![]() | #18 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,261 ![]() | Waiting for server.....OK Checking iDevices.....OK Remove icloud with UDID .....(00008020-000834890198003A)... Model:iPhone XS Device Name:iPhone MODE:CLEAN Status:ONLINE Status Code:200 Removed:Fail ⛔️ === Click Again! =========================== Operation {Remove Icloud Open Menu with UDID} ID: 22F3394455382DDF Elapsed time 00:03 -- Version 4.6.8 Build 002 |
![]() | #19 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Online Sonork: 100.1584728 Thanks Meter: 22,168 | Quote:
![]() | #21 (permalink) |
Junior Member Join Date: Jan 2015 Location: Egypt Age: 32
Member: 2331934 Status: Offline Thanks Meter: 0 | Waiting for server.....OK Checking iDevices.....OK Remove icloud with UDID .... Model:iPhone 11 Device Name:iPhone MODE:CLEAN Status:OFFLINE Status Code:200 Removed:Success ✅ ======================== Operation {Remove Icloud Open Menu with UDID} ID: Elapsed time 00:04 -- Version 4.6.8 Build 002 thank you |
![]() | #22 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: kadapa {A.P} Age: 44
Member: 151175 Status: Offline Sonork: 105497 Thanks Meter: 98 | tried lot of times getting same error pls see the log Waiting for server.....OK Checking iDevices.....OK Remove icloud with UDID .....(7925c0f33e50331b9d64af5452d9dcf3c1924c7d)... ERROR: DATA NOT FOUND OR TOKEN EXPIRED Please follow the instructions below and try again: 1 - Before connecting the DEVICE WITH ICLOUD to the WIFI network go to the wifi settings and configure Proxy Server: 51.178.81.232 Port:8882 press Save, and then connect 2 - Go from safari to "51.178.81.232:8882" and press download , then Allow 3 - Go to Settings General->Profile and Install the profile you downloaded 4 - Then go Settings->General->About-> scroll down and after go to Certificate Trust Settings and enable DO_NOT_TRUST 5 - Go to iCloud > Turn OFF Game Center->Then Turn ON again (only 1 times) 6-After completing the previous steps, go apple Tap select (Remove Icloud Open Menu with UDID (FMI OFF with UDID)) and click Start again go to icloud turn on and off game center If the process is successful, Turn OFF WiFi then check iCloud services before flashing. Operation {Remove Icloud Open Menu with UDID} ID: E1DAF8F6274354D5 Elapsed time 00:02 -- Version 4.6.8 Build 002 |
![]() | #23 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Aug 2007 Location: Melbourne, Australia
Member: 574542 Status: Offline Thanks Meter: 15 | Help!!!!!!!!!!!!!! Thanks Waiting for server.....OK Checking iDevices.....OK Remove icloud with UDID .....(905...............975)... Model:iPhone 8 Plus Device Name:iPhone MODE:CLEAN Status:OFFLINE Status Code:200 Removed:Success ✅ ======================== Operation {Remove Icloud Open Menu with UDID} ID: 215DB7FAA1E37248 Elapsed time 00:14 -- Version 4.6.8 Build 002 |
The Following User Says Thank You to surjit_jit For This Useful Post: |
![]() | #27 (permalink) |
Member: 2536865 Status: Online Sonork: 100.1584728 Thanks Meter: 22,168 | |
![]() | #29 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2008 Location: Turkey/ Gaziantep
Member: 833220 Status: Offline Sonork: hasokeh Thanks Meter: 16 ![]() | Waiting for server.....OK Checking iDevices.....OK Remove icloud with UDID .....(00008101-001550541451003A)... ERROR: DATA NOT FOUND OR TOKEN EXPIRED |
![]() | #30 (permalink) | |
