Old 05-20-2024, 13:02   #1 (permalink)
Thanks Meter: 21,546
EFT Pro Dongle Update V4.7.6 Is released [Added Qualcomm Models Samsung V2]
EFT Pro Dongle Update V4.7.6 Build 001 is released :
What's New :
[Qualcomm]
★ FRP
★ Factory Reset
[Qualcomm]
SM-A207F
SM-E025F
SM-F7110
SM-F711B
SM-F711BR
SM-F711D
SM-F711J
SM-F711N
SM-F711U
SM-F711U1
SM-F711W
SM-F711XU
SM-F721B
SM-F721BR
SM-F721U
SM-F721U1
SM-F721W
SM-F721XU
SM-G998U1
A207f U4 Reset FRP With EDL Cable
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
Added Repair IMEI Generic (MT67XX) BROM
Added Repair Network Security 2020/2021 BROM
Added Repair Network Security 2022 BROM
Added Read IMEI
Added backup with CID number for MTK operations
Added Forced BROM SAMSUNG Download Mode
Added OPPO MT6771 Auth Free
Added Samsung Auth Free
Samsung Galaxy Wide5(SM-E426S) Auth Free
Samsung Galaxy A13 5G(SM-A136) Auth Free
Samsung Galaxy A22(SM-A225) Auth Free
Samsung Galaxy F42 (SM-E426)Auth Free
Added new DEVICE for mtk protocol (v6)
Update GENERIC MTK V5
Update GENERIC MTK 2023
Added META Read Info All MTK CPU
Added META Factory Reset All MTK CPU
Added META Factory Reset MT62XX
Added META Repair IMEI All MTK CPU
Added in META Mode ( Infinix - Tecno - Itel ) All Model With Auth
Added MTK Preloader
Added SAMSUNG Brom Models NEW
Added META Factory Reset Direct (INFINIX-TECNO-ITEL)
Added Enable/Disable Backup
Direct Factory Reset (INFINIX-TECNO-ITEL)
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
Added Info Boot Mode
Added Read Flash /Format Disk /Write Disk
Added Network Unlock Boot Mode
Added Repair IMEI Boot Mode
Added Remove MDM Boot Mode
Added New Boot SPD V2
Added GENERIC SPD V1
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
Added Read flash
Added Repair Chip damaged (Huawei)
Update Remove ID (Huawei)
Fix OLD loader
Support Automatic Loader [OPPO/VIVO/HUAWEI/XIAOMI/ONEPLUS]
Added NEW Device ALCATEL/TCL
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
Added (Jailbreak) Backup Apple with Info
Added Disable Update/Reset/Skip Setup (One Click)
Added Disable Update/Reset/Skip Setup Ramdisk/HELLO
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 12 Users Say Thank You to easy-team For This Useful Post:
Old 05-20-2024, 13:53   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
What is working proxy ip for open menu?
Old 05-20-2024, 14:17   #3 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 832
Hi sir.
What about vivo MTK latest Security???
Old 05-20-2024, 17:03   #4 (permalink)
Member: 1914849
Thanks Meter: 43
hi sir how to connect samsung V2 to remove frp for exemple a207f
Old 05-20-2024, 17:10   #5 (permalink)
https://www.youtube.com/watch?v=iFW1...nnel=EFTDongle
Old 05-20-2024, 19:51   #6 (permalink)
Member: 3055920
hi sir,
can you please add oppo mtk 6779 (helio p90) in the very next update?��
devices like:
oppo reno z
oppo reno 2z
Old 05-20-2024, 21:42   #7 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 589
Samsung a207f bit5 support...?
Old 05-21-2024, 17:56   #8 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 669
Originally Posted by DA7DA7 View Post
hi sir,
devices like:
oppo reno z
oppo reno 2z
try here sir
Old 05-21-2024, 18:59   #9 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 669
test point or EDL cable
Old 05-21-2024, 19:07   #10 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 669
yes sir
The Following User Says Thank You to Gsm-Ahmed For This Useful Post:
Old 05-22-2024, 22:55   #11 (permalink)
Member: 217170
Thanks Meter: 46
Samsung Note 10 + N975F FRP Reset?
Hello how reset FRP in this model N975F ?????
Old 05-25-2024, 08:56   #12 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 77
Nice update can it work for oppo cph1831 Qualcomm i want to remove the password
Sent from my M2103K19G using Tapatalk
The Following 2 Users Say Thank You to Y Michael For This Useful Post:
Old 05-29-2024, 22:54   #13 (permalink)
Member: 2310167
Thanks Meter: 2
erreur transfert .server replied forbidden please check your internet
Old 05-30-2024, 15:03   #14 (permalink)
Member: 2310167
Thanks Meter: 2
erreur transfert .server replied forbidden please check your internet on eft pro
Old 05-30-2024, 15:48   #15 (permalink)
Member: 2310167
Thanks Meter: 2
erreur transfert .server replied forbidden please check your internet on eft pro on mtk and qualcomm
Page generated in 0.27241 seconds with 8 queries
