Old 09-15-2023, 20:49   #31 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 520
Good update.....keep it up
Old 09-16-2023, 02:16   #32 (permalink)
Member: 2406539
Thanks Meter: 92
samsung frp lock remove menu not showing with dial code, any solution..?
can you please add paid solution to remove samsung frp lock like other tools..?
Old 09-16-2023, 07:45   #33 (permalink)
Member: 3041332
Thanks Meter: 2
15.7.9 tested thanks
Originally Posted by easy-team View Post
Depending on the version of your phone
15.7.9 tested i dont know on 16 if support
Old 09-16-2023, 10:40   #34 (permalink)
lsrfrz's Avatar
Member: 931565
Sonork: 100.1626372
Thanks Meter: 45
IPHONE 8 4.7_P3_16.6.1 BYPASS DONE ON ONE CLICK
PHONE RETART PROBLEM...
Test Signed Drivers is....ON
Preparing.....OK
Fix Drivers.........OK
Check BOOT.....NO
Reading iDevice info.....OK
Device NAME: iPhone 8 (GSM)
Product NAME: iPhone10,4
Device MODEL: d201ap
Device ECID: 0x125c2834f1802e
Device CPID: 8015
Device SRTG: IBOOT-3332.0.0.1.23
Device MODE: DFU
Device CPU: A11
Waiting for server.....OK
Checking PWNDFU.....NO
iDevices PWNDFU :.....
Checking Drivers .....Ok
Device CPU: A11
Preparing.....OK
PWNDFU IS.....Failed
Preparing.....OK
NO
Device is already in pwned DFU mode
Path:VID_PID:USB\VID_05AC&PID_1227\CPID:8015_CPRV: 11_CPFM:03_SCEP:01_BDID:0A_ECID:00125C2834F1802E_I BFL:3C_SRTG:[IBOOT-3332.0.0.1.23]_PWND:[GASTER]
Preparing.....OK
Exploiting Device [1]....
Sending File (iboot).....Failed
Sending File (iboot).....OK
Sending File (devicetree).....OK
Sending File (ramdisk).....OK
Sending File (adc).....OK
Sending File (trustcache).....OK
Sending File (kernel).....OK
Successfully!
Checking iDevices.....OK
Checking SSH......P:16..P:15..P:8..OK
Mounting IPhone/Ipad partition (Hello/Passcode).......OK
BuildIDC42F44E-4955-11EE-867F-F7EE2D005372
ProductBuildVersion:20G81
ProductCopyright:1983-2023 Apple Inc.
ProductName:iPhone OS
ProductVersion:16.6.1
SystemImageID:EB73E3E1-17C2-4224-BD68-270648554C22
Preparing paths.....OK
Checking SSH......P:8..OK
Path:Backups/130c6b25dc14b2d29e461223c60eee5ebd277341
Wildcard File:Not Found
Activation Files (Hello Screen).......OK
Disable Reset Settings and Updates....OK
Skip Setup...OK
Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: FA258E4CC6AA2D7B
Elapsed time 02:48 -- Version 4.5.5 Build 001
Old 09-16-2023, 13:10   #35 (permalink)
Thanks Meter: 20,332
Preparing.....OK
Check BOOT.....NO
Device CPID: 8015
Device MODE: DFU
Device CPU: A11
Device CPU: A11
Preparing.....OK
Preparing.....OK
NO
Preparing.....OK
Successfully!
Skip Setup...OK
Just update the phone without losing data
Old 09-16-2023, 13:15   #36 (permalink)
Member: 1759100
Thanks Meter: 6
please add support for iphone 6 and 6plus pwnd and ramdisk passcode backup and support for honor x6 vne-lx2 mtk frp reset
Old 09-16-2023, 15:28   #37 (permalink)
support for iphone 5s and 6 and 6plus pwnd and ramdisk passcode backup and support restore passcode
Old 09-16-2023, 15:31   #38 (permalink)
Member: 1759100
Thanks Meter: 6
It's been added already?
Sent from my INE-LX2 using Tapatalk
Old 09-16-2023, 15:32   #39 (permalink)
Yes, they were supported, sir
Old 09-16-2023, 15:33   #40 (permalink)
Member: 1759100
Thanks Meter: 6
Thanks!
Please as support for Honor X6 VNE-LX2
The Following User Says Thank You to Don mali For This Useful Post:
Old 09-16-2023, 20:53   #41 (permalink)
Member: 2588546
Sonork: 1676974
Thanks Meter: 4
sm-a025m (A03s) americas model frp error
hi
a02s giving me error when i perfoming frp reset
Searching for Qualcomm 9008 port.....Detected {COM5}
Loading Programmer.....OK
Setting up.....OK
Reading hardware info.....OK
Serial number: 0xc73e9164
Hardware ID: 0x0009a0e1
OEM Private key: 0x3ccefae4cacf8160ef95a9c7d10c9aa7aa7e9664b75c5238 df67a3c4e273bee2
Software version: 0x00000001
Sending programmer.....Failed: Unknown error
Operation {Reset FRP} ID: 288ECEB01A2F814A
Elapsed time 00:23 -- Version 4.5.5 Build 001
Page generated in 0.18882 seconds with 8 queries
