Old 04-07-2024, 20:20   #1 (permalink)
Thanks Meter: 21,546
EFT Pro Dongle Update V4.7.1 released SPD Diag repair IMEI &Samsung Reset Frp QR Code
EFT Pro Dongle Update V4.7.1 Build 001 is released :
What's New :
[SAMSUNG]
Added Reset Frp QR Code (BETA)
Samsung G990B Reset Frp QR Code
[SPD]
Added SPD Diag Repair IMEI
Infinix Smart 7 HD X6516 Repair IMEI
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
Added Repair IMEI Generic (MT67XX) BROM
Added Repair Network Security 2020/2021 BROM
Added Repair Network Security 2022 BROM
Added Read IMEI
Added backup with CID number for MTK operations
Added Forced BROM SAMSUNG Download Mode
Added OPPO MT6771 Auth Free
Added Samsung Auth Free
Samsung Galaxy Wide5(SM-E426S) Auth Free
Samsung Galaxy A13 5G(SM-A136) Auth Free
Samsung Galaxy A22(SM-A225) Auth Free
Samsung Galaxy F42 (SM-E426)Auth Free
Added new DEVICE for mtk protocol (v6)
Update GENERIC MTK V5
Update GENERIC MTK 2023
Added META Read Info All MTK CPU
Added META Factory Reset All MTK CPU
Added META Factory Reset MT62XX
Added META Repair IMEI All MTK CPU
Added in META Mode ( Infinix - Tecno - Itel ) All Model With Auth
Added MTK Preloader
Added SAMSUNG Brom Models NEW
Added META Factory Reset Direct (INFINIX-TECNO-ITEL)
Added Enable/Disable Backup
Direct Factory Reset (INFINIX-TECNO-ITEL)
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
Added Info Boot Mode
Added Read Flash /Format Disk /Write Disk
Added Network Unlock Boot Mode
Added Repair IMEI Boot Mode
Added Remove MDM Boot Mode
Added New Boot SPD V2
Added GENERIC SPD V1
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
Added Read flash
Added Repair Chip damaged (Huawei)
Update Remove ID (Huawei)
Fix OLD loader
Support Automatic Loader [OPPO/VIVO/HUAWEI/XIAOMI/ONEPLUS]
Added NEW Device ALCATEL/TCL
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
Added (Jailbreak) Backup Apple with Info
Added Disable Update/Reset/Skip Setup (One Click)
Added Disable Update/Reset/Skip Setup Ramdisk/HELLO
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 17 Users Say Thank You to easy-team For This Useful Post:
Old 04-07-2024, 21:27   #2 (permalink)
Member: 2894867
Thanks Meter: 11
Boom Boom update
Thank u eft team
The Following User Says Thank You to bilshow For This Useful Post:
Old 04-07-2024, 23:16   #3 (permalink)
Member: 3041584
Sonork: Ok
Thanks Meter: 7
Thank eft team
good team
Old 04-07-2024, 23:26   #4 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 490
Team about this update all phones are not go to qr screen if frp locked except kg lock devices
Best Regards | Yoba
The Following 2 Users Say Thank You to eyobaaa For This Useful Post:
Old 04-08-2024, 00:18   #5 (permalink)
CHEZRACHID's Avatar
Member: 136492
Thanks Meter: 292
It's free solution realised 2 days ago by other team to remove kg lock ( enable adb if frp lock is off ).
Old 04-08-2024, 01:28   #6 (permalink)
Member: 1788877
Thanks Meter: 492
What's the purpose of this comment ?
Do you want them not to add this option because others did it ?
And if they don't add this option, users will come complaining why this option is not available !!!!
Really weird comment
The Following 6 Users Say Thank You to aamigoo For This Useful Post:
Old 04-08-2024, 08:53   #7 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 589
Good update easy team......thanks
The Following User Says Thank You to Malik Shani G For This Useful Post:
Old 04-08-2024, 11:50   #8 (permalink)
Member: 3059146
its greet update more power need by kg
Old 04-08-2024, 12:54   #9 (permalink)
Member: 2666112
Thanks Meter: 96
tutorial for frp remove with qr please!!!!!!
The Following User Says Thank You to locofollador For This Useful Post:
Old 04-08-2024, 13:54   #10 (permalink)
mahaprobhu's Avatar
Member: 1818374
Sonork: 100.1640346
Thanks Meter: 310
all model update eft team
Old 04-08-2024, 14:42   #11 (permalink)
Member: 282206
Thanks Meter: 102
hello a54 wont activate QR Code with tape 3 times
Old 04-08-2024, 15:45   #12 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 235
Does not activate the camera for frp via qr fake update
The Following User Says Thank You to m&s For This Useful Post:
Old 04-08-2024, 17:36   #13 (permalink)
Member: 953646
Sonork: 000000000
Thanks Meter: 19
i tested A137FXXS3CWL2 work fine android 13
but on android 14 not
Old 04-08-2024, 18:33   #14 (permalink)
Member: 3041318
Old 04-08-2024, 20:27   #15 (permalink)
this mtk supported by mtk new download mode
Page generated in 0.23860 seconds with 8 queries
