Old 07-24-2023, 13:09   #31 (permalink)
Gsm::Boiragi::'s Avatar
Member: 1816848
Thanks Meter: 103
please quick responds
Old 07-24-2023, 13:24   #32 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 56
After successful backup of iphone 7
And restored successfully
But iCloud is still on the phone what can be the issue
I have tried 10 times now successfully restored but still iCloud on the phone what can i do... Pls help
Sent from my M2103K19G using Tapatalk
Old 07-24-2023, 13:53   #33 (permalink)
Thanks Meter: 20,332
It is a phone that has been previously skipped, sir. If all the process is successful, you can repeat the process without connecting a Wi-Fi network or a SIM card
Old 07-24-2023, 15:38   #34 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 56
I have repeated the process without Wi-fi and sim but still not working i have tried over and over again but still not working and backup was successful restore was still successful but not working
Old 07-24-2023, 16:26   #35 (permalink)
A phone that has already been skipped iCloud, sir, is not supported by a passcode
Old 07-24-2023, 17:30   #36 (permalink)
Member: 2406539
Thanks Meter: 92
trying to update xiaomi Mi 8 lite but connection closed automatically by showing warning.. "other reason"..
Checking devices.....OK
Waiting for server.....OK
Version: V11.0.5.0.PDTMIXM
Device: platina_global
language: en
SN: 0x3945e7b3
Android version: 9
Getting MD5 hash for file: miui_MI8LiteGlobal_V11.0.8.0.PDTMIXM_bb4de77c17_9. 0.zip
MD5 hash obtained successfully: bb4de77c177c77f223db3500e39c837c
Operation {Flash Ota Frome File(Use Info/Imei/sn)} ID: C4D475D0D4340D95
Elapsed time 00:32 -- Version 4.5.0 Build 001
tried with both available option, but still doing same.. warning "other reason".
language: en
SN: 0x3945e7b3
Android version: 9
MD5 hash:bb4de77c177c77f223db3500e39c837c
Operation {Download && Flash Ota} ID: 4568F59339D237D9
Elapsed time 00:57 -- Version 4.5.0 Build 001
Old 07-24-2023, 17:36   #37 (permalink)
language: en
SN: 0x3945e7b3
Android version: 9
language: en
SN: 0x3945e7b3
Android version: 9
delete folder data-mi and try again sir
Old 07-24-2023, 17:44   #38 (permalink)
Member: 2406539
Thanks Meter: 92
already deleted and tried but still showing same..
this phone is Mi account locked, can it be flashed if Mi account is ON..?
Old 07-24-2023, 17:59   #39 (permalink)
Sir, we apologize for inconveniencing you, we just need you to transfer the Pro interface to a new disk and a new folder, make sure the internet speed is working fine, and try again.
Old 07-24-2023, 18:12   #40 (permalink)
Member: 2406539
Thanks Meter: 92
no, it's not working.. changed location from C: drive to E: drive,
downloaded everything new and tried but still not working, showing error.
"other reason".
The Following User Says Thank You to TMAC1122 For This Useful Post:
Old 07-25-2023, 00:58   #41 (permalink)
"other reason".
Sir, the phone has been changed. IMEI is not the main phone
Old 07-25-2023, 05:47   #42 (permalink)
pradyumnasahoo's Avatar
Member: 1267573
Thanks Meter: 134
Arrow
delete folder data - mi and try again sir
same problem ,i will change folder desktop to E drive this same error.
did not open dialog box to sign in....
Old 07-25-2023, 08:08   #43 (permalink)
Member: 209146
Thanks Meter: 31
Version: V12.0.2.0.QJIEUXM
Device: monet_eea_global
language: pl
SN: 0xe0de626e
Android version: 10
Getting MD5 hash for file: miui_MONETEEAGlobal_V12.0.2.0.QJIEUXM_12bc504f22_1 0.0.zip
MD5 hash obtained successfully: 12bc504f22eb04026a6430df40fd74c8
Operation {Flash Ota Frome File(Use Info/Imei/sn)} ID: BDE4D90E6AB5A729
Elapsed time 00:39 -- Version 4.5.0 Build 001
Old 07-25-2023, 11:30   #44 (permalink)
Member: 1699998
Sonork: 100.1610140
Thanks Meter: 7
EFT Pro Dongle Update V4.5.0 Build 001 is released :
What's New :
[ XIAOMI] First In The World
  • Added New Listing ( UPDATE )
MI Assistant Mode (Sideload)
You Need To Login With Xiaomi Account
  • Added Download & Flash OTA MI Assistant Mode (Sideload)
  • Added Flash OTA From File MI Assistant Mode (Sideload)
Xiaomi Redmi Note 10S download file and update done by EFT Pro 4.5.0
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Added Forced BROM (method 1)
Added Forced BROM (method 2)
Added Forced BROM without Test Point
Added Samsung forced BROM (PIT Method)
Added write Huawei (UPDATE APP) firmware
Added write Samsung (TAR) firmware
Added write Oppo/Realme (OFP) firmware
Added write EMMC Dump firmware
Added Vivo MT6765 PreLoader
Added direct unlock network MTK (BROM)
Added (Vivo) Disable MDM lock Supported for (2020 to Up)
Added (Vivo) Disable MDM lock Supported for (2019)
Added (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Added (Vivo) Disable demo mode
Added (Vivo) Disable orange msg
Added (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Added New Security 2022/2023 for MTK
Added New Device Support for MTK devices
Added New Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
[SPD]
Added new models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Added New Device Support for Qualcomm devices
Added New Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Added New Unlock ID (Huawei)
Added New Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Added Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
Added NEW BOOT PASSCODE/HELLO FOR (IPAD)
Added New Read Account From Backup Folder
[ Rockchip ]
Update Read/Write Flash
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
Good Update Allways ........
The Following User Says Thank You to nido1684 For This Useful Post:
Old 07-25-2023, 18:12   #45 (permalink)
marcin7904's Avatar
Member: 290272
Thanks Meter: 428
Build 002 MI account login failed
https://www.youtube.com/watch?v=iN-M6PNZFaE
The Following User Says Thank You to marcin7904 For This Useful Post:
Page generated in 0.24997 seconds with 8 queries
