Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #106 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: everywhere
Member: 1868823 Status: Offline Thanks Meter: 47 | Quote:
The Following User Says Thank You to okta28 For This Useful Post: |
![]() | #107 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2006 Location: Republica Dominicana
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 128 | I made a post explaining that I have been trying to make an iphone x bypass passcode and I carry out the whole process perfectly but in the end the iphone does not activate, it does not perform the bypass. I made a post explaining that I have been trying to make an iphone x bypass passcode and I carry out the whole process perfectly but in the end the iphone does not activate, it does not perform the bypass. I even deleted my post even with the details log. |
The Following User Says Thank You to alexis_01 For This Useful Post: |
![]() | #108 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 635202 Status: Online Thanks Meter: 10 | iDevices PWNDFU :..... Checking Drivers.....Ok Checking UsbDk.....Ok Error! Tips to solve the problem: 1-Reconnect the Device Try Again 2-Download And install UsbDk_1.0.22_x64.msi: From: https://github.com/daynix/UsbDk/releases 3-Restart Your PC And Try Again Operation {IPWNDER Device} ID: 67719B4F8E81D19C Elapsed time 00:05 -- Version 4.3.4 |
![]() | #109 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2008 Location: always here Age: 31
Member: 701656 Status: Offline Sonork: 100.1605121 Thanks Meter: 108 | Quote:
I have the same problem on a 6s | |
![]() | #110 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2012 Location: srilanka(pearl island)
Member: 1848453 Status: Offline Thanks Meter: 55 ![]() | tested iphone 6s tested an iphone 6s ios 15.0 on windows 7 working fine thanks team for your support,we are waiting for ios 15 hello bypass .... ![]() |
The Following User Says Thank You to barakath For This Useful Post: |
![]() | #113 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: Albania -Durres Age: 42
Member: 154346 Status: Offline Thanks Meter: 37 | iDevices PWNDFU :..... Checking Drivers.....Ok Checking UsbDk.....Ok Device CPU: A11 Waiting for server.....OK Please wait...Failed PWNDFU IS.....Failed Re-enter in DFU and Try Again! Operation {IPWNDER Device} ID: 8D22A4B530565533 Elapsed time 00:25 -- Version 4.3.4 |
![]() | #115 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: ESPAŅA
Member: 808967 Status: Offline Thanks Meter: 155 | i have the same problem i have 2 iphone 7 plus and 8 normal vercion 15.0.2 and nothing happens with the program and the new update are in hello always from the friend five birth |
The Following User Says Thank You to fabicel For This Useful Post: |
![]() | #118 (permalink) |
Member: 635202 Status: Online Thanks Meter: 10 | driver solution ? whats this probleme iDevices PWNDFU :..... Checking Drivers.....Ok Checking UsbDk.....Ok Error! Tips to solve the problem: 1-Reconnect the Device Try Again 2-Download And install UsbDk_1.0.22_x64.msi: From: https://github.com/daynix/UsbDk/releases 3-Restart Your PC And Try Again Operation {IPWNDER Device} ID: 24DFD8905DB9E9A5 Elapsed time 02:05 -- Version 4.3.4 |
![]() | #120 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007
Member: 621455 Status: Online Thanks Meter: 117 | iphone 6s stuck on this reconnect device and press ok while boot passcodeios Preparing.....OK Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 6s Plus Product NAME: iPhone8,2 Device ECID: 0x52c19307b8226 Device CPID: 8003 Device SRTG: IBOOT-2234.0.0.2.22 Device MODE: DFU Device CPU: A9 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK |
