Old 10-22-2017, 20:31   #1 (permalink)
Thanks Meter: 21,699
EFT Dongle UserGuide From Registration to Professionalism
Hello,
-We will explain in this User Guide :
How To Register your EFT Dongle
How To USE it
-We will explain every tab in detail
-We will explain every button .
-Here will be just a simple explanation.
-If we miss something then kindly just ask about it !
-You can use Private Messages or our Facebook page HERE
The Following 5 Users Say Thank You to easy-team For This Useful Post:
Old 10-22-2017, 20:45   #2 (permalink)
Download and Registration Stage
First
Download the Dongle Software
Software + Hardware Setup
From here
First, We install the Hardware software and then the Software
Here is a list of programs necessary to run the dongle
1-Net.frame work 4.5 or above
2-Java
3-Visual C ++ Redistributable
After you have finished installing all programs
Open the dongle program
And then press on
Click to REGISTER
Then enter ur e-mail
Then a user name of our choice
Then a strong password
Note: Do not place these characters in the password! @ # $%? ^ & *) (_ +
It will not work and you'll have trouble signing in.
Then press on
Complete Registration
A word will appear
Successful
Now the registration has been completed
We return and enter our data
Then tick
Save
Then click on
Check Account
A word appears to us
Connected (online)
(Here we can switch between hardware and software interface)
Through the list
UI
Then press
Login
Follow the contact meter from 1 to 20
Within 20 seconds the program opens
Thus we have Successfully finished installation and Opening Software for the first time
To be continued ...
The Following 6 Users Say Thank You to easy-team For This Useful Post:
Old 10-22-2017, 20:57   #3 (permalink)
Stage Two
Interfaces Explanation
Android Kitchen
This section contains many tabs that we will explain One by one !
1. Translate
2. Manual Translate Settings
3. Dictionary Maker
4. Fix Android
5. Mod
6. Features
7. Options
-Translate-
This interface contains four tabs and will be explained separately
1-One Click
2-Translate
3-Translate Multi Language
4-More
To be continued ...
The Following 2 Users Say Thank You to easy-team For This Useful Post:
Old 10-22-2017, 21:08   #4 (permalink)
One Click Interface
The translation interface and the automatic addition of languages with one click
Supports all types of android devices
With root or without root
Root for all versions of Android 4 and above
Without Root FOR LOCKED Bootloader devices From version 6 and above
Also we can Use it with Unlocked Bootloader devices!
The status of the device is recognized if it is Rooted or not automatically!
The steps of the addition of any language is very simple
First
We connect the phone after activating the debugging mode
Second
Press
Third
Press
Now after phone is connected
We choose the desired language to be added
Then we Press
Now all applications will be shown
we Select them all by using CTRL+A or mouse
Then we Press
The operation may take 15 to 20 minutes
We have to wait
The phone will reboot more than once and this is not a concern
When those words appear
The required language has been added and we can safely remove the phone
You can add your name or domain name through this window before you start translating
To be continued ...
Old 10-22-2017, 21:26   #5 (permalink)
Translate
Interface Add languages manually
You can dispense with it because there is an interface to add languages automatically
But we will explain its mechanism
In addition to some tabs contained and their functions !
1- The function of this option is to close all ADB servers if you face any problem connecting your phone in adb mode!
2-To root some old Samsung devices using adb mode!
3-Reboot device .
4-Read phone applications to add language
5-Read all phone apps including System apps .
6-Read more oof system apps.
7-We choose to search for a particular application
8-After choosing 7 , we write app name and click here.
9-System patch so you will not face any problem after formatting the device !
This tab contains some fixes
Fix of Contacts has stopped !
Fix of TouchWizHome has stopped!
This tab is needed in manual translation methods
By pressing the
R
Then use the drop-down menu
For example, there are more than one dictionary for each language
Arabic has three dictionaries
To be continued ...
The Following 3 Users Say Thank You to easy-team For This Useful Post:
Old 10-22-2017, 22:15   #6 (permalink)
Interface Add more than one language manually
By selecting the language in the menu
Language
And a dictionary matching the language
Dictionary
and framwork identical to the language
Then press on
ADD
In the previous picture we added Arabic and Turkish
Note that all three options are identical and contain Turkish
The same method is used to add any other language
After you finish adding the languages press
For the two options
If you do not have a phone and you have apps you want to localize
You can localize through this option any application without a phone
To be continued ...
The Following User Says Thank You to easy-team For This Useful Post:
Old 10-22-2017, 22:36   #7 (permalink)
More
An option to read folder names containing multiple applications and localize or translate them into any language
Such as Google or Samsung Folders !
This interface is used to decompile files
APK
Modify them and then recompile them
In addition to translating and adding languages to files
APK
individually
There is also an option to install applications in the root of the system so that they are not deleted after formatting
All operations in this interface need the phone to be rooted
1-Connect phone in adb mode and click this option to install framework file so the Dongle can decompile the apk files .
2-The same as first option but in this one framework file installed from PC not phone
3-decompile the application
4-recompile the application
5-Sign the apk after editing to let the phone accept it .
6-zipalign apk to make it work faster
7-Used to translate any xml file from one language to another( it can be found at Values folder)
8-To choose where to install apk
To be continued ...
Old 10-22-2017, 22:49   #8 (permalink)
Dictionary Maker
1-to get apk files
2-to reset work screen
3-to choose which language to be pulled from apk
4-to add pulled language to Dongle Dictionary
5-to add name to your choosen language
6-Delete choosen languages
7-to staet pulling languages
to be continued ...
Old 10-22-2017, 23:09   #9 (permalink)
Fix Android
1- to fix Wifi losing password after adding languages
2- to add mobile data on/off in notification panel
3- To delete Knox protection on the User Data from some devices
4- Add Farsi to Samsung Keyboard
5- Add Arabic for Samsung Keyboard
6- Fixing the Contacts stopped in Samsung DoCoMo devices for Japan
7- T - Mobile logo Remover from Samsung S-5
8- Show hidden languages ​​in Samsung devices (need root)
9- Show languages ​​in HTC phones
10- TouchWizHome Repair has stopped (method 1)
11- TouchWizHome Repair has stopped (method 2)
12- 4G Network Repair
13- Show hidden menu on Samsung devices
14- Fix the problem of reboot after root
15- Install Morlocale application to show languages
16- Show hidden languages ​​in Sony devices
17- Install Contacts application
18- HTC Show all languages ​​in Keyboard devices
19- Fix of the phone does not read the names of the SIM card and is not moving them from/and to the phone
20- (not safe) HTC Show hidden languages ​​in devices
21- Resolving a problem Contacts stopped or disappeared Method 1
22- Resolving a problem Contacts stopped or disappeared Method 2
23- Resolving a problem Contacts stopped or disappeared Method 3
24- Button Perform any operation selected in the previous options
to be continued ...
Old 10-22-2017, 23:44   #10 (permalink)
Mod
Here in this tab we can install the Google app package and change the boot logo in Samsung Devices and modify the keyboard
Each will be explained separately
Gapps Installer
Logo / Keyboard
Gapps Installer
1-To provide more space in the system where there must be at least 200 MB to install Google packages
(please note that if the package is not installed then free memory in the system less than 200 megabytes) and must free additional space !
2- show Gapps version info
3- start download and install Gapps package
4- show phone version info
5- to refresh where to install zip file
6- to choose where to install zip file
7- to choose zip file
8- to start the operation
Logo/Keyboard
1- To pull the logo file from the device ( does not need root)
2- To read the files already pulled out from the devices
3- To flash pulled out logo to any device and needs root
4- To read phone information (About phone)
5- To modify the information and then save it
6- To pull the keyboard out of the Device
7- To read the captured keyboard files
8- To flash the keyboard on the device
to be continued ...
Old 10-23-2017, 21:26   #11 (permalink)
Features
1- To activate a number of features
2- Tick if you want to remove all notifications (not safe)
3- Suspension of notification (sending security reports)
4- Stop notification (this SIM is not supported)
5- Stop notification (update security policy for device)
To be continued ...
Old 10-23-2017, 21:30   #12 (permalink)
Android Model
This interface includes 9 tabs that will be explained separately
Which are:
Samsung
HTC
Huawei
MTK Beta
LG
Moto Flasher
Qualcomm Flasher
Asus
Fastboot
Samsung
The Samsung interface contains 5 tabs
EFT
Flash
Make Root
Make Kernel
Repair
Old 10-23-2017, 21:39   #13 (permalink)
EFT
1- To delete a Google account by formating the user profile sector (USER Data) (The device model must be selected. In this way the phone boot to the desktop but must go to the developer mode and unlock the manufacturer of the equipment so that the FRP is not locked again after format or flash !)
2- To delete a Google account (does not need to choose the phone model)
The method was successful on some old Binaries
3- to get Pit file from device.
4- To reset counter of Knox (first method)
5- To reset counter of Knox(second method)
6- Flash boot.eft / img
7- Browse boot.eft / img
8- Switch between file types eft / img
To be continured ...
Old 10-23-2017, 21:43   #14 (permalink)
Flash
Samsung Flashing Interface (Beta)
1- Boot-Loader
2- System file
3- Modem file
4- CSC file
5- Clear operations
6- Start flash button
Old 10-23-2017, 21:54   #15 (permalink)
Make Root
1-After selecting the boot file we choose buildprop file taken from the same phone that we want to work on.
This method is used if we connect another device (not the one we want to root)
2- Select boot file and connect the same phone that you want to root then press option 5
3- If we dont have build-prop but we have a system file, we select the system file and connect another device in adb mode and press 5.
4- To select and choose the boot file from which we will create Root Kernel
5- Used to start making the Root Kernel !
To be continued ...
The Following 8 Users Say Thank You to easy-team For This Useful Post:
Page generated in 0.24813 seconds with 8 queries
