Old 09-25-2023, 06:27   #31 (permalink)
Member: 1759100
Thanks Meter: 6
Originally Posted by byteforce2016 View Post
Great updates nowadays by EFT, specially the OneClick bypass iPhones with RAMDISK, but I get my nerves everytime when EFT downloads the same files again and again for bypass. Is it possible to download all those files at once so that it does not download everytime the same files again and again?
Example I have one iPhone X to bypass now and it downloads the needed files, after 5 minutes another iPhone X with the same version and EFT again downloads some files to bypass . This should be easy to be implemented I think
I really think EFT should work on this. Unlocktool has all the files in offline mode and once you've downloaded, it'll automatically do the job without redownloading
Sent from my INE-LX2 using Tapatalk
Old 09-25-2023, 15:17   #32 (permalink)
Member: 2227538
Thanks Meter: 30
iphone 8 pwndfu cpu not supported
Originally Posted by easy-team View Post
EFT Pro Dongle Update V4.5.6 Build 001 is released :
What's New :
[ Samsung ]
Add Translate ADB Android 13 (First in the world)
ar-EG: Arabic (Egypt)
es-ES: Spanish (Spain)
fr-FR: French (France)
it-IT: Italian (Italy)
ko-KR: Korean (South Korea)
ru-RU: Russian (Russia)
tr-TR: Turkish (Turkey)
th-TH: Thai (Thailand)
fa-IR: Persian (Iran
Update Remove KG Lock Direct (MTP)
[ MTK ]
Update Remove MDM INFINIX / TECNO
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
iDevices PWNDFU :.....
Checking Drivers .....Ok
CPU Not Supported
Path:VID_PID:ACPI\PNP0C01\2
Operation {Ipwnder Idevice A7/A8/A9/A10/A11} ID: 0DB24C64C68F85F6
Elapsed time 00:00 -- Version 4.5.6 Build 001
Old 09-25-2023, 16:58   #33 (permalink)
Thanks Meter: 20,608
CPU Not Supported
from one click sir here
https://www.youtube.com/channel/UCR-...B2Zc5lsJxWl7WQ
Old 09-30-2023, 17:16   #34 (permalink)
candelwizzy's Avatar
Member: 853308
Thanks Meter: 60
Post Iphone 8 mdm bypass done
Preparing paths.....OK
Setting up.....OK
Checking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Activated
BuildVersion: 20H19
CPU Arch: arm64
Device Class: iPhone
Device Name: iPhone
Firmware Version: iBoot-8422.142.2
Device IMEI: 356084096840479
Product Name: iPhone OS
Product Type: iPhone 8
IOS Version: 16.7
SIM Status: kCTSIMSupportSIMStatusNotInserted
Device Serial Number: FFQXN4EJJC67
DeviceID: c3889d89a7b67f0b28d532b436033d8d26c70251
MEID Status: Not Supported
Preparing.....OK
Reading Data.....OK
Patching.....OK
Bypassing.....OK
Operation {Bypass MDM} ID: 74A816B1B72E05E6
Elapsed time 00:55 -- Version 4.5.6 Build 001
p, li { white-space: pre-wrap; }
Old 10-04-2023, 15:10   #35 (permalink)
Member: 2810712
Thanks Meter: 2
very nice thanks eft team ♥
Old 10-04-2023, 15:12   #36 (permalink)
Member: 779470
Sonork: Waseem mobile
Thanks Meter: 101
iphone 7 15.7.9 icloud bypass not working
Old 10-04-2023, 16:27   #37 (permalink)
Member: 2810712
Thanks Meter: 2
plz support mdm remove 4 SPD
The Following User Says Thank You to mohammed_har For This Useful Post:
Old 10-04-2023, 17:00   #38 (permalink)
why send me image problem sir please
Old 10-04-2023, 18:22   #39 (permalink)
Member: 779470
Thanks Meter: 101
Arrow iphone 7 15.7.9 icloud bypass not working
Error 9 Not Supported
Page generated in 0.22285 seconds with 9 queries
