Old 04-11-2023, 08:34   #31 (permalink)
Member: 2514129
Sonork: Univ. Gsm Ra-Hos
Thanks Meter: 27
Wow ! Good update eft
Old 04-11-2023, 09:07   #32 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,344
Good Update EFT Keep it Up......Update to Build 0.2
Old 04-11-2023, 09:07   #33 (permalink)
allumts's Avatar
Member: 1564612
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 04-11-2023, 10:10   #34 (permalink)
Member: 334094
Sonork: none
Thanks Meter: 73
happy ramadan kareem...
Nice update
Old 04-11-2023, 10:31   #35 (permalink)
Member: 320108
Thanks Meter: 18
i cant find FRP remove on mpt.. please advise
Old 04-11-2023, 10:50   #36 (permalink)
s@lwos's Avatar
Member: 281998
Thanks Meter: 115
Originally Posted by easy-team View Post
If it accepts flashing, flash it sir first. After flashing, do the process from the dongle
The phone does not enter Download Mode as it is blocked in all its functions.
Old 04-11-2023, 11:36   #37 (permalink)
Member: 2926422
Thanks Meter: 2
after 4.4.5 update it says dongle is not connected.
Well, it is, it was working in 4.4.4 right before
Old 04-11-2023, 11:41   #38 (permalink)
Member: 2926422
Thanks Meter: 2
ok, it's working now. Had to scratch the SIM and contacts a bit.
The Following User Says Thank You to saspipi813 For This Useful Post:
Old 04-11-2023, 12:05   #39 (permalink)
amr_ibrahim's Avatar
Member: 119435
Thanks Meter: 52
after update FRP on Samsung tab not showing
Old 04-11-2023, 19:57   #40 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,998
Redmi 9 Power Daig Fail
Connecting to device.....OK
Reading device info.....OK
Baseband Version: A.1.0-00505.1-KAMORTA_GEN_PACK-3,A.1.0-00505.1-KAMORTA_GEN_PACK-3
Android version: 12
Device SDK: 31
Device data encryption: encrypted
Device Hardware: qcom
Device CPU: arm64-v8a
Device Factory: Xiaomi
Device Model: M2010J19SI
Device IMEI:
Root status.....Not Rooted
Waiting for server.....OK
Preparing.....OK
Enable Diag....failed
Operation {Enable Diag} ID: 43D07970F4E047B9
Elapsed time 00:04 -- Version 4.4.5 Build 004
Old 04-11-2023, 20:27   #41 (permalink)
Thanks Meter: 20,951
Android version: 12
Device SDK: 31
Device IMEI:
Preparing.....OK
Install this manually on a phone and repeat the process
https://tool.dongle.dl12.easy-firmwa...files/Diag.apk
Old 04-11-2023, 23:54   #42 (permalink)
Member: 2510757
Thanks Meter: 101
very good thnks easy tem for this ubdate .
Old 04-12-2023, 00:36   #43 (permalink)
Member: 95541
Thanks Meter: 4
The Huawei MTK chipset has not been updated for a long time, and none of the recently encountered Huawei MTK chipset machines can successfully remove the ID, all of which have failed
Waiting for Device Connection..
USB PORT: MediaTek USB Pont (COM12
Port: MediaTek UsB Port (COM12)
Manufacturer: MediaTek Inc.
OPEN COM PORT...OK
Handshake... OK
Waiting for server....... OK
Read CHIP ]D... OK
HW-CODE: 0X886
CPU: MT6873
Read Chin Version... Ok
HW-SUBCODE- 0XBA00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Read Phone Configuration... OK
Bypass Security Protection... OK
Waiting for server........ OK
Dump EMI Config...Ok
Send Protection Files BROM... OK
Check BRON status... OK
Setup DEVICE...OK
Init HARDWARE... OK
Setup DEVICE... OK
Read DEVICE Status.. BROM
Init EXT RAM... FAIL
PORT ERRI READ TIMED OUT
Old 04-12-2023, 08:37   #44 (permalink)
Member: 2499990
Thanks Meter: 4
Update to Build 0.5 error9
eftpro update error
Old 04-12-2023, 09:35   #45 (permalink)
eftpro update error
delete folder data and file user sir
Page generated in 0.19903 seconds with 9 queries
