Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #77 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2016 Location: Paranaque
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | Preparing.....OK Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 6s Product NAME: iPhone8,1 Device ECID: 0x1a385c249b8226 Device CPID: 8003 Device SRTG: IBOOT-2234.0.0.2.22 Device MODE: DFU Device CPU: A9 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (kernel.img4).....OK Failed! Check Drivers and Re-enter in PWNDFU and Try Again Operation {Boot Passcode IOS 15.x} ID: 59C04DF0752DEEEB Elapsed time 01:35 -- Version 4.3.4 |
![]() | #78 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: philippines Age: 34
Member: 678773 Status: Offline Thanks Meter: 17 | iDevices PWNDFU :..... Checking Drivers.....Ok Checking UsbDk.....Ok Device CPU: A10 Waiting for server.....OK Please wait...Failed PWNDFU IS.....Failed Re-enter in DFU and Try Again! Operation {IPWNDER Device} ID: DBE5629A5EE4EB94 Elapsed time 00:17 -- Version 4.3.4 |
![]() | #79 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2013 Location: pakistan P G L Age: 38
Member: 2067643 Status: Offline Sonork: 1611265 Thanks Meter: 436 | Quote:
![]() | #80 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2005
Member: 204684 Status: Offline Thanks Meter: 21 | Hello, EFT Team! Can't make Boot Passcode IOS 15.X procedure: Preparing.....OK Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 7 (GSM) Product NAME: iPhone9,3 Device ECID: 0x1130de26400026 Device CPID: 8010 Device SRTG: IBOOT-2696.0.0.1.33 Device MODE: DFU Device CPU: A10 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (kernel.img4).....OK then warning window is drawn with 'Reconnect device and press OK!', I do reconnect device but after 0.5-1 min this window appears again and so on so forth. Can you advice? Thank you! |
The Following User Says Thank You to gr_from For This Useful Post: |
![]() | #81 (permalink) |
Junior Member ![]() Join Date: Feb 2014 Location: Dadyal,Mirpur AK Age: 34
Member: 2130753 Status: Offline Sonork: 100.1654683 Thanks Meter: 5 | when i backup passcode ios 15.x its ask to write ECID when i enter its on ECID i cant enter full misses last figure what the solution |
![]() | #82 (permalink) |
Member: 204684 Status: Offline Thanks Meter: 21 | answer to my question https://forum.gsmhosting.com/vbb/14568182-post80.html ...rebooted PC, from first try went without errors |
The Following 2 Users Say Thank You to gr_from For This Useful Post: |
![]() | #83 (permalink) | |
Member: 204684 Status: Offline Thanks Meter: 21 | Quote:
Sorry once again | |
![]() | #84 (permalink) | |
I have the same problem with iphone 7 Backup passcode was done without errors This is the log of Backuo Passcode IOS 15.X procedure: Preparing.....OK Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 7 (GSM) Product NAME: iPhone9,3 Device ECID: 0x1130de26400026 Device CPID: 8010 Device SRTG: IBOOT-2696.0.0.1.33 Device MODE: DFU Device CPU: A10 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (kernel.img4).....OK Successfully! Operation {Boot Passcode IOS 15.x} ID: 95A48440B3E3B1F9 Elapsed time 01:07 -- Version 4.3.4 But when I get info about iphone in working state I get this ECID 001130DE26400026 It means that data was read incorrect? If enter this ECID: 0x1130de26400026 of this ECID:001130DE26400026 I get such error: Checking iDevices.....OK Checking SSH......OK Backup Not Found & Check the ECID Operation {Restore Passcode IOS 15.x} ID: 7FEEAE26311992F4 Elapsed time 06:49 -- Version 4.3.4 Last edited by gr_from; 06-13-2022 at 10:13. | |
![]() | #85 (permalink) |
Member: 678773 Status: Offline Thanks Meter: 17 | iDevices PWNDFU :..... Checking Drivers.....Ok Checking UsbDk.....Ok Device CPU: A09 Waiting for server.....OK Please wait...Failed PWNDFU IS.....Failed Re-enter in DFU and Try Again! Operation {IPWNDER Device} ID: 1AAB7341C6847274 Elapsed time 00:14 -- Version 4.3.4 |
![]() | #86 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 648453 Status: Offline Thanks Meter: 81 | thanks eft team iphone 6s plus passcode bypass done eft 4.3.3 error but done with eft 4.3.4 Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 6s Plus Product NAME: iPhone8,2 Device ECID: 0x1819ac188b8226 Device CPID: 8003 Device SRTG: IBOOT-2234.0.0.2.22 Device MODE: DFU Device CPU: A9 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (kernel.img4).....OK Successfully! Operation {Boot Passcode IOS 15.x} ID: C54D8CC8F02CB86D Elapsed time 01:03 -- Version 4.3.3 Checking iDevices.....OK Checking SSH......OK Waiting for server.....OK Activation Files Restoring .......OK Operation {Restore Passcode IOS 15.x} ID: 5D12FBC8A398E000 Elapsed time 00:08 -- Version 4.3.3 Checking iDevices.....OK Checking SSH......OK Waiting for server.....OK Activation Files Restoring .......OK Operation {Restore Passcode IOS 15.x} ID: 2D0F29DBCC253987 Elapsed time 00:20 -- Version 4.3.4 |
The Following User Says Thank You to sahed07860 For This Useful Post: |
![]() | #87 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 238 ![]() | im still stock at 45% when doing backup..device disconect and software closes.. |
The Following User Says Thank You to simpleprince49 For This Useful Post: |
![]() | #88 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: EARTH
Member: 359939 Status: Offline Sonork: none Thanks Meter: 61 | iDevices PWNDFU :..... Checking Drivers.....Ok Checking UsbDk.....Ok Device CPU: A09 Waiting for server.....OK Please wait...Failed PWNDFU IS.....Failed Re-enter in DFU and Try Again! Operation {IPWNDER Device} ID: A9EB8487FE9F717D Elapsed time 00:14 -- Version 4.3.4 |
![]() | #89 (permalink) |
Member: 204684 Status: Offline Thanks Meter: 21 | Hello, EFT Team! I have backup files in \EFT Pro\Backups for my phone but EFTPro software says that I dont't. I can send you archive with those file, just tell me where should I upload the archive ' cause I cant upload it here on forum. Thank you! |
