10-21-2020, 23:34 | #181 (permalink) | |
Junior Member Join Date: Sep 2009 Location: Mexico
Member: 1112912 Status: Offline Sonork: 1112912 Thanks Meter: 0 | Quote:
Same problem Product Type: iPhone 6 Plus IOS Version: 12.4.8 SIM Status: kCTSIMSupportSIMStatusPINLocked Device Serial Number: C39PWMAQG5QH MEID Status: Not Supported Preparing.....OK Bypassing.....Error: Connection Exception, Please be sure from JailBreaking Your iDeviceFailed to create activation request. | |
10-22-2020, 00:43 | #182 (permalink) |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | Preparing paths.....OK Setting up.....OK Checking iDevices.....Error: No devices found, Please connect you iDevice to this PC Operation {Bypass iCloud at Hello Screen} ID: 2F5794C2219F9B09 Elapsed time 00:01 -- Version 3.5.0 any help the deice have jailbreak |
The Following 2 Users Say Thank You to daryl007 For This Useful Post: |
10-22-2020, 04:36 | #186 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: pakistan Age: 39
Member: 1789762 Status: Offline Sonork: 1612770 Thanks Meter: 51 | Quote:
Checking iDevices.....Error: No devices found, Please connect you iDevice to this PC Operation {Read iDevice Info} ID: 6879101EAC1A9667 Elapsed time 00:01 -- Version 3.5.0 | |
10-22-2020, 06:57 | #189 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Iran
Member: 299773 Status: Offline Thanks Meter: 14 | Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.11.41 Device IMEI: 35************ Device MEID: 35************ Product Name: iPhone OS Product Type: iPhone SE (GSM) IOS Version: 14.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F17RVNSNH2XL MEID Status: Supported Preparing.....OK Bypassing.....Error: Exception, Please be sure from JailBreaking Your iDeviceError connecting to device! Operation {Bypass iCloud at Hello Screen} ID: 052F91013FE2EFCF Elapsed time 00:04 -- Version 3.5.0 ?????????????????????? |
10-22-2020, 07:48 | #192 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | 7 plus done with network thanks eft team |
The Following User Says Thank You to pintu_das For This Useful Post: |
10-22-2020, 08:11 | #193 (permalink) |
Freak Poster Join Date: Jan 2009 Location: RAWALPINDI Age: 40
Member: 951666 Status: Offline Thanks Meter: 64 | Preparing paths.....OK Setting up.....OK Checking iDevices.....Error: No devices found, Please connect you iDevice to this PC Operation {Read iDevice Info} ID: A3E0F729B1ADF7C9 Elapsed time 00:02 -- Version 3.5.0 how to solve this issue ??? |
10-22-2020, 08:13 | #194 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Requirements For { Bypass iCloud at Hello Screen (Normal Mode) }: - JailBreak your IOS device -- If your Device has MEID enabled: --- The bypass will be without GSM Network --- Put SIM Card with PIN into the device - Connect it to PC using usb cable - Wait until the device appears on PC then press Start read this message |
10-22-2020, 08:14 | #195 (permalink) |
No Life Poster Join Date: May 2007 Location: INDIA
Member: 511749 Status: Offline Thanks Meter: 335 | EFT IPhone Bypass On Error ??? Preparing paths.....OK Setting up.....OK Checking iDevices.....Error: No devices found, Please connect you iDevice to this PC Operation {Bypass iCloud at Hello Screen} ID: D1A5DF9A1BE971D4 Elapsed time 00:00 -- Version 3.5.0 |
