Old 05-06-2023, 09:09   #31 (permalink)
Member: 1143337
Thanks Meter: 103
Hello Team eftsu.com not working long time no root files on it
please fix it thank you.
Old 05-06-2023, 14:50   #32 (permalink)
Member: 463222
Thanks Meter: 29
Hello team;
1-plz how to connect Rockchip devices to unlock/read/write or remove frp ?
(I tried with other tool can do it, may be prb. of drivers?)
2- how to remove demo on Oppo A5 2020 ?
Old 05-06-2023, 23:13   #33 (permalink)
amrMHF's Avatar
Member: 710690
Thanks Meter: 901
please next update add operations log, we need this option some times
The Following User Says Thank You to amrMHF For This Useful Post:
Old 05-11-2023, 19:11   #34 (permalink)
candelwizzy's Avatar
Member: 853308
Thanks Meter: 61
Post
Please add FRP reset of new Tecno Phones without test point.
Old 05-13-2023, 11:02   #35 (permalink)
Member: 853308
Thanks Meter: 61
Post Ihone 8 Hello Bypass done without serial number change
Checking iDevices.....OK
Preparing paths.....OK
Checking SSH......P:15..OK
Path:Backups/96e2a3565388d08cb55b84539e284eec0f63bc7f
Wildcard File:Not Found
Activation Files (Hello Screen).......OK
Disable Reset Settings and Updates....OK
Skip Setup...OK
Operation {Hello Screen:Activate device iCloud 15.x/16.x} ID: DD9CBDF321A09EEB
Elapsed time 00:11 -- Version 4.4.6 Build 001
p, li { white-space: pre-wrap; }
The Following User Says Thank You to candelwizzy For This Useful Post:
Old 05-14-2023, 16:08   #36 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,468
after update eft pro 446 , automatically download MTK FILES but its very slowly
after few hours just proses 37%
if i do close "MTK DOWNLOAD FILES" AND RUN SW again ,i see "profile error " then close suddenly sw and not run again
what is problem and how can i solve ?
Old 05-14-2023, 16:34   #37 (permalink)
Thanks Meter: 20,610
Sir, this is a problem with your internet. Delete the data folder completely, or download the interface again from here
https://easy-firmware.com/index.php?...file&id=250229
Page generated in 0.13783 seconds with 9 queries
