Old 08-10-2023, 14:19   #1 (permalink)
Thanks Meter: 20,332
EFT Pro Dongle V4.5.2 is Released Fix MTK Filter & Network Unlock
EFT Pro Dongle Update V4.5.2 Build 001 is released :
What's New :
[ MTK ]
Added Fix MTK Filter
Added Network Unlock
Realme:
Realme C33 2023
Realme C53
Realme N53
Realme C30
Realme C30S
Realme C35
Realme C55
Realme N55
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Added Forced BROM (method 1)
Added Forced BROM (method 2)
Added Forced BROM without Test Point
Added Samsung forced BROM (PIT Method)
Added write Huawei (UPDATE APP) firmware
Added write Samsung (TAR) firmware
Added write Oppo/Realme (OFP) firmware
Added write EMMC Dump firmware
Added Vivo MT6765 PreLoader
Added direct unlock network MTK (BROM)
Added (Vivo) Disable MDM lock Supported for (2020 to Up)
Added (Vivo) Disable MDM lock Supported for (2019)
Added (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Added (Vivo) Disable demo mode
Added (Vivo) Disable orange msg
Added (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Added New Security 2022/2023 for MTK
Added New Device Support for MTK devices
Added New Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Added Fix Tool Dl Image Fail
Added Reset Frp Lock WriteFile
[SPD]
Added new models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Added Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Added New Device Support for Qualcomm devices
Added New Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Added New Unlock ID (Huawei)
Added New Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Added Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
Added NEW BOOT PASSCODE/HELLO FOR (IPAD)
Added New Read Account From Backup Folder
[ Rockchip ]
Update Read/Write Flash
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 15 Users Say Thank You to easy-team For This Useful Post:
Old 08-10-2023, 14:26   #2 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 232
Hello dear team now possilke unlock A037u bit 3 mtk cpu?
Old 08-10-2023, 14:39   #3 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,988
Oppo A5 2020 pinlock Format Update Need
Old 08-10-2023, 15:06   #4 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,373
Plz Add This Option
Remove Factory Reset Protection aka. Remove FRP (no need of *#0*# )
Remove / Unlock Knox Guard
Change CSC aka. Country-Specific Code change
Factory Reset
Remove Find My Mobile setting, Remove / Unlock Samsung Lost Mode
Remove Warning Logos and Messages (e.g. Bootloader Unlock Warning)
The Following 3 Users Say Thank You to haji rahim For This Useful Post:
Old 08-10-2023, 16:02   #5 (permalink)
Member: 2383501
Sonork: 100.1660513
Thanks Meter: 170
Perfect
Realme C33 2023
Realme C53
Realme N53
Realme C30
Realme C30S
Realme C35
Realme C55
Realme N55
Old 08-10-2023, 17:25   #6 (permalink)
Member: 2691652
Thanks Meter: 60
Samsung frp 2023 not work S23
The Following User Says Thank You to BOSSVORS For This Useful Post:
Old 08-10-2023, 17:35   #7 (permalink)
not supported sir this model
Old 08-10-2023, 18:48   #8 (permalink)
Member: 2839458
Thanks Meter: 5
thank you very much, keep up the good work.
Old 08-10-2023, 23:15   #9 (permalink)
Member: 3041584
Sonork: Ok
thank you very much.
Old 08-11-2023, 06:49   #10 (permalink)
Member: 2973928
Thanks Meter: 245
Thnx For New Update But Team Plzzz On Your Service EFTSU Website & EFTSU Tool Thnx
Old 08-11-2023, 07:38   #11 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,332
good update
i have realme c33 rmx3627 model network locked phone
but i can't found realme unlock option
The Following 3 Users Say Thank You to pintu_das For This Useful Post:
Old 08-11-2023, 07:52   #12 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 520
Allways good update.........
Old 08-11-2023, 19:29   #13 (permalink)
amrMHF's Avatar
Member: 710690
Thanks Meter: 894
thank you so much EFT team ♥
Old 08-12-2023, 07:44   #14 (permalink)
Originally Posted by pintu_das View Post
good update
Here by mtk sir
The Following 3 Users Say Thank You to easy-team For This Useful Post:
Old 08-12-2023, 08:34   #15 (permalink)
Member: 2532428
Thanks Meter: 34
Please add make knox firmware for exynos samsung phones
The Following User Says Thank You to BootYa For This Useful Post:
Page generated in 0.20494 seconds with 8 queries
