Old 03-25-2023, 13:55   #31 (permalink)
Member: 2067643
Sonork: 1611265
Thanks Meter: 480
Waiting For Device Connection...
USB PORT: (COM6)
Port: (COM6)
Manufacturer: MediaTek Inc.
OPEN COM PORT... OK
Handshake... OK
Waiting for server........ OK
Read CHIP ID... OK
HW-CODE: 0X699
CPU: MT6739
Read Chip Version... OK
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Read Phone Configuration... OK
Bypass Security Protection... OK
Dump EMI Config... OK
Send Protection Files BROM... OK
Check BROM status... OK
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Read DEVICE Status... BROM
Init EXT RAM... OK
Send Download Agent... OK
Send Download Agent Extended... OK
Read Device Info... OK
EMMC INFO:
EMMC Boot1 Size: 4.00 MB
EMMC Boot2 Size: 4.00 MB
EMMC RPMB Size: 16.00 MB
EMMC USER Size: 29.12 GB
EMMC CID: 150100475836424142008E0ABC17B7D7
RAM INFO:
SRAM Size: 128.00 KB
DRAM Size: 3.00 GB
CHANGE TO HIGH-SPEED PORT... OK
Read Build Prop Info... OK
Brand: SAMSUNG
Model: SM-A022F
Product: A02XX
Manufacturer: SAMSUNG
Android Version: 11 (Android 11)
Security Patch: 2022-07-01
Build ID: RP1A.200720.012
Build Date: THU JUL 21 17:02:37 KST 2022
Display ID: RP1A.200720.012.A022FXXU3BVG6
Build: A022FXXU3BVG6
Read Internal Storage Info... OK
USERDATA: 24.17 GB
USERDATA: ENCRYPTED
Prepare data... OK
RESET FRP... OK
READ MISC PARTITION... OK
Patch misc partition to format data... OK
Finalize... OK
Reboot... OK
Elapsed Time: 11 secs, 349 msecs
a22 logs done butt still lock
The Following User Says Thank You to iftikharrana58 For This Useful Post:
Old 03-26-2023, 01:32   #32 (permalink)
Registered User
Member: 1977340
Sonork: cairo
Thanks Meter: 2
Nice update Thank you
The Following User Says Thank You to mahmoud slama For This Useful Post:
Old 03-26-2023, 20:00   #33 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
Do u future add Apple Watch Activation Lock!! Bypass?
Old 03-27-2023, 10:01   #34 (permalink)
Thanks Meter: 22,316
Thank you for your comment, and *** willing, they will be supported in the future
The Following User Says Thank You to easy-team For This Useful Post:
Old 03-27-2023, 10:44   #35 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,375
Hello,
in future there's any chance for Ipad 2 Apple Id forgot?
Old 04-01-2023, 20:09   #36 (permalink)
Zaki Bouzidson's Avatar
Member: 2287326
Thanks Meter: 56
[SPD] Added No use Boot For The device is in diag mode
What does that mean?
Old 04-02-2023, 08:54   #37 (permalink)
This option, if you are given an error, select this and repeat without disconnecting the phone
Old 04-02-2023, 17:30   #38 (permalink)
Member: 686560
Thanks Meter: 69
Sorry . where can i see these pics or do i have to buy them?
Add New Tecno Model TeastPoint
Tecno CG6 T.P
Tecno CG6j T.P
Tecno CG7n T.P
Tecno CG8 T.P
Tecno CH7 T.P
Tecno CI6N T.P
Tecno KF6H T.P
Tecno KF6K T.P
Tecno KF6P T.P
Tecno KF7J T.P
Tecno KF8 T.P
Tecno KG6K T.P
Old 04-03-2023, 00:24   #39 (permalink)
Member: 2048673
Thanks Meter: 66
I am in a big problem. I updated the phone, iPhone 6S Plus, with the latest software_15.7.4_ware from the update, and we do not activate the phone. Please help. I have the latest type of update_15.7.4_soft. Please help me. The phone cannot be activated. Thank you for your kind cooperation with us.
Old 04-03-2023, 09:20   #40 (permalink)
Roll back to 15.7.3 and repeat the process again
Old 04-03-2023, 09:52   #41 (permalink)
candelwizzy's Avatar
Member: 853308
Thanks Meter: 64
Post Iphone X SN ca'nt change
Searching for Apple Port.....Detected {COM54} Open Port Port.....OK Writing New SN: [F17LTC4YFGDQ].....IF NOT Done Try Again! Operation {Change Serial Number} ID: 8A918A623FBD9403 Elapsed time 00:09 -- Version 4.4.4 Build 001
Old 04-03-2023, 10:07   #42 (permalink)
Member: 853308
Thanks Meter: 64
Checking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Unactivated
BuildVersion: 20D67
CPU Arch: arm64
Device Class: iPhone
Device Name: iPhone
Firmware Version: iBoot-8419.82.1
Device IMEI: 354841094374708
Device MEID: 35484109437470
Product Name: iPhone OS
Product Type: iPhone X Global
IOS Version: 16.3.1
SIM Status: kCTSIMSupportSIMStatusNotInserted
Device Serial Number: DNPWXH15JCLG
DeviceID: b7b20ef6f96c175dedafd239f011bdd73e5147f8
MEID Status: Supported
Preparing Hello....Waiting for server.....OK
Please change the serial number to (F17LTC4YFGDQ) and try again
Operation {Hello Screen: Generate Activation files iCloud 15.x/16.x} ID: 84A2F4171253A222
Elapsed time 00:01 -- Version 4.4.4 Build 001
p, li { white-space: pre-wrap; }
Old 04-03-2023, 11:46   #43 (permalink)
BuildVersion: 20D67
CPU Arch: arm64
Device Name: iPhone
IOS Version: 16.3.1
https://www.youtube.com/watch?v=KeAq...nnel=EFTDongle
Old 04-03-2023, 17:58   #44 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 86
USB PORT: SAMSUNG Mobile USB Serial Port (COM144)
Port: SAMSUNG Mobile USB Serial Port (COM144)
Manufacturer: SAMSUNG Electronics Co., Ltd.
Please Do it with Test Point...
Trying to unlock Samsung A12 but when it get to please Do it with Test point it will not connect
Sent from my CPH1727 using Tapatalk
Old 04-04-2023, 21:33   #45 (permalink)
Close the interface, which is a connected phone, open it, and repeat the process again. This will be fixed in the next version
Page generated in 0.21382 seconds with 8 queries
