Old 04-10-2024, 12:21   #1 (permalink)
Thanks Meter: 21,546
EFT Pro Dongle Update V4.7.2 released Reset FRP Tecno/Infinix&Samsung Bypass Knox/MDM
EFT Pro Dongle Update V4.7.2 Build 001 is released :
What's New :
[EFRP]
TECNO / INFNIX
Reset FRP Tecno/infinix (MTP & USB) 2024 (BETA)
[SAMSUNG]
Added BYPASS Knox/MDM (QR Code )
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
Added Repair IMEI Generic (MT67XX) BROM
Added Repair Network Security 2020/2021 BROM
Added Repair Network Security 2022 BROM
Added Read IMEI
Added backup with CID number for MTK operations
Added Forced BROM SAMSUNG Download Mode
Added OPPO MT6771 Auth Free
Added Samsung Auth Free
Samsung Galaxy Wide5(SM-E426S) Auth Free
Samsung Galaxy A13 5G(SM-A136) Auth Free
Samsung Galaxy A22(SM-A225) Auth Free
Samsung Galaxy F42 (SM-E426)Auth Free
Added new DEVICE for mtk protocol (v6)
Update GENERIC MTK V5
Update GENERIC MTK 2023
Added META Read Info All MTK CPU
Added META Factory Reset All MTK CPU
Added META Factory Reset MT62XX
Added META Repair IMEI All MTK CPU
Added in META Mode ( Infinix - Tecno - Itel ) All Model With Auth
Added MTK Preloader
Added SAMSUNG Brom Models NEW
Added META Factory Reset Direct (INFINIX-TECNO-ITEL)
Added Enable/Disable Backup
Direct Factory Reset (INFINIX-TECNO-ITEL)
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
Added Info Boot Mode
Added Read Flash /Format Disk /Write Disk
Added Network Unlock Boot Mode
Added Repair IMEI Boot Mode
Added Remove MDM Boot Mode
Added New Boot SPD V2
Added GENERIC SPD V1
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
Added Read flash
Added Repair Chip damaged (Huawei)
Update Remove ID (Huawei)
Fix OLD loader
Support Automatic Loader [OPPO/VIVO/HUAWEI/XIAOMI/ONEPLUS]
Added NEW Device ALCATEL/TCL
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
Added (Jailbreak) Backup Apple with Info
Added Disable Update/Reset/Skip Setup (One Click)
Added Disable Update/Reset/Skip Setup Ramdisk/HELLO
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 18 Users Say Thank You to easy-team For This Useful Post:
Old 04-10-2024, 14:17   #2 (permalink)
CHEZRACHID's Avatar
Member: 136492
Thanks Meter: 292
https://www.youtube.com/watch?v=FefnueOxQqo&t=29s
Old 04-10-2024, 14:32   #3 (permalink)
Member: 2994119
Thanks Meter: 15
hope tecno/infinix frp works at 2024 security
Old 04-10-2024, 15:37   #4 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 235
Old 04-10-2024, 20:58   #5 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 589
Eid mubarik......and good update
The Following User Says Thank You to Malik Shani G For This Useful Post:
Old 04-11-2024, 11:54   #6 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
Bypass MDM, android 14 not supported
The Following 3 Users Say Thank You to Monty For This Useful Post:
Old 04-13-2024, 16:28   #7 (permalink)
Member: 3041584
Sonork: Ok
Thanks Meter: 7
good update...good team
Old 04-13-2024, 16:33   #8 (permalink)
Super Moderator
mihut's Avatar
Member: 824
Thanks Meter: 25,229
Tecno Spark 5 pro pictures
read info Done​
Waiting For Device Connection...
USB PORT: MediaTek PreLoader USB VCOM (Android) (COM67)
Port: MediaTek PreLoader USB VCOM (Android) (COM67)
Manufacturer: MediaTek Inc.
OPEN COM PORT... OK
Handshake... OK
Waiting for server........ OK
Read CHIP ID... OK
HW-CODE: 0X766
CPU: MT6765
Read Chip Version... OK
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Read Phone Configuration... OK
Switch TO BROM PORT... OK
Wait for brom... OK
Bypass Security Protection... OK
Dump EMI Config... OK
Send Protection Files BROM... OK
Check BROM status... OK
Setup DEVICE... OK
Init HARDWARE... OK
Setup DEVICE... OK
Read DEVICE Status... BROM
Init EXT RAM... OK
Send Download Agent... OK
Send Download Agent Extended... OK
Read Device Info... OK
EMMC INFO:
EMMC Boot1 Size: 4.00 MB
EMMC Boot2 Size: 4.00 MB
EMMC RPMB Size: 16.00 MB
EMMC USER Size: 58.24 GB
EMMC CID: 150100445036444142031B2C9AF267B3
RAM INFO:
SRAM Size: 224.00 KB
DRAM Size: 4.00 GB
CHANGE TO HIGH-SPEED PORT... OK
Server ... OK
Get Partition ... OK
Read Build Prop Info... OK
Brand: TECNO
Model: TECNO KD7
Product: KD7-GL
Manufacturer: TECNO MOBILE LIMITED
Android Version: 10 (Android 10)
Security Patch: 2022-03-05
Build ID: QP1A.190711.020
Build Date: FRI MAR 11 02:15:24 CST 2022
Display ID: KD7-H6211FQRSTU-Q-GL-220311V417
Build: FQRSTU-GL-220311V417
Read Internal Storage Info... OK
USERDATA: 52.97 GB
USERDATA: ENCRYPTED
Reboot... OK
Elapsed Time: 36 secs, 650 msecs
__________________
Just Follow the Rules and Be Polite
Saying "thank you" can be hard. But it's so important.
The Following User Says Thank You to mihut For This Useful Post:
Old 04-14-2024, 08:28   #9 (permalink)
bijoychowdry's Avatar
Member: 1984655
Sonork: 119.30.39.25
Thanks Meter: 82
vivo y22 mt6768 frp not work
Old 04-15-2024, 06:24   #10 (permalink)
Member: 3047741
Sonork: www.sonork.com
very good update, very good tool.
The Following User Says Thank You to RYU HAIABUSA For This Useful Post:
Old 04-15-2024, 07:42   #11 (permalink)
Member: 2968042
How many computers is the daily login limit for the EFT Pro account version?
Page generated in 0.18151 seconds with 8 queries
