Lite SE LTE DS) MICROMAX-Q4260 (Evok Power LTE DS) MICROMAX-Q4261 (Fire Q4261 LTE DS) MICROMAX-Q4310 (Canvas 2 LTE DS) MICROMAX-Q4311 (Selfie 2 LTE DS) MICROMAX-Q4601 (Selfie 2 Note LTE DS) MICROMAX-V51 (MMX V51 LTE DS) MICROMAX-YU-YU5011 (Yunique 2 LTE DS) MICROMAX-YU-YU5012 (Yunique 2 LTE DS) MICROMAX-YU-YU5530 (Yunicorn LTE DS) MICROMAX-YU-YU6000 (Yureka Note LTE DS) VODAFONE-VODAFONE-VFD300 (Smart Mini 7 3G) VODAFONE-VODAFONE-VFD301 (Smart Mini 7 3G DS) VODAFONE-VODAFONE-VFD500 (Smart Turbo 7 LTE) VODAFONE-VODAFONE-VFD501 (Smart Turbo 7 LTE) VODAFONE-VODAFONE-VFD502 (Smart Turbo 7 LTE DS) ALTICE-Starnaute 4 (Starnaute 4 3G) ARTEL-Z5 (Z5 3G DS) ARCHOS-101E Neon (101E Neon WiFi) ARCHOS-Sense 50DC (Sense 50DC LTE DS) ARCHOS-55 Graphite (55 Graphite LTE DS) BLACKVIEW-A10 (A10 3G DS) BLACKVIEW-A7 (A7 3G DS) BLACKVIEW-A9 (A9 3G DS) BLACKVIEW-S8 (S8 LTE DS) BLU-D0030UU (Dash X Plus LTE DS) BLU-G0010JJ (Grand X LTE DS) BLU-G0010WW (Grand X LTE DS) BLU-G0030 (Grand XL LTE DS) BLU-G030L (Grand 5.5 HD 3G DS) BLU-G030U (Grand 5.5 HD 3G DS) BLU-G070 (Grand M 3G DS) BLU-G130 (Grand Energy 3G DS) BLU-G150 (Grand XL 3G DS) BLU-R0010UU (R1 HD LTE DS) BLU-R0011UU (R1 HD LTE DS) BLU-R0030UU (R1 HD LTE DS) BLU-R0031UU (R1 HD LTE DS) BLU-R0051UU (R1 Plus LTE DS) BLU-R010P (R2 3G DS) BLU-R0110 (J2 LTE DS) BLU-R0150EE (R2 LTE DS) BLU-R0170WW (R2 LTE DS) BLU-R0190WW (R2 Plus LTE DS) BLU-V0290WW (Vivo One Plus LTE DS) BLU-V050 (Vivo 5 Mini 3G DS) BQ-Aquaris M10 (Aquaris M10 WiFi) BQ-Aquaris M10 4G (Aquaris M10 4G LTE) BQ-Aquaris M10FHD (Aquaris M10 FHD WiFi) BQ-Aquaris M8 (Aquaris M8 WiFi) BQ-BQS-5057 (Strike 2 3G DS) BQ-BQS-5058 (Strike Power Easy 3G DS) CASPER-Via E2 (Via E2 LTE) CASPER-Via M3 (Via M3 LTE) CHERRY-Flare J3 Lite (Flare J3 Lite 3G DS) CHERRY-Flare S6 Lite (Flare S6 Lite 3G DS) CHERRY-Selfie 2 (Selfie 2 LTE DS) DOOGEE-X20 (X20 3G DS) DOOGEE-X30 (X30 3G DS) HYUNDAI-A25024L (A25024L LTE DS) HYUNDAI-G25022K (G25022K 3G DS) iBALL-Andi 5.5H Weber 4G (5.5H Weber 4G LTE DS) iBALL-Andi 5Q Gold 4G (5Q Gold 4G LTE DS) iBALL-Cobalt Solus 4G (Solus 4G LTE DS) INTEX-Elyt E7 (Elyt E7 LTE DS) KARBONN-Aura Note 4G (Aura Note 4G LTE DS) KARBONN-Aura Note2 (Aura Note 2 LTE DS) KREZ-SL502 (SL502 3G DS) LAVA-A1 (A1 LTE DS) LAVA-Iris 80 (Iris 80 LTE DS) LAVA-Z5 (Z5 LTE DS) LAVA-Z60E (Z60E LTE DS) LAVA-Z80 (Z80 LTE DS) LAVA-Z80E (Z80E LTE DS) LAVA-Z90 (Z90 LTE DS) LETV-X620 (LeEco Le 2 Pro LTE DS) LETV-X622 (LeEco Le S3 LTE DS) LETV-X626 (LeEco Le S3 LTE DS) NOUS-NS5002 (NS5002 3G DS) OUKITEL-C5 Pro (C5 LTE DS) OUKITEL-U22 (U22 3G DS) PANASONIC-Eluga WE (Eluga WE LTE DS) PANASONIC-P9 (P9 LTE DS) PANASONIC-P91 (P91 LTE DS) PANASONIC-P99 (P99 LTE DS) PRESTIGIO-PMT5487 (Multipad4 Quantum 8.1 3G) QMOBILE-CS1 QMOBILE-CS1 PLUS QMOBILE -J1 QMOBILE -J2 QMOBILE -I6 METAL 2017 QMOBILE -I6 METAL ONE TECNO-A6 (Phantom 6 LTE DS) TECNO-A6S (Phantom 6S LTE DS) TECNO-CX Air (Camon CX Air LTE DS) TECNO-CX-H501D1 (Camon CX LTE DS) TECNO-CX-H501DE (Camon CX LTE DS) TECNO-CXS (Camon CXS LTE DS) TECNO-i3 (i3 LTE DS) TECNO-i3 Pro (i3 Pro LTE DS) TECNO-i5 (i5 LTE DS) TECNO-i5 Pro (i5 Pro LTE DS) TECNO-i7 (i7 LTE DS) TECNO-W5 (W5 LTE DS) TELENOR-UP06 Smart (Smart 3G) TELENOR-UP16 Smart Plus (Smart Plus 3G) TELENOR-V816W Smart (Smart 3G) VERTEX-ImpressLuck (Impress Luck 3G DS) VERTEX-ImpressNight (Impress Night LTE DS) XIAOMI-Redmi Note 2 Hermes (Note 2 LTE DS) XIAOMI-Redmi Note 3 Henessy (Note 3 LTE DS) XIAOMI-Redmi Note 4 Nikel (Note 4 LTE DS) XIAOMI-Redmi Pro Omega (Redmi Pro LTE DS) XIAOMI-Redmi Note 2 Hermes (Note 2 LTE DS) XIAOMI-Redmi Note 3 Henessy (Note 3 LTE DS) XIAOMI-Redmi Note 4 Nikel (Note 4 LTE DS) XIAOMI-Redmi Pro Omega (Redmi Pro LTE DS) ACER-B3-A20 (Iconia One 10 WiFi) ACER-B3-A30 (Iconia One 10 WiFi) ACER-E39 (Liquid E700 3G TS) ACER-S53 (Liquid X1 3G) ACER-S55 (Liquid Jade 3G DS) ACER-S56 (Liquid Jade S LTE DS) ACER-S57 (Liquid Jade Z LTE DS) ACER-S59 (Liquid X2 LTE TS) ACER-T02 (Liquid Z530 LTE DS) ACER-T03 (Liquid Z630 LTE DS) ACER-T04 (Liquid Z630S LTE DS) ACER-T06 (Liquid Zest 3G DS) ACER-T07 (Liquid Zest 4G LTE DS) ACER-T08 (Liquid Zest Plus LTE DS) ACER-T10 (Liquid Z6E 3G DS) ACER-Z130 (Liquid Z3 3G DS) ACER-Z150 (Liquid Z5 3G DS) ACER-Z160 (Liquid Z4 3G DS) ACER-Z200 (Liquid Z7 3G DS) ACER-Z205 (Liquid Z7 3G DS) ACER-Z410 (Liquid Z410 LTE) ACER-Z500 (Liquid Z500 3G DS) ACER-Z520 (Liquid Z520 3G) ACER-Z520-DS (Liquid Z520 3G DS) ARCHOS-101 Copper (101 Copper 3G) ARCHOS-101 Core (101 Core 3G) ARCHOS-101 Platinum (101 Platinum 3G) ARCHOS-101B Copper (101B Copper 3G) ARCHOS-101B Helium (101B Helium LTE DS) ARCHOS-101B Xenon (101B Xenon LTE DS) ARCHOS-101E Neon (101E Neon WiFi) ARCHOS-40 Titanium (40 Titanium 3G DS) ARCHOS-40C Titanium (40C Titanium 3G DS) ARCHOS-45 Titanium (45 Titanium 3G DS) ARCHOS-50 Helium Plus (50 Helium Plus LTE DS) ARCHOS-50 Oxygen Plus (50 Oxygen Plus 3G DS) ARCHOS-50 Power (50 Power LTE DS) ARCHOS-50 Saphir (50 Saphir LTE DS) ARCHOS-50B Platinum (50B Platinum 3G DS) ARCHOS-50C Helium (50C Helium LTE DS) ARCHOS-50E Neon (50E Neon 3G DS) ARCHOS-50F Neon (50F Neon 3G DS) ARCHOS-55 Graphite (55 Graphite LTE DS) ARCHOS-55 Helium (55 Helium LTE DS) ARCHOS-55 Helium Plus (55 Helium Plus LTE DS) ARCHOS-60 Platinum (60 Platinum 3G DS) ARCHOS-62 Xenon (62 Xenon 3G DS) ARCHOS-70 Platinum (70 Platinum 3G DS) ARCHOS-80B Xenon (80B Xenon 3G DS) ARCHOS-Diamond Plus (Diamond Plus LTE DS) ARCHOS-Sense 50DC (Sense 50DC LTE DS) BLU-A010L (Advance 4.0 3G DS) BLU-A010U (Advance 4.0 3G DS) BLU-A030L (Advance 4.0 L2 3G DS) BLU-A050U (Advance 5.0 HD 3G DS) BLU-A150Q (Studio J2 3G DS) BLU-C0010LL (CX5 LTE DS) BLU-C010Q (C5 3G DS) BLU-D0030UU (Dash X Plus LTE DS) BLU-D030UX (Advance 5.0 3G DS) BLU-D050 (Dash L 3G DS) BLU-D090L (Dash M2 3G DS) BLU-D090U (Dash M2 3G DS) BLU-D110L (Dash X2 3G DS) BLU-D110U (Dash X2 3G DS) BLU-D210L (Diamond M 3G DS) BLU-D410A (Dash 5.0 3G DS) BLU-D410Ai (Dash 5.0 3G DS) BLU-D522U (Studio 5.0 II 3G DS) BLU-D530E (Studio 5.0 E 3G DS) BLU-D532L (Studio 5.0 II 3G DS) BLU-D532U (Studio 5.0 II 3G DS) BLU-D534L (Studio 5.0 C HD 3G DS) BLU-D534U (Studio 5.0 C HD 3G DS) BLU-D535U (Studio 5.0 C HD 3G DS) BLU-D536L (Studio 5.0 C 3G DS) BLU-D536U (Studio 5.0 C 3G DS) BLU-D572A (Studio 5.0 S II 3G DS) BLU-D650Ai (Studio 6.0 3G DS) BLU-D651 (Studio 6.0 3G DS) BLU-D670L (Studio 5.0 C Mini 3G DS) BLU-D670U (Studio 5.0 C Mini 3G DS) BLU-D710 (Dash XL 3G DS) BLU-D830L (Studio C 3G DS) BLU-D830U (Studio C 3G DS) BLU-D890L (Studio C5+5 3G DS) BLU-D890U (Studio C5+5 3G DS) BLU-E0010UU (Energy X LTE DS) BLU-E0030UU (Energy XL LTE DS) BLU-E050L (Energy X2 3G DS) BLU-E050U (Energy X2 3G DS) BLU-E090 (Energy Diamond Mini 3G DS) BLU-E110 (Energy M 3G DS) BLU-E150Q (Energy X Plus 3G DS) BLU-G0010JJ (Grand X LTE DS) BLU-G0010WW (Grand X LTE DS) BLU-G0030 (Grand XL LTE DS) BLU-G030L (Grand 5.5 HD 3G DS) BLU-G030U (Grand 5.5 HD 3G DS) BLU-G070 (Grand M 3G DS) BLU-G130 (Grand Energy 3G DS) BLU-G150 (Grand XL 3G DS) BLU-G170Q (Grand Mini 3G DS) BLU-L0030EE (Life Mark LTE DS) BLU-L0110UU (Life Max LTE DS) BLU-L180 (Life Play Mini 3G) BLU-L190 (Life Play Mini 3G DS) BLU-L280 (Life 8 3G DS) BLU-M12 (M12 LTE DS) BLU-N0010UU (Neo X LTE DS) BLU-N00110UU (Neo X LTE DS) BLU-N070 (Neo X 3G DS) BLU-N110U (Neo XL 3G DS) BLU-N130 (Neo Energy Mini 3G DS) BLU-N130U (Neo Energy Mini 3G DS) BLU-N150 (Neo X Mini 3G DS) BLU-P0010UU (Life Pure XL LTE DS) BLU-P0030UU (Life Pure XR LTE DS) BLU-R0010UU (R1 HD LTE DS) BLU-R0011UU (R1 HD LTE DS) BLU-R0030UU (R1 HD LTE DS) BLU-R0031UU (R1 HD LTE DS) BLU-R0051UU (R1 Plus LTE DS) BLU-R010P (R2 3G DS) BLU-R0110 (J2 LTE DS) BLU-R0150EE (R2 LTE DS) BLU-R0170WW (R2 LTE DS) BLU-R0190WW (R2 Plus LTE DS) BLU-S0090UU (Studio Energy 2 LTE DS) BLU-S010Q (Studio G2 3G DS) BLU-S0110EE (Studio One LTE DS) BLU-S0110UU (Studio One LTE DS) BLU-S0130UU (Studio One Plus LTE DS) BLU-S0150UU (Studio X Mini LTE DS) BLU-S0151UU (Studio X Mini LTE DS) BLU-S0170UU (Studio C8+8 LTE DS) BLU-S0210UU (Studio Touch LTE DS) BLU-S0230EE (Studio M LTE DS) BLU-S0230UU (Studio M LTE DS) BLU-S0250UU (Studio G HD LTE DS) BLU-S0290UU (Studio J5 LTE DS) BLU-S270Q (Studio C8+8 3G DS) BLU-S390U (Studio X5 3G DS) BLU-S500Q (Studio G Plus 3G DS) BLU-S510 (Studio G Plus 3G DS) BLU-S550Q (Studio G2 HD 3G DS) BLU-S530 (Studio X8 HD 3G DS) BLU-S610P (Studio Mega 3G DS) BLU-S710U (Studio M5 Plus 3G DS) BLU-S730P (Studio M6 Plus 3G DS) BLU-S750P (Studio Pro 3G DS) BLU-S810 (Studio View 3G DS) BLU-T0010UU (Tank Extreme Pro LTE DS) BLU-V0030UU (Vivo XL LTE DS) BLU-V0050UU (Vivo 5 LTE DS) BLU-V0070EE (Vivo XL2 LTE DS) BLU-V0070UU (Vivo XL2 LTE DS) BLU-V0090EE (Vivo 5R LTE DS) BLU-V0090UU (Vivo 5R LTE DS) BLU-V0110EE (Vivo 6 LTE DS) BLU-V0110UU (Vivo 6 LTE DS) BLU-V0150UU (Vivo 8 LTE DS) BLU-V0290WW (Vivo One Plus LTE DS) BLU-V050 (Vivo 5 Mini 3G DS) INFINIX-X5010-AW878 (X5010 3G DS) INFINIX-X503-L3378 (Surf Bravo 3G DS) INFINIX-X506-J608 (Zero 3G) INFINIX-X507-D5120 (Hot 3G DS) INFINIX-X509-J5800 (Zero 2 3G DS) INFINIX-X509-J5808 (Zero 2 LTE DS) INFINIX-X510-D5110 (Hot 2 3G DS) INFINIX-X510-D5116 (Hot 2 LTE DS) INFINIX-X521-J5086-H1 (Hot S Pro LTE DS) INFINIX-X521-J5088-A1 (Hot S LTE DS) INFINIX-X521-J5088-C1 (Hot S LTE DS) INFINIX-X521-J5088-E1 (Hot S LTE DS) INFINIX-X521-J5088-G1 (Hot S LTE DS) INFINIX-X521-J5088-I1 (Hot S LTE DS) INFINIX-X522-H539-A (S2 LTE DS) INFINIX-X551-G808-A1 (Hot Note 3G DS) INFINIX-X551-G808-B1 (Hot Note 3G DS) INFINIX-X551-G808-BC (Hot Note 3G DS) INFINIX-X551-G808-D1 (Hot Note 3G DS) INFINIX-X5511-H3716-B1 (Hot 4 Pro LTE DS) INFINIX-X552-H952-A1 (Zero 3 LTE DS) INFINIX-X552-H952-B1 (Zero 3 LTE DS) INFINIX-X552-H952-C1 (Zero 3 LTE DS) INFINIX-X554-T90918-A1 (Hot 3 3G DS) INFINIX-X554-T90918-A2 (Hot 3 3G DS) INFINIX-X555-H538-A1 (Zero 4 LTE DS) INFINIX-X555-H538-B1 (Zero 4 LTE DS) INFINIX-X556-H371-A1 (Hot 4 Pro LTE DS) INFINIX-X557-H807-A1 (Hot 4 3G DS) INFINIX-X557-H807-B1 (Hot 4 3G DS) INFINIX-X557-H807-D1 (Hot 4 3G DS) INFINIX-X557-H807-F1 (Hot 4 3G DS) INFINIX-X557-H807-G1 (Hot 4 3G DS) INFINIX-X559-H8015-A1 (Hot 5 Lite 3G DS) INFINIX-X559-H8015-B1 (Hot 5 Lite 3G DS) INFINIX-X559-H8015-C1 (Hot 5 3G DS) INFINIX-X571-H5311-A1 (Note 4 Pro LTE DS) INFINIX-X572-H5312-A1 (Note 4 LTE DS) INFINIX-X572-H5312-C1 (Note 4 LTE DS) INFINIX-X600-H532-A1 (Note 2 LTE DS) INFINIX-X600-H533-A1 (Note 2 LTE DS) INFINIX-X601-H536-A1 (Note 3 LTE DS) INFINIX-X601-H537-A1 (Note 3 Pro LTE DS) INFINIX-X601-H537-B1 (Note 3 Pro LTE DS) INFINIX-X603-H575-A (Zero 5 LTE DS) INFINIX-X602-H972-A1 (Zero 4 Plus LTE DS) INFINIX-X602-H972-C1 (Zero 4 Plus LTE DS) Condor A8 (PGN-611) Condor A8 Plus (PGN-612) Condor A55 (PGN-606) Condor A55 Plus (PGN-613) Condor A55 Slim (PGN-608) Condor A100 (PGN-607) Condor A100 Lite (PGN-609) Condor G4 (PGN-513) Condor G4 Plus (PGN-521) Condor G5 Plus (PAM-524) Condor L1 (SP-622) Condor M1 (SP-614) Condor M1 Plus (SP-615) Condor M2 (SP-617) Condor P4 (PGN-409) Condor P4 Plus (PGN-527) Condor P4 Pro (PGN-515) Condor P5 (PGN-516) Condor P6 (PGN-517) Condor P6 Plus (PGN-522) Condor P6 Pro (PGN-518) Condor P6 Pro LTE (PGN-528) Condor P7 (PGN-514) Condor P7 Plus (PGN-523) Condor P8 (PGN-605) Condor P8 Lite (PGN-610) Condor TFX-711G Condor TFX-712G Condor TFX-713L Condor TFX-714L Condor TGW-102L Condor TGW710G Condor TGW-801G Condor TGW-801L Condor TMK-715L INTEX-Aqua 3G (Aqua 3G 3G DS) INTEX-Aqua 3G Mini (Aqua 3G Mini 3G DS) INTEX-Aqua 3X (Aqua 3X 3G DS) INTEX-Aqua 4G+ (Aqua 4G+ LTE DS) INTEX-Aqua 4G Strong (Aqua 4G Strong LTE DS) INTEX-Aqua 4X (Aqua 4X 3G DS) INTEX-Aqua 55VR (Aqua 5.5 VR LTE DS) INTEX-Aqua 55VR+ (Aqua 5.5 VR+ LTE DS) INTEX-Aqua 5X (Aqua 5X 3G DS) INTEX-Aqua A1 (Aqua A1 3G DS) INTEX-Aqua Ace (Aqua Ace LTE DS) INTEX-Aqua Ace 2 (Aqua Ace 2 LTE DS) INTEX-Aqua Ace Mini (Aqua Ace Mini LTE DS) INTEX-Aqua Air (Aqua Air 3G DS) INTEX-Aqua Air 2 (Aqua Air 2 3G DS) INTEX-Aqua Amaze (Aqua Amaze 3G DS) INTEX-Aqua Amoled (Aqua Amoled 3G DS) INTEX-Aqua Craze (Aqua Craze LTE DS) INTEX-Aqua Crystal (Aqua Crystal LTE DS) INTEX-Aqua Crystal+ (Aqua Crystal+ LTE DS) INTEX-Aqua Curve (Aqua Curve 3G DS) INTEX-Aqua Curve Mini (Aqua Curve Mini 3G DS) INTEX-Aqua Desire (Aqua Desire 3G DS) INTEX-Aqua Desire HD (Aqua Desire HD 3G DS) INTEX-Aqua Dream (Aqua Dream 3G DS) INTEX-Aqua Freedom (Aqua Freedom 3G DS) INTEX-Aqua Glam (Aqua Glam 3G DS) INTEX-Aqua HD (Aqua HD 3G DS) INTEX-Aqua HD 5.0 (Aqua HD 5.0 3G DS) INTEX-Aqua HD 5.5 (Aqua HD 5.5 3G DS) INTEX-Aqua i14 (Aqua i14 3G DS) INTEX-Aqua i15 (Aqua i15 3G DS) INTEX-Aqua i2 (Aqua i2 3G DS) INTEX-Aqua i3K (Aqua i3K 3G DS) INTEX-Aqua i4 (Aqua i4 3G DS) INTEX-Aqua i4+ (Aqua i4+ 3G DS) INTEX-Aqua i5 (Aqua i5 3G DS) INTEX-Aqua i5 HD (Aqua i5 HD 3G DS) INTEX-Aqua i5 Mini (Aqua i5 Mini 3G DS) INTEX-Aqua i5 Octa (Aqua i5 Octa 3G DS) INTEX-Aqua i6 (Aqua i6 3G DS) INTEX-Aqua i7 (Aqua i7 3G DS) INTEX-Aqua Irist (Aqua Irist 3G DS) INTEX-Aqua KAT (Aqua KAT 3G DS) INTEX-Aqua Life (Aqua Life 3G DS) INTEX-Aqua Lions 3 (Aqua Lions 3 LTE DS) INTEX-Aqua Lions N1 (Aqua Lions N1 LTE DS) INTEX-Aqua Lions X1 (Aqua Lions X1 LTE DS) INTEX-Aqua Lions X1+ (Aqua Lions X1+ LTE DS) INTEX-Aqua M5 (Aqua M5 3G DS) INTEX-Aqua Music (Aqua Music LTE DS) INTEX-Aqua N15 (Aqua N15 3G DS) INTEX-Aqua N17 (Aqua N17 3G DS) INTEX-Aqua N2 (Aqua N2 3G DS) INTEX-Aqua N4 (Aqua N4 3G DS) INTEX-Aqua N8 (Aqua N8 3G DS) INTEX-Aqua Note55 (Aqua Note 5.5 LTE DS) INTEX-Aqua Octa (Aqua Octa 3G DS) INTEX-Aqua Play (Aqua Play 3G DS) INTEX-Aqua Power (Aqua Power 3G DS) INTEX-Aqua Power+ (Aqua Power+ 3G DS) INTEX-Aqua Power HD (Aqua Power HD 3G DS) INTEX-Aqua Power IV (Aqua Power IV LTE DS) INTEX-Aqua Power M (Aqua Power M 3G DS) INTEX-Aqua Power Pro (Aqua Power Pro 3G DS) INTEX-Aqua Pride (Aqua Pride 3G DS) INTEX-Aqua Prime 4G (Aqua Prime 4G LTE DS) INTEX-Aqua Raze (Aqua Raze LTE DS) INTEX-Aqua Retscan (Aqua Retscan LTE DS) INTEX-Aqua Ring (Aqua Ring 3G DS) INTEX-Aqua S1 (Aqua S1 LTE DS) INTEX-Aqua S7 (Aqua S7 LTE DS) INTEX-Aqua S9 (Aqua S9 LTE DS) INTEX-Aqua S9 Pro (Aqua S9 Pro LTE DS) INTEX-Aqua Secure (Aqua Secure LTE DS) INTEX-Aqua Shine 4G (Aqua Shine 4G LTE DS) INTEX-Aqua Slice (Aqua Slice 3G DS) INTEX-Aqua Speed (Aqua Speed 3G DS) INTEX-Aqua Speed HD (Aqua Speed HD 3G DS) INTEX-Aqua Star 4G (Aqua Star 4G LTE DS) INTEX-Aqua Star HD (Aqua Star HD 3G DS) INTEX-Aqua Star L (Aqua Star L 3G DS) INTEX-Aqua Star Power (Aqua Star Power 3G DS) INTEX-Aqua Strong 5.1 (Aqua Strong 5.1 LTE DS) INTEX-Aqua Strong 5.2 (Aqua Strong 5.2 LTE DS) INTEX-Aqua Style 4.0 (Aqua Style 4.0 3G DS) INTEX-Aqua Style Mini (Aqua Style Mini 3G DS) INTEX-Aqua Style X (Aqua Style X 3G DS) INTEX-Aqua Style VX (Aqua Style VX 3G DS) INTEX-Aqua Supreme+ (Aqua Supreme+ LTE DS) INTEX-Aqua T2 (Aqua T2 3G DS) INTEX-Aqua Trend (Aqua Trend LTE DS) INTEX-Aqua Trend Lite (Aqua Trend Lite LTE DS) INTEX-Aqua Turbo 4G (Aqua Turbo 4G LTE DS) INTEX-Aqua Twist (Aqua Twist 3G DS) INTEX-Aqua View (Aqua View LTE DS) INTEX-Aqua Wing (Aqua Wing LTE DS) INTEX-Aqua Wonder QC (Aqua Wonder QC 3G DS) INTEX-Aqua Xtreme (Aqua Xtreme 3G DS) INTEX-Aqua Xtreme 2 (Aqua Xtreme 2 3G DS) INTEX-Aqua Xtreme V (Aqua Xtreme V 3G DS) INTEX-Aqua Y2 (Aqua Y2 3G DS) INTEX-Aqua Y2 Pro (Aqua Y2 Pro 3G DS) INTEX-Aqua Y2 Remote (Aqua Y2 Remote 3G DS) INTEX-Aqua Y3 (Aqua Y3 3G DS) INTEX-Aqua Y4 (Aqua Y4 3G DS) INTEX-Aqua Zenith (Aqua Zenith LTE DS) INTEX-Cloud 4G Star (Cloud 4G Star LTE DS) INTEX-Cloud Breeze (Cloud Breeze 3G DS) INTEX-Cloud Champ (Cloud Champ 3G DS) INTEX-Cloud Crystal25D (Cloud Crystal 2.5D LTE DS) INTEX-Cloud Fame4G (Cloud Fame 4G LTE DS) INTEX-Cloud Flash (Cloud Flash LTE DS) INTEX-Cloud Gem+ (Cloud Gem+ 3G DS) INTEX-Cloud i9 (Cloud i9 3G DS) INTEX-Cloud Jewel (Cloud Jewel LTE DS) INTEX-Cloud N12 (Cloud N12 3G DS) INTEX-Cloud O3 (Cloud O3 LTE DS) INTEX-Cloud Pace (Cloud Pace 3G DS) INTEX-Cloud Power+ (Cloud Power+ 3G DS) INTEX-Cloud Q11 (Cloud Q11 3G DS) INTEX-Cloud Q11 4G (Cloud Q11 4G LTE DS) INTEX-Cloud S9 (Cloud S9 LTE DS) INTEX-Cloud Swift (Cloud Swift LTE DS) INTEX-Cloud Tread (Cloud Tread 3G DS) INTEX-Cloud X11 (Cloud X11 3G DS) INTEX-Cloud X3 (Cloud X3 3G DS) INTEX-Cloud X3+ (Cloud X3+ 3G DS) INTEX-Cloud X4 (Cloud X4 3G DS) INTEX-Cloud Y1 (Cloud Y1 3G DS) INTEX-Cloud Y10 (Cloud Y10 3G DS) INTEX-Cloud Y11 (Cloud Y11 3G DS) INTEX-Cloud Y12 (Cloud Y12 3G DS) INTEX-Cloud Y13 (Cloud Y13 3G DS) INTEX-Cloud Y13+ (Cloud Y13+ 3G DS) INTEX-Cloud Y17 (Cloud Y17 3G DS) INTEX-Cloud Y17+ (Cloud Y17+ 3G DS) INTEX-Cloud Y2 (Cloud Y2 3G DS) INTEX-Cloud Y3 (Cloud Y3 3G DS) INTEX-Cloud Y4+ (Cloud Y4+ 3G DS) INTEX-Cloud Y7 (Cloud Y7 3G DS) INTEX-Cloud X5 (Cloud X5 3G DS) INTEX-Elyt E6 (Elyt E6 LTE DS) INTEX-Elyt E7 (Elyt E7 LTE DS) INTEX-Elyt E8 (Elyt E8 3G DS) INTEX-JS Dubai (JS Dubai LTE DS) Samsung Repair Boot (Unbrick) Supported Devices : G935A G935P G935T G935V G930A G930P G930T G930V G955U2 G950U2 (FRP – Reset ScreenLock – CALL ME – SAMSUNG ACCOUNT – MDM ) on (FRP ON / OEM ON) supported devices : – G530FZ (Base: XXE1BQF1) – G531F (Base: XXE1AQF1) – G531H (Base: XXE0AQE1) – G532G (Base: DDE1ARB4) – G610F (Base: DXE1BRD1) – G610M (Base: UBE1BRB1) – G610Y (Base: ZTE1BRC3) – G611F (Base: DDE1ARD3) – G615FU (Base: DDE2ARB3) – G615F (Base: XXE2ARE1) – SM-C5000 (FRP:ON – CROM Lock:ON) – SM-C7000 (FRP:ON – CROM Lock:ON) – SM-C7100 (FRP:ON – CROM Lock:ON) – SM-G6100 7.0 (FRP:ON – CROM Lock:ON) – SM-G930V U4 (FRP:ON – OEM:ON) – SM-G930A U4 (FRP:ON – OEM:ON) – SM-G930T U4 (FRP:ON – OEM:ON) – SM-G930P U4 (FRP:ON – OEM:ON) – SM-J730F U2 (FRP:ON – OEM:ON) – SM-A320F U3 8.0 (FRP:ON – OEM:ON) – SM-A320FL U3 8.0 (FRP:ON – OEM:ON) – SM-A810F U1 7.0 (FRP:ON – OEM:ON) – SM-A910F U1 7.0 (FRP:ON – OEM:ON) – SM-A5108 U3 (FRP:ON – CROM Lock:ON) – SM-G5700 TGY 7.0 (FRP:ON – CROM Lock:ON) – SM-G6000 ZC U2 (FRP:ON – CROM Lock:ON) – SM-J530F U2 7.0 (FRP:ON – OEM:ON) – SM-J710F U5 (FRP:ON – OEM:ON) – SM-J5108 ALL (FRP:ON – CROM Lock:ON) – SM-G930F U2 8.0.0 (FRP:ON) – SM-G935F U2 8.0.0 (FRP:ON) – SM-G6100 ZH 7.0TGY – SM-G930V U4 – SM-G930A U4 – SM-G930T U4 – SM-G930P U4 – SM-J730F U2 – SM-A320F U3 8.0 – SM-A320FL U3 8.0 – SM-A810F U1 7.0 – SM-A910F U1 7.0 – SM-A5108 U3 – SM-G5700 TGY 7.0 – SM-G6000 ZC U2 – SM-J530F U2 7.0 – SM-J710F U5 – SM-J5108 ALL – SM-G930F U2 8.0.0 – SM-G935F U2 8.0.0 – SM-A510S U1 7.0 – SM-A710S U1 7.0 – SM-A810S U2 7.0 – SM-C7000 ZHE3BRG1 – SM-G532F U1 – SM-G610S U1 – SM-G920A 6.0.1 – SM-G920S U3 7.0 – SM-G925V U4 6.0.1 – SM-G928V U3 7.0 – SM-G930S U1 8.0.0 – SM-G935S U1 8.0.0 – SM-J510S U1 7.0 – SM-N920T U4 7.0 – SM-N920S U2 7.0 – SM-C7000 ZC – SM-C5000 ZC – SM-C7100 ZC – SM-G5700 ZC 7.0 – SM-A510S U1 7.0 – SM-A710S U1 7.0 – SM-A810S U2 7.0 – SM-C7000 ZHE3BRG1 – SM-G532F U1 – SM-G610S U1 – SM-G920A 6.0.1 – SM-G920S U3 7.0 – SM-G925V U4 6.0.1 – SM-G928V U3 7.0 – SM-G930S U1 8.0.0 – SM-G935S U1 8.0.0 – SM-J510S U1 7.0 – SM-N920T U4 7.0 – SM-N920S U2 7.0 – SM-C7000 ZC – SM-C5000 ZC – SM-C7100 ZC – SM-G5700 ZC 7.0 |
eft dongle price ................ |
EFT Dongle Price.........????? |
Welcome To Easy Firmware Team :) Can We Access free From this Dongle To Your Site Easy Firmware ? can We use your Site From this Dongle As a Support Site ? |
easy-team @ v r interested good luck team , i agree Akhtar Ali Jatt We Access free From this Dongle To Your Site Easy Firmware ? |
srinibas please appreciate and suport now i can trust sir you are 1 person asking not belive in this dongle Very Nyc please add online firmware donwload and MTK Bootloader unlock add we also need this feature |
BR, Mohamed Aamri |
BR, Mohamed Aamri |
BR, Mohamed Aamri |
re |
sir htc latest phone S-OFF &SUPER CID possible |
supoprt will be added for HTC Samsung and Lg and lot of more gpg is our Resller only Some changes will be made Soon |
My dongle is not For one Year it will Still continue until its not change your Mind |
Warm welcome in gsm forum wbr the mobile shop |
very nice welcome team and congratulation best luck |
