01-13-2021, 11:48 | #528 (permalink) |
No Life Poster Join Date: Jun 2013 Location: BANGLADESH+UAE Age: 34
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | iPhone X GSM Version: 14.3 Bypass iCloud at Hello Screen Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.62.3 Device IMEI: 359407xxxxxxxx Product Name: iPhone OS Product Type: iPhone X GSM IOS Version: 14.3 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: DNPxxxxxxxxx MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 1E480CCF2BE94C7F Elapsed time 00:48 -- Version 3.7.2 |
01-13-2021, 15:00 | #529 (permalink) |
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | iPhone 6s Version: 14.3 Bypass iCloud at Hello Screen Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Activated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.62.3 Device IMEI: 35542907xxxxx Device MEID: 355429xxxxxx Product Name: iPhone OS Product Type: iPhone 6s IOS Version: 14.3 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: FK2QNWxxxxx MEID Status: Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: ED890755C6DD3915 Elapsed time 00:54 -- Version 3.7.2 |
01-14-2021, 11:55 | #530 (permalink) |
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | iPhone 6 Plus Version: 12.5.1 Bypass iCloud at Hello Screen Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-4513.270.14 Device IMEI: 3543830624xxxxx Device MEID: 354383062xxxxx Product Name: iPhone OS Product Type: iPhone 6 Plus IOS Version: 12.5.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: FK1NHLxxxxx MEID Status: Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: C8B00A06B03DA994 Elapsed time 01:04 -- Version 3.7.2 |
01-14-2021, 22:07 | #531 (permalink) |
No Life Poster Join Date: Jan 2004 Location: State 51 Of Russia Age: 48
Member: 48815 Status: Offline Sonork: 100.1581608 Thanks Meter: 422 | Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-4513.270.14 Device IMEI: 35567207XXXXXXX Product Name: iPhone OS Product Type: iPhone 5S (Global) IOS Version: 12.5.1 SIM Status: kCTSIMSupportSIMStatusReady Device Serial Number: DX5RDXXXXXX MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 6CA6E1F9F1339C00 Elapsed time 01:01 -- Version 3.7.2 But call failed issue. And after reboot - still ask activation. Whats wrong? |
The Following User Says Thank You to hELLISh For This Useful Post: |
01-19-2021, 12:10 | #532 (permalink) |
Insane Poster Join Date: Feb 2009
Member: 966403 Status: Offline Thanks Meter: 5 | You need to enable pin lock on whatever sim you will use.leave the sim inside. when you enter the sim pin it will skip activation. you will need to enter sim pin every-time you power off or reboot. |
01-20-2021, 13:57 | #533 (permalink) |
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | iPad mini Retina (WiFi) Bypass iCloud at Hello Screen Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPad Device Name: iPad Firmware Version: iBoot-4513.270.14 Product Name: iPhone OS Product Type: iPad mini Retina (WiFi) IOS Version: 12.5.1 Device Serial Number: F9FRK4Zxxxxx MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 5997552D0E527341 Elapsed time 00:53 -- Version 3.7.2 |
01-20-2021, 15:59 | #534 (permalink) |
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | iPad Air 2 (WiFi) Bypass iCloud at Hello Screen Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPad Device Name: iPad Firmware Version: iBoot-6723.42.3 Product Name: iPhone OS Product Type: iPad Air 2 (WiFi) IOS Version: 14.2 Device Serial Number: DLXNR4TSxxxx MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 737EAA9C43945FC6 Elapsed time 00:39 -- Version 3.7.2 |
01-23-2021, 12:00 | #537 (permalink) |
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | iPad Pro (9.7 inch Bypass iCloud at Hello Screen Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPad Device Name: iPad Firmware Version: iBoot-6723.62.3 Product Name: iPhone OS Product Type: iPad Pro (9.7 inch IOS Version: 14.3 Device Serial Number: DMPRR0D1xxxx MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 411450CA8544A6CB Elapsed time 00:51 -- Version 3.8.0 |
01-23-2021, 12:56 | #538 (permalink) |
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | iPhone 5S (Global) Bypass iCloud at Hello Screen Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-4513.270.14 Device IMEI: 35876105497xxxx Product Name: iPhone OS Product Type: iPhone 5S (Global) IOS Version: 12.5.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F2LLK491xxxx MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: EC0838FD4FE90F10 Elapsed time 00:55 -- Version 3.8.0 |
01-25-2021, 11:25 | #539 (permalink) |
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-4513.270.14xxxxxxx 761054972430 Product Name: iPhone OS Product Type: iPhone 5S (Global) IOS Version: 12.5.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: xxxxxxxxx MEID Status: Not Supported Preparing.....OK Bypassing.....OK Operation {Bypass iCloud at Hello Screen} ID: 03991D414A40043F Elapsed time 01:00 -- Version 3.8.1 |
01-26-2021, 07:57 | #540 (permalink) | |
Junior Member Join Date: Nov 2009
Member: 1170617 Status: Offline Thanks Meter: 3 | Quote:
After bypass, is it work with SIM Service bro ? Sent from my iPhone using Tapatalk | |
