Old 08-03-2023, 14:19   #16 (permalink)
Member: 1745682
Thanks Meter: 48
This is a great update
Kudos to eft team for adding unlock and relock bootloader of spd chips.
I tested infinix X6517 bootloader unlock and it worked.
Pls spd partition manager for editing partitions
Old 08-03-2023, 14:37   #17 (permalink)
Member: 154346
Thanks Meter: 37
note 20 ultra 5g 2023 security not work remove frp
Old 08-03-2023, 14:58   #18 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,317
Hello, tested not work, new and lastest iOS require new method for PWNED, also boot from old version loaders not work, need update for new versions please!!!
Originally Posted by easy-team View Post
New versions that have not been tried, you can try, sir, no problem
Old 08-03-2023, 15:16   #19 (permalink)
Member: 2801230
Originally Posted by Ahmad-Hzzory View Post
Best of Best
Samsung
Added Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Samsung frp Security patch july workiging to ?
Old 08-03-2023, 18:09   #20 (permalink)
Member: 2839458
Thanks Meter: 5
thank you for the update, keep up the good work.
The Following User Says Thank You to azizmobile For This Useful Post:
Old 08-08-2023, 22:04   #21 (permalink)
morton1984's Avatar
Member: 720579
Sonork: 100.1591812
Thanks Meter: 26
yes ineed that tow lik pandora box
Originally Posted by sajuahmed View Post
Pls add wipe and restore partitions in next update
ineed that olso lik pandora box
Page generated in 0.15669 seconds with 9 queries
