Old 09-02-2023, 22:21   #1 (permalink)
Thanks Meter: 20,332
EFT Pro Dongle V4.5.4 is Released SAMSUNG Remove KG Lock Direct (MTP)
EFT Pro Dongle Update V4.5.4 Build 001 is released :
What's New :
[ SAMSUNG ]
Added New Remove KG Lock Direct (MTP)
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Added Forced BROM (method 1)
Added Forced BROM (method 2)
Added Forced BROM without Test Point
Added Samsung forced BROM (PIT Method)
Added write Huawei (UPDATE APP) firmware
Added write Samsung (TAR) firmware
Added write Oppo/Realme (OFP) firmware
Added write EMMC Dump firmware
Added Vivo MT6765 PreLoader
Added direct unlock network MTK (BROM)
Added (Vivo) Disable MDM lock Supported for (2020 to Up)
Added (Vivo) Disable MDM lock Supported for (2019)
Added (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Added (Vivo) Disable demo mode
Added (Vivo) Disable orange msg
Added (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Added New Security 2022/2023 for MTK
Added New Device Support for MTK devices
Added New Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Added Fix Tool Dl Image Fail
Added Reset Frp Lock WriteFile
[SPD]
Added new models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Added Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Added New Device Support for Qualcomm devices
Added New Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Added New Unlock ID (Huawei)
Added New Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Added Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
Added NEW BOOT PASSCODE/HELLO FOR (IPAD)
Added New Read Account From Backup Folder
[ Rockchip ]
Update Read/Write Flash
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 25 Users Say Thank You to easy-team For This Useful Post:
Old 09-03-2023, 03:45   #2 (permalink)
Member: 2973928
Thanks Meter: 245
Good update team keep it up
Old 09-03-2023, 04:34   #3 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,946
Old 09-03-2023, 04:59   #4 (permalink)
Member: 1657674
Thanks Meter: 849
It's great update EFT Great Team
Old 09-03-2023, 06:49   #5 (permalink)
Member: 257603
Sonork: 100.1605284
Thanks Meter: 145
good work team keep it up
Old 09-03-2023, 07:08   #6 (permalink)
Member: 98928
Thanks Meter: 455
I think this is what we need nowadays, Thank you EFT team.
Old 09-03-2023, 07:44   #7 (permalink)
pradyumnasahoo's Avatar
Member: 1267573
Thanks Meter: 134
A235F KG Unlock done
The Following 2 Users Say Thank You to pradyumnasahoo For This Useful Post:
Old 09-03-2023, 08:01   #8 (permalink)
Member: 2067643
Sonork: 1611265
Thanks Meter: 452
Connecting to device.....OK
Reading device info.....OK
Baseband Version: A022FXXS3BWA1,A022FXXS3BWA1
Device bootloader: A022FXXS3BWA1
Device warranty bit: 0
Device Firmware: A022FXXS3BWA1
Android version: 11
Device SDK: 30
Device data encryption: encrypted
Firmware Country: SOUTH AFRICA
Device Hardware: mt6739
Device CPU: armeabi-v7a
Device Factory: samsung
Device Model: SM-A022F
Device IMEI: 350843983024935
Root status.....Not Rooted
Preparing paths.....OK
Remove KG Lock.....step2......The phone is not supported
Operation {Remove KG Lock Direct} ID: 5398EAAE71DE8130
Elapsed time 02:16 -- Version 4.5.4 Build 001
Old 09-03-2023, 08:37   #9 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
Baseband Version: M215FDDU2BUE1,M215FDDU2BUE1
Device Arch: exynos9610
Device bootloader: M215FXXU2BUF1
Device selinux: enforcing
Device Firmware: M215FXXU2BUF1
Android version: 11
Device SDK: 30
Firmware Country: India
Device Hardware: exynos9611
Device CPU: arm64-v8a
Device Model: SM-M215F
Device IMEI: 354984113379017
Operation {Remove KG Lock Direct} ID: 6B7AE22E0FE6E78F
Elapsed time 01:05 -- Version 4.5.4 Build 001
Old 09-03-2023, 08:37   #10 (permalink)
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
Android version: 11
Device SDK: 30
Old 09-03-2023, 08:57   #11 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 296
Good update Easy team
The Following User Says Thank You to GSM KPK For This Useful Post:
Old 09-03-2023, 09:52   #12 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
please add all vivo FB to EDL
Old 09-03-2023, 10:05   #13 (permalink)
Member: 515940
Thanks Meter: 29
great update EFT TEAM
but which samsung model support?
all new samsung or some models/
thx
BR..
SAiNi
The Following User Says Thank You to khudda1234 For This Useful Post:
Old 09-03-2023, 10:07   #14 (permalink)
thx
BR..
SAiNi
Not all models are supported as this is a beta version
The Following User Says Thank You to easy-team For This Useful Post:
Old 09-03-2023, 11:31   #15 (permalink)
Member: 1263652
Thanks Meter: 30
Good update .... kg lock remove permanently ???
The Following User Says Thank You to moulaha For This Useful Post:
Page generated in 0.24986 seconds with 8 queries
