Old 04-21-2024, 19:10   #1 (permalink)
Thanks Meter: 21,546
EFT Pro Dongle Update V4.7.3 released Samsung Qualcomm Model Reset FRP-Factory Reset
EFT Pro Dongle Update V4.7.3 Build 001 is released :
What's New :
[SAMSUNG]
Added models Qualcomm
* Reset FRP
* Factory Reset
  • SM-A426U U7
  • SM-A426U1 U7
  • SM-A426W U7
  • SM-A426XU U7
  • SM-A526U UA
  • SM-A526U1 UA
  • SM-A526W UA
  • SM-A526XU UA
  • SM-A716U U9
  • SM-A716U1 U9
  • SM-A716W U9
  • SM-A716XU U9
  • SM-A736B U5
  • SM-A736BR U5
  • SM-F711B U6
  • SM-F711BR U6
  • SM-F711U U6
  • SM-F711U1 U6
  • SM-F711W U6
  • SM-F711XU U6
  • SM-F721B U4
  • SM-F721BR U4
  • SM-F721U U3
  • SM-F721U1 U3
  • SM-F721W U3
  • SM-F721XU U3
  • SM-F731B U3
  • SM-F731BR U3
  • SM-F731U U3
  • SM-F731U1 U3
  • SM-F731W U3
  • SM-F731XU U3
  • SM-F916U U2
  • SM-F916U1 U2
  • SM-F916W U2
  • SM-F916XU U2
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
Added Repair IMEI Generic (MT67XX) BROM
Added Repair Network Security 2020/2021 BROM
Added Repair Network Security 2022 BROM
Added Read IMEI
Added backup with CID number for MTK operations
Added Forced BROM SAMSUNG Download Mode
Added OPPO MT6771 Auth Free
Added Samsung Auth Free
Samsung Galaxy Wide5(SM-E426S) Auth Free
Samsung Galaxy A13 5G(SM-A136) Auth Free
Samsung Galaxy A22(SM-A225) Auth Free
Samsung Galaxy F42 (SM-E426)Auth Free
Added new DEVICE for mtk protocol (v6)
Update GENERIC MTK V5
Update GENERIC MTK 2023
Added META Read Info All MTK CPU
Added META Factory Reset All MTK CPU
Added META Factory Reset MT62XX
Added META Repair IMEI All MTK CPU
Added in META Mode ( Infinix - Tecno - Itel ) All Model With Auth
Added MTK Preloader
Added SAMSUNG Brom Models NEW
Added META Factory Reset Direct (INFINIX-TECNO-ITEL)
Added Enable/Disable Backup
Direct Factory Reset (INFINIX-TECNO-ITEL)
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
Added Info Boot Mode
Added Read Flash /Format Disk /Write Disk
Added Network Unlock Boot Mode
Added Repair IMEI Boot Mode
Added Remove MDM Boot Mode
Added New Boot SPD V2
Added GENERIC SPD V1
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
Added Read flash
Added Repair Chip damaged (Huawei)
Update Remove ID (Huawei)
Fix OLD loader
Support Automatic Loader [OPPO/VIVO/HUAWEI/XIAOMI/ONEPLUS]
Added NEW Device ALCATEL/TCL
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
Added (Jailbreak) Backup Apple with Info
Added Disable Update/Reset/Skip Setup (One Click)
Added Disable Update/Reset/Skip Setup Ramdisk/HELLO
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 10 Users Say Thank You to easy-team For This Useful Post:
Old 04-22-2024, 04:49   #2 (permalink)
Member: 2353766
Thanks Meter: 70
Thanks for amazing update
The Following User Says Thank You to WWRG For This Useful Post:
Old 04-22-2024, 10:14   #3 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 589
Always good update easyteam....thanks
The Following User Says Thank You to Malik Shani G For This Useful Post:
Old 04-22-2024, 15:36   #4 (permalink)
lucky999's Avatar
Member: 1643797
Thanks Meter: 183
F731u bit3 fail
Wait for device...
Download port: Qualcomm HS-USB QDLoader 9008 (COM16)
Port: Qualcomm HS-USB QDLoader 9008 (COM16)
Manufacturer: Qualcomm Incorporated
Waiting for server........ OK
Connect to comport... OK
Read chip info... OK
OEM Private key: 0x23B7FED9A5CAF0BE38C6724E2E01CB3EAC1D30CB52213B40 71CB76B4D42EB2B7
Vendor: GENERIC QUALCOMM
Load loader... OK
Send Loader... FAIL
[PROTOCOL ERR] HASH_TABLE_AUTH_FAILURE [0x00000021]
The Following User Says Thank You to lucky999 For This Useful Post:
Old 04-22-2024, 21:03   #5 (permalink)
Member: 3041584
Sonork: Ok
Thanks Meter: 7
good update good team
The Following User Says Thank You to Bessem ichi For This Useful Post:
Old 04-23-2024, 09:08   #6 (permalink)
Member: 270591
Thanks Meter: 19
good update add tecno mdm remove.
The Following User Says Thank You to haqpatel For This Useful Post:
Old 04-23-2024, 12:07   #7 (permalink)
Originally Posted by lucky999 View Post
Wait for device...
Load loader... OK
Send Loader... FAIL
contact me telegram @hasanorfi
Old 04-24-2024, 12:39   #8 (permalink)
SRASHED's Avatar
Member: 1024699
Sonork: 100.1622959
Thanks Meter: 601
Post
Pls add vivo mtk new security 𝐅𝐞𝐜𝐭𝐨𝐫𝐲 𝐑𝐞𝐬𝐞𝐭+𝐅𝐫𝐩
The Following 2 Users Say Thank You to SRASHED For This Useful Post:
Old 05-09-2024, 11:08   #9 (permalink)
Member: 3020763
Thanks Meter: 15
But samsung sm-g781w failed to reset frp ,,due to loarder file,,any file
The Following User Says Thank You to ELSATT For This Useful Post:
Page generated in 0.17688 seconds with 8 queries
