Old 05-14-2024, 13:19   #1 (permalink)
Thanks Meter: 21,407
EFT Pro Dongle Update V4.7.5 released [APPLE Open Menu FMI Off Backup&MTK&Qualcomm]
EFT Pro Dongle Update V4.7.5 Build 001 is released :
What's New :
[APPLE]
Added Open Menu FMI Off 2024 Backup
[MTK]
Added MTK Models New MTK 2023 V5 Patch 2024
Tecno & infinix auth V2
*Read info
*FRP
*Factory Reset
*Flash
[Qualcomm]
Added Qualcomm Models Samsung V2
*FRP
*Factory Reset
Tecno
Tecno Spark 10 5G KI8
Tecno Pova 5 pro LH8N
Tecno Spark 20c BG7N
Tecno Pova neo LE6
Tecno Camon 20 pro 5g CK8N
Tecno Phantomx2 5G AD8
Tecno Camon 19 pro 5G CL7N
Tecno Camon i4 CB7
Tecno Camon isky2 IN1
Tecno Camon iace KB2J
Tecno Pova 6 pro 5G LI9
Tecno Spark 6 go KE5
Tecno Spark 10 pro KL7
Tecno Pova 2 LE7
Tecno Camon 17 CG6
Tecno Spark 7 pro KF8
Tecno Camon 16 CE7
Tecno Camon 16 pro CE8
Tecno Camon 19 CL6
Tecno Pova 3 LF7N
Tecno Pova LD7
Infinix
Infinix Note 12 Pro 5G X671B
Infinix Note 12 5G X671
Infinix Hot 30 5G X6832
Infinix Hot 20 5G X666B X666C
Infinix Note 30 5G X6711
Infinix Hot 10 X682B
Infinix Note 7 X690
Infinix Note 7 X690B X690C
Infinix Note 8 X692
Infinix Note 8i X683
Infinix Note 10 X693
Infinix Hot 10i X659B X659
Infinix Hot 11s X6812
Infinix Note 11i 11i
Infinix Note 11 Note_11
Infinix Hot 10i X658E X658B
Infinix Note 7 Lite X656
Infinix Hot 40 X6836
Infinix Note 12 X663 X663C X663D
Infinix Note 12i X6819
Added MTK Models New MTK 2023 V6 Patch 2024
Infinix
Infinix Note 30 X6833B X6716B Auth V2
Infinix Note 30 Pro X678b Auth V2
Infinix Hot 40 Pro X6837 Auth V2
Infinix Note 12 Pro X676b Auth V2
Tecno
Tecno Pova 6 li6 Auth V2
Tecno Pova 6 new LI9 Auth V2
Tecno Pova 4 LG7n Auth V2
Tecno Pova 4 Pro LG8N Auth V2
Tecno Pova 5 LH7n Auth V2
Tecno Spark 20 Pro KJ6 Auth V2
Tecno Spark 20 Pro Plus KJ7 Auth V2
Samsung
SM-A015A
SM-A015AZ
SM-A015F
SM-A015G
SM-A015M
SM-A015T1
SM-A015U
SM-A015U1
SM-A015V
SM-A426U
SM-A426U1
SM-A426W
SM-A426XU
SM-A526U
SM-A526U1
SM-A526W
SM-A526XU
SM-A6060
SM-A606Y
SM-A7050
SM-A7058
SM-A705F
SM-A705FN
SM-A705GM
SM-A705MN
SM-A705U
SM-A705U1
SM-A705W
SM-A705XU
SM-A705YN
SM-A7070
SM-A7078
SM-A707F
SM-A707FN
SM-A716U
SM-A716U1
SM-A716W
SM-A716XU
SM-A736B
SM-A736BR
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
Added Repair IMEI Generic (MT67XX) BROM
Added Repair Network Security 2020/2021 BROM
Added Repair Network Security 2022 BROM
Added Read IMEI
Added backup with CID number for MTK operations
Added Forced BROM SAMSUNG Download Mode
Added OPPO MT6771 Auth Free
Added Samsung Auth Free
Samsung Galaxy Wide5(SM-E426S) Auth Free
Samsung Galaxy A13 5G(SM-A136) Auth Free
Samsung Galaxy A22(SM-A225) Auth Free
Samsung Galaxy F42 (SM-E426)Auth Free
Added new DEVICE for mtk protocol (v6)
Update GENERIC MTK V5
Update GENERIC MTK 2023
Added META Read Info All MTK CPU
Added META Factory Reset All MTK CPU
Added META Factory Reset MT62XX
Added META Repair IMEI All MTK CPU
Added in META Mode ( Infinix - Tecno - Itel ) All Model With Auth
Added MTK Preloader
Added SAMSUNG Brom Models NEW
Added META Factory Reset Direct (INFINIX-TECNO-ITEL)
Added Enable/Disable Backup
Direct Factory Reset (INFINIX-TECNO-ITEL)
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
Added Info Boot Mode
Added Read Flash /Format Disk /Write Disk
Added Network Unlock Boot Mode
Added Repair IMEI Boot Mode
Added Remove MDM Boot Mode
Added New Boot SPD V2
Added GENERIC SPD V1
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
Added Read flash
Added Repair Chip damaged (Huawei)
Update Remove ID (Huawei)
Fix OLD loader
Support Automatic Loader [OPPO/VIVO/HUAWEI/XIAOMI/ONEPLUS]
Added NEW Device ALCATEL/TCL
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
Added (Jailbreak) Backup Apple with Info
Added Disable Update/Reset/Skip Setup (One Click)
Added Disable Update/Reset/Skip Setup Ramdisk/HELLO
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 17 Users Say Thank You to easy-team For This Useful Post:
Old 05-14-2024, 13:58   #2 (permalink)
Megavee's Avatar
Member: 2496301
Thanks Meter: 43
Thanks for the update I was waiting for the Tecno Thanks so much EFT
The Following User Says Thank You to Megavee For This Useful Post:
Old 05-14-2024, 16:16   #3 (permalink)
Member: 2779917
Thanks Meter: 89
Dear eft team mtk infinix and tecno which you support in preloade or mtk usb port brom. Like x678b is supported in brom mod ?
The Following User Says Thank You to Mhdharisu For This Useful Post:
Old 05-14-2024, 18:22   #4 (permalink)
Member: 2117710
Thanks Meter: 74
11 pro fmi off successfully
Waiting for server.....OK
Checking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Activated
BuildVersion: 20F75
CPU Arch: arm64e
Device Class: iPhone
Device Name: iPhone de xxxxxxxx
Firmware Version: iBoot-8422.122.1
Device IMEI: 353xxxxxxxxx
Device MEID: 3532xxxxxxxxx
Product Name: iPhone OS
Product Type: iPhone 11 Pro
IOS Version: 16.5.1
SIM Status: kCTSIMSupportSIMStatusNotInserted
Device Serial Number: F17Cxxxxxx
DeviceID: 00008030-000569993685802E
MEID Status: SuBackup Successful.
Get Auth Info.....
OK
Apple ID:[email protected]
PET Token:GbR8yNFt2xhRi6bgBgO8BgOsdKZWRAWdlKngaUYyI6p8 OOxDtbyepne9uW7SVr/fPtZqsZk5GObqLnFgW63I4xYkbV+lSctCOYVFxp3q2imbv332u ugnXNoUAE0c/Id6fUgn1/ps9qxauaN05fiaYlb9WmxtmGfULEaB1RBLn0SidGHEhUeWBdug m1IEpSfIZ/UvwR6xFsk/0foiqqb6kXMqh1X4rBdeMc70JCLZGLq1MYqfMP3fDLji66MW5y 0tPGscuuDiVZ9sAjsUvaqBOcbexjFvHNswghm1nywwIOod32mh FoQp2ZgsXjFmEhoyZIZWpifUt7b/OEDTaFXdL+IkMYJ0U+iehrMFuPsK1gKdrGpZ61mHqJhaPMeyvq Bs1LEnaV2+zAOoqFobfriT5lHoN3d67cnIzkp3DA2I6hNW+TyG X7u8Xg8sLZcwNMtvca4Z4baJce3e0KGM3xEcmhwrI4i2PET
Model:iPhone 11 Pro
Device Name:iPhone de xxxxxx
MODE:CLEAN
Status:OFFLINE
Status Code:200
Removed:Success ✅
1-Turn off Wi-Fi and mobile data directly through your phone's settings.2-Check your phone's IMEI and make sure icloud off.3-After that, proceed to format the device.
Operation {Remove Icloud Open Menu with BACKUP} ID: EF859C523909C62D
Elapsed time 01:25 -- Version 4.7.5 Build 001
The Following 4 Users Say Thank You to sbtech For This Useful Post:
Old 05-14-2024, 21:44   #5 (permalink)
Member: 3041584
Sonork: Ok
Thanks Meter: 4
good team
Old 05-15-2024, 01:12   #6 (permalink)
Member: 3044478
Thank for update very fast
best team
Old 05-15-2024, 04:07   #7 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Helllo good update please add Exynon Samsung models the next update.
Thanks
Old 05-15-2024, 05:01   #8 (permalink)
Member: 2629080
Thanks Meter: 19
Game Center It does not activate There is a way
BuildVersion: 20C65
CPU Arch: arm64e
Device Name: iPhone
Firmware Version: iBoot-8419.60.44
Device IMEI: 356875114080109
Device MEID: 35687511408010
IOS Version: 16.2
SIM Status: kCTSIMSupportSIMStatusReady
Device Serial Number: F4GFHXNVN741
DeviceID: 00008030-0009148E0CF9402E
MEID Status: Supported
Get Auth Info.....
OK
PET Token:GbRVeeL1iwZJFkwOuT3N2XZbwA8YvKkzvqMS2v8wur6X JC2eMwmpuoAGQCCiLk6gxJYyW78pKeYp4NsPE7syylt8tgGApk 6i71D2ZrclH+qFu32nWWFLrHly4PaKmMaBFC7O3HYhStA2tOMu BifQ9FDeg7hLRIpRKSo7F2mwJWe1V6Zr2GlGiXwgn4s6B1Wa+X q5BcrCq3ZcWfN+0FCaK9xUHU8vRaANDnPmKcH75o8qztL+LTxZ ZTxqJWuhXTSiUu9UAroUO0oejJ5tPmSDD5geie7bt8F8lR8KfX 5lSUCf5FMshJElogpnzHIbtrpFkG7xzgJRMTBew3Kn4kBGdINq 2Y9OpoZfN0AGvtD2QREVSM12d1leGkKj9w8Oi57PSLozgz3qdC 9M7+u5Heu2AYqxIGyUKC1nqlFMvqzDNi06PGlN1FGFlX2QNJJF NzMexrrbCRW5RuN0dqMwYBedvilhoBBPPET
ERROR: DATA NOT FOUND OR TOKEN EXPIRED
Please follow the instructions below and try again:
If it expires, you need to turn the game center off and on again and backup again to get the token back
Token Expired. status code: 401
Operation {Remove Icloud Open Menu with BACKUP} ID: 47566DE3F1CD2885
Elapsed time 00:59 -- Version 4.7.5 Build 001
Old 05-15-2024, 06:08   #9 (permalink)
Member: 844028
Sonork: 3654
Thanks Meter: 5
good update please unlock demo vivo v30 y100
Old 05-15-2024, 07:10   #10 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 571
Always good update easy team....thanks
Old 05-15-2024, 09:25   #11 (permalink)
yes sir suppprted v6 or v5
Old 05-15-2024, 10:52   #12 (permalink)
Member: 2779917
Thanks Meter: 89
Thankx let me give it try
Old 05-15-2024, 11:13   #13 (permalink)
BuildVersion: 20C65
CPU Arch: arm64e
Device Name: iPhone
IOS Version: 16.2
Get Auth Info.....
OK
https://www.youtube.com/watch?v=iFW1...nnel=EFTDongle
Old 05-15-2024, 12:31   #14 (permalink)
Member: 3054148
BuildVersion: 19H384
CPU Arch: arm64
Device Name: Ronjon’s iPhone
Firmware Version: iBoot-7459.140.15
Device IMEI: 355735075969818
Device MEID: 35573507596981
Product Type: iPhone 6s Plus
IOS Version: 15.8.2
Device Serial Number: FCGTD2QUHFM5
DeviceID: 923b6c47dddc5feec9abb6d12c4d6b65c5b26fc3
Get Auth Info.....
2024/05/15 17:28:56 Bad password
Old 05-15-2024, 17:55   #15 (permalink)
Member: 181405
Thanks Meter: 249
BuildVersion: 20C65
CPU Arch: arm64e
Device Name: iPhone de Gsm-unlock
Device IMEI: 3579598
Device MEID: 357959
IOS Version: 16.2
Device Serial Number: FFXJXS
DeviceID: 00008030-000E604822D8202E
Info.....Backup Successful.
Get Auth Info.....
OK
PET Token:GVvFa3Tj+8EKw4AZEv//2Kw1AorY3D90wZihf5K7jbSPEydcmajP4t+ykG6WnJA10BMChr hvGfcuvCyFQXuQOlfa5AdOdqPzeE45B8x3/2I26kLAuWpemsccYkfg4Mqi4wjAzaUqnFnPzRaUWAmpErlQXHa Yv49REINJyFPFIbRidWA2zyCXF5+pOdghvjFzjGyEhSicTVict HduuzMrrWrfeCPjKD9tEPiwANNDI7g3U2B8HMI2sm4QMZSgBYD/WwtwqJYMmGreSOgSwkuGDUoefntwsphFFwoWSZUcBoOLajOkNL 26S3M4qoePkqiyMEDZYyTFMG7nQfn3d/3UmL1gtZzgdxxwRz3hW3uNljs2gRs2n0CxF6aAgtF2DGwxjbv9 9G/EZWD++5JfDKmQdHLkRmQ+nsj2tUrUP0DJ0ou35pRVhJBbPXA7J 9Si+l69nz0ovfw=PET
Model:iPhone 11
Device Name:iPhone de Gsm-unlock
MODE:CLEAN
Status:OFFLINE
Status Code:200
Removed:Success ✅
Operation {Remove Icloud Open Menu with BACKUP} ID: F950CBB4E8857208
Elapsed time 02:20 -- Version 4.7.5 Build 001
Page generated in 0.13950 seconds with 9 queries
