Old 01-25-2024, 02:13   #16 (permalink)
Member: 2869230
Thanks Meter: 9
Kirin devices team ��
Old 01-25-2024, 04:09   #17 (permalink)
Member: 2958818
Thanks Meter: 23
add unisoc T603 like itel A70
Old 01-25-2024, 07:33   #18 (permalink)
Member: 908095
Thanks Meter: 8
Great update , thanks team
Old 01-25-2024, 07:50   #19 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 467
Originally Posted by easy-team View Post
This is an option that connects a phone to download mode and automatically turns the phone into a brom
The question is not force to brom from download mode. There is a new 2023 method out there used by almost all gsm tool they manage to patch FRP partition name from download mode and erase it just like other partition which is accessible for read and write operation controlled odin protocol.
Best Regards | Yoba
The Following User Says Thank You to eyobaaa For This Useful Post:
Old 01-25-2024, 10:44   #20 (permalink)
Member: 154346
Thanks Meter: 37
how about a245f fix brom mode MT6789
Old 01-25-2024, 11:33   #21 (permalink)
Member: 2643730
Thanks Meter: 1,113
eft pro dongle update v4.6.4 build 001 is released :
what's new :
[spd]
new design and easy menu
spd old / new ui update
added info boot mode
added read flash /format disk /write disk
added network unlock boot mode
added repair imei boot mode
added remove mdm boot mode
added new boot spd v2
  • sc7731e_v2
  • sc9863a_v2
  • sc9863a_64_v2
  • t606_64_v2
  • t610_64_v2
[mtk]
added repair imei generic (mt67xx) brom
added repair network security 2020/2021 brom
added repair network security 2022 brom
added read imei
added backup with cid number for mtk operations
added forced brom samsung download mode
added oppo mt6771 auth free
  • oppo a91 auth free
  • oppo a9x auth free
  • oppo f15 auth free
  • oppo reno2 f auth free
  • oppo a3 auth free
  • oppo a7x auth free
  • oppo f7 auth free
  • oppo f7 youth auth free
  • oppo f9 auth free
  • oppo f9 pro auth free
  • oppo r15 auth free
added samsung auth free
  • samsung galaxy wide5(sm-e426s) auth free
  • samsung galaxy a13 5g(sm-a136) auth free
  • samsung galaxy a22(sm-a225) auth free
  • samsung galaxy f42 (sm-e426)auth free
added new device for mtk protocol (v6)
  • infinix hot 40 pro x6837 v6
  • infininx note 12 pro x676b v6
  • infinix note 12 vip x672 v6
  • infinix note 12 g96 x670 v6
  • infinix note 30 pro x678b
  • infinix zero 30 x6731b v6
  • infinix zero 20 x6821 v6
  • blackview n6000 v6
  • blackview a200 pro v6
  • ulefone armor 12s v6
  • tecno pova 5 lh7n v6
  • tecno pova 4 v6
  • tecno phantom x2 pro 5g ad9 v6
  • tecno camon 20 pro ck7n v6
  • tecno phantom v fold(ad10) v6
  • tecno camon 19 pro (ci8n) v6
[qualcomm]
added read flash
added repair chip damaged (huawei)
update remove id (huawei)
fix old loader
[apple]
added (jailbreak) backup apple with info
added disable update/reset/skip setup (one click)
added disable update/reset/skip setup ramdisk/hello
previous version eft pro dongle feature
[mtk]
support forced brom (method 1)
support forced brom (method 2)
support forced brom without test point
support samsung forced brom (pit method)
support write huawei (update app) firmware
support write samsung (tar) firmware
support write oppo/realme (ofp) firmware
support write emmc dump firmware
support vivo mt6765 preloader
support direct unlock network mtk (brom)
support (vivo) disable mdm lock supported for (2020 to up)
support (vivo) disable mdm lock supported for (2019)
support (vivo) disable mdm lock supported for (y15s pd2140ef)
support (vivo) disable demo mode
support (vivo) disable orange msg
support (vivo) restore orange msg
update samsung disable mdm lock
update samsung change kg
update oppo disable mdm lock
support security 2022/2023 for mtk
support device for mtk devices
support device (mtk) factory reset/frp reset/write firmware
update write samsung (tar) firmware
fix tool dl image fail
reset frp lock writefile
protocol for mtk (v6)
protocol mtk devices read info / flash / format / frp
free auth tecno / infinix / itel
support models on v6 protocol infinix / tecno
[spd]
support models apove 200+ model
factory reset and frp reset
added write pac firmware for all spd
enter diag mode 2 methods
read info and imei in diag mode
factory reset in diag mode all mode
added rsa auth itel/tecno/infinix/realme and more
added spd fix wireless test assistant
added new device (spd) factory reset/frp reset/write firmware pac
read info
reset frp/factory reset
unlock bootloader
relock bootloader
[samsung]
fix exynos boot (beta)
bypass knox samsung adb
bypass knox samsung mtp
remove frp direct (mtp) 2023
enable adb with call emergency #0#.
Remove kg lock direct (mtp)
translate adb android 13
[qualcomm]
enable diag mode without root
added new list (qualcomm new)
added list service for (factory reset /frp )
added list service for (factory reset oppo /frp oppo )
-qualcomm device support automatic loader
-support for qualcomm devices. Select the model
device support for qualcomm devices
device (qualcomm) factory reset/frp
qualcomm protocol update to support more devices and brands
fixed read chip info oppo reno devices
unlock id (huawei)
reset frp/userdata use firmware (vivo/other)
[ apple ]
added boot passcode/hello ios 16.4 iphone 8/8+/x
added boot passcode/hello ios 16.4 ipad
generate activation files ios 15.x/16.x (iphone/ipad) (without change sn)
fix boot passcode/hello ios 15.x/16.x (ipad/iphone)
fix mount passcode/hello ios 11.x up 16.x
boot passcode/hello for (ipad)
read account from backup folder
boot passcode/hello ios 11.x up 16.x one click
change test signed drivers to on
read idevice info (recovery mode)
automatic active backup restore built-in with one click
supported by recovery and supported by dfu
save info to txt file when backup or reading from a file
restore passcode with disable update/reset
add option to format or restart if backup completes
ipwnder restart in case of failure
restore by bypass setup and disabling update
[ rockchip ]
update read/write flash
factory reset & frp
more come soon ...
update online without replace it ...
for new user download file
kind regards, easy firmware team
get now eft dongle from nearest distrubutor/reseller here
eft tool pro withoutdongle
as always last in update
Old 01-25-2024, 12:57   #22 (permalink)
Member: 1594841
Thanks Meter: 2
Hello EFT Team great update thanks, please add Samsung Exynos cpu frp new security
Old 01-25-2024, 13:12   #23 (permalink)
Member: 2067643
Sonork: 1611265
Thanks Meter: 472
huawei a8 frp done
Waiting For Device Connection...
USB PORT: MediaTek USB Port_V1632 (COM48)
Port: MediaTek USB Port_V1632 (COM48)
Manufacturer: MediaTek Inc.
OPEN COM PORT... OK
Handshake... OK
Waiting for server........ OK
Read CHIP ID... OK
HW-CODE: 0X766
CPU: MT6765
Read Chip Version... OK
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Read Phone Configuration... OK
Bypass Security Protection... OK
Dump EMI Config... OK
Send Protection Files BROM... OK
Check BROM status... OK
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Read DEVICE Status... BROM
Init EXT RAM... OK
Send Download Agent... OK
Send Download Agent Extended... OK
Read Device Info... OK
EMMC INFO:
EMMC Boot1 Size: 4.00 MB
EMMC Boot2 Size: 4.00 MB
EMMC RPMB Size: 16.00 MB
EMMC USER Size: 58.24 GB
EMMC CID: 90014A68433861503E01002495E767B3
RAM INFO:
SRAM Size: 224.00 KB
DRAM Size: 3.00 GB
CHANGE TO HIGH-SPEED PORT... OK
Server ... OK
Get Partition ...
Checking calibration data... OK
Backup preloader... OK
Backup nvcfg... OK
Backup nvdata... OK
Backup protect1... OK
Backup protect2... OK
Backup seccfg... OK
Backup persist... OK
Backup proinfo... OK
Backup nvram... OK
Backup vbmeta... OK
Backup md1img... OK
Read Build Prop Info... FAIL
[FS ERR] FAILED TO MOUNT /SYSTEM/
Read Internal Storage Info... OK
USERDATA: 54.52 GB
USERDATA: ENCRYPTED
Prepare data... OK
RESET FRP... OK
Finalize... OK
Reboot... OK
Elapsed Time: 50 secs, 834 msecs
Old 01-25-2024, 19:37   #24 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 230
repairing the damaged chip does not work
Old 01-25-2024, 21:05   #25 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 549
Always good update team....thanks
Old 01-26-2024, 16:28   #26 (permalink)
Member: 1759100
Thanks Meter: 6
USB PORT: SPRD U2S Diag (COM7)
Port: SPRD U2S Diag (COM7)
Manufacturer: DriverCoding Corporation
OPEN COM PORT... OK
Handshake NAND_FDL... OK
Boot version: SPRD3
Sending payload... OK
Sending preloader... FAIL
[PROTOCOL ERR] BSL_REP_VERIFY_ERROR [0x0000008B]
Old 01-27-2024, 07:06   #27 (permalink)
Member: 1759100
Thanks Meter: 6
This update has a lot of bugs with spd and mtk...you guys should look into it and rectify please
Sent from my INE-LX2 using Tapatalk
Old 01-27-2024, 08:32   #28 (permalink)
Blocked
Member: 219420
Thanks Meter: 76
samsung a34 is mtk can download to force BROM?
and exynos kg remove supported ?
Old 01-27-2024, 08:57   #29 (permalink)
Thanks Meter: 21,010
reset pc and phone and try again connect battery
Old 01-30-2024, 09:13   #30 (permalink)
Member: 1868823
Thanks Meter: 47
after activation file restoring iphone 8 ios 16.7.4 boot loop tryed 3 phones same thing . phone keeps restarting
Page generated in 0.22463 seconds with 8 queries
