Old 11-27-2023, 20:15   #1 (permalink)
Thanks Meter: 21,007
EFT Pro Dongle V4.6.1 is Released New Protocol MTK 2023 And Huawei Kirin & Rockchip
EFT Pro Dongle Update V4.6.1 Build 001 is released :
What's New :
[Apple]
Update Remove Icloud Open Menu BY APPLE ID
Proxy Server: 51.178.81.232
Port: 8887
51.178.81.232:8887
[Rockchip]
Added New Boot By Loader
[MTK]
Added New Protocol MTK 2023
Read Info / Flash (Read + Write) / Format / FRP
Added New Tecno / Infinix/ Itel Preloader MTK
Auth Free MT6761 / MT6765 / MT6768
Read / Write Firmware / Reset FRP / Factory Reset
NOTE: Some Models have been tested and most brands and Models are Supported
MT6761
Infinix Hot 9 Play
Infinix Hot 8
Infinix Hot 12i
Infinix Smart 4
Infinix Smart3 Plus
Tecno Camon 11
Tecno Camon 12 Air
Tecno Camon iACE2
Tecno Camon iACE2X
Tecno Pop 3 Plus
Tecno Pop 5 Pro
Tecno Pop 6 Pro
Tecno Pouvoir 3 Air
Tecno Pouvoir 4
Tecno Spark 3
Tecno Spark 3 Pro
Tecno Spark 4
Tecno Spark 4 Lite
Tecno Spark 5
Tecno Spark 6 Air
Tecno Spark Go
Tecno Spark Go 2023
Tecno Tecno Spark 6 Air
Tecno Spark 8C
Tecno Pop 7 Pro
MT6765
Infinix S5 Pro
Infinix Hot 20 Play
Infinix Hot 30 Play
Infinix Hot 30 Play NFC
Infinix S5 Pro
Tecno Camon 15 Premier
Tecno Camon 15 Pro
Tecno Phantom 9
Tecno Spark 10 4G
Tecno Spark 9
Tecno Spark 9T
MT6768/MT6769
Infinix Hot 10i
Infinix Note 11i
Infinix HOT 12
Infinix Note 10
Infinix Hot 10s
Infinix Note 10
Infinix Note 12i 2022
Infinix HOT 12
Infinix Hot 20
Tecno Camon 20
Tecno Pova Neo 2
Tecno Pova Neo 3
Tecno Spark 8 Pro
Tecno Spark 8P
Tecno Spark 9 Pro
Tecno Camon 18T
Tecno Pova 2
Tecno Camon 17P
Tecno Camon 19
Added New Protocol For MTK (V5)
Read info / Flash (Read + Write) / Format / FRP
Read/Write Firmware / Reset FRP / Factory Reset
[HUAWEI]
Added New support For CHIP KIRIN
Read Info / FRP
KIRIN 620
KIRIN 650
KIRIN 655
KIRIN 685
KIRIN 659
KIRIN 710
KIRIN 710F
KIRIN 910
KIRIN 920
KIRIN 925
KIRIN 930
KIRIN 935
KIRIN 950
KIRIN 955
KIRIN 960
KIRIN 970
KIRIN 980
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 12 Users Say Thank You to easy-team For This Useful Post:
Old 11-27-2023, 20:29   #2 (permalink)
Member: 1161437
Sonork: nokia
Thanks Meter: 50
Good updat
Next updat iphone ipad ios 17.1.1 bypass
Old 11-27-2023, 20:49   #3 (permalink)
Member: 1161437
Sonork: nokia
Thanks Meter: 50
ipad 6th gen ios 17.1.1 bypass problem
Checking iDevices.....OK
Checking SSH......P:16..OK
Waiting for server.....OK
Mounting IPhone/Ipad partition (Hello/Passcode).......OK
BuildIDE068946-7964-11EE-A6E6-0809FA644ADB
ProductBuildVersion:21B91
ProductCopyright:1983-2023 Apple Inc.
ProductName:iPhone OS
ProductVersion:17.1.1
SystemImageID:8195C829-3F3B-47F8-A7DB-83566AC97DE4
Operation {Mount Passcode/Hello IOS 11.x Up 16.x} ID: C98BFC7763E995DD
Elapsed time 00:05 -- Version 4.6.1 Build 001
Path:Backups/aa9434547676ca86dc264310261c477e1d269e26
Wildcard File:OK
Activation Files (Hello Screen).......Upload Failed
Operation {Hello Screen:Activate device iCloud 15.x/16.x} ID: 96E70E35D8313F22
Elapsed time 00:02 -- Version 4.6.1 Build 001
Old 11-27-2023, 20:51   #4 (permalink)
candelwizzy's Avatar
Member: 853308
Thanks Meter: 61
Post Samsung Galaxy A20 FRP done.
Reading device info.....OK
Baseband Version: A205FDDSABUB1,A205FDDSABUB1
Device Arch: exynos7884B
Device bootloader: A205FXXSABUB1
Device selinux: enforcing
Device warranty bit: 0
Device Firmware: A205FXXSABUB1
Android version: 10
Device SDK: 29
Device data encryption: encrypted
Firmware Country: GHANA
Device Hardware: exynos7884B
Device CPU: arm64-v8a
Device Factory: samsung
Device Model: SM-A205F
Device IMEI: 355039102905345
Root status.....Not Rooted
Resetting FRP.....OK
Operation {Remove FRP Direct} ID: 1463A74311E209B0
Elapsed time 01:50 -- Version 4.6.1 Build 001
p, li { white-space: pre-wrap; }
Old 11-27-2023, 21:16   #5 (permalink)
amrMHF's Avatar
Member: 710690
Thanks Meter: 907
very nice update thanks EFT Team ♥
Old 11-28-2023, 06:11   #6 (permalink)
Member: 3022235
Thanks Meter: 31
Thank you very much, nice and wonderful update
Old 11-28-2023, 06:59   #7 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 825
Very good work .
2023 new MTK repair and restore original security also supported??
Old 11-28-2023, 09:30   #8 (permalink)
Member: 2383501
Sonork: 100.1660513
Thanks Meter: 210
Thanks
The Following User Says Thank You to Ahmad-Hzzory For This Useful Post:
Old 11-28-2023, 10:11   #9 (permalink)
Member: 1087145
Thanks Meter: 161
Please Add Samsung A05s Remove KG .
Connecting to device.....OK
Baseband Version: A057FXXU1AWI3,A057FXXU1AWI3
Device bootloader: A057FXXU1AWIE
Device Firmware: A057FXXU1AWIE
Android version: 13
Device SDK: 33
Firmware Country: THAILAND
Device Hardware: qcom
Device Model: SM-A057F
Device IMEI:
Remove KG Lock.....step2......The phone is not supported
Operation {Remove KG Lock Direct} ID: F6042A09CC59AEC4
Elapsed time 00:28 -- Version 4.6.1 Build 001
Old 11-28-2023, 13:00   #10 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
Huawei is broke. Nothing happend when I press start, no fastboot, no com1
Old 11-28-2023, 13:59   #11 (permalink)
Member: 853308
Thanks Meter: 61
Post Iphone 7plus pwndfu boot and passcode backup done
est Signed Drivers is....OFF
Preparing.....OK
Fix Drivers.........OK
Check BOOT.....NO
Reading iDevice info.....OK
Device NAME: iPhone 7 Plus (GSM)
Product NAME: iPhone9,4
Device MODEL: d111ap
Device ECID: 0x11588900d3403a
Device CPID: 8010
Device SRTG: IBOOT-2696.0.0.1.33
Device MODE: DFU
Device CPU: A10
Checking PWNDFU.....OK
Exploiting Device [1]....
Sending File (iBSS.img4).....Failed
Sending File (iBSS.img4).....OK
Sending File (iBEC.img4).....OK
Sending File (bootlogo.img4).....OK
Sending File (devicetree).....OK
Sending File (ramdisk).....OK
Sending File (trustcache).....OK
Sending File (kernel).....OK
Successfully!
Checking SSH......P:16..P:15..P:8..P:14..Failed!
BuildID:81A6A95C-2126-11ED-9931-BEF4C785BB30
ProductBuildVersion:19H12
ProductCopyright:1983-2022 Apple Inc.
ProductVersion:15.7
SystemImageID:A0C47B04-EAE9-4E23-9858-C6B440F24531
Activation Files Backing up .......MAKING IC-Info.sisv...OK
Checking backup files...OK
Path:Backups/11588900d3403a
iCloud':[email protected]
com.apple.accountsd':[email protected]
com.apple.accounts.accountsd':[email protected]
itunesstored':local
com.apple.AuthKit':[email protected]
com.apple.Preferences':[email protected]
SIMPhoneNumber:+233593974073
CopiedSIMPhoneNumber:+233593974073
PNRPhoneNumber:+233593974073
PhoneNumber:233593974073
LastKnownICCID:8923301004369608222
NetworkPhoneNumberICCID:8923301004369608222
NetworkPhoneNumber:+233593974073
Preparing paths.....OK
Erase All Content and Settings ..........OK
Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: A1B807AD1DCA632C
Elapsed time 05:23 -- Version 4.6.1 Build 001
Old 11-28-2023, 17:33   #12 (permalink)
Member: 62545
Thanks Meter: 40
thanks spark 8C HARD RESET OK
Waiting For Device Connection.....OK
USB PORT: SPRD U2S Diag (COM4)
Port: SPRD U2S Diag (COM4)
OPEN COM PORT......OK
Handshake...OK
Writing : FDL1........OK
Boot Block ver:..1.1
Writing : FDL2........OK
The data packet with type(0x96) returned was misformatted
Formatting userdata..........OK
Operation {Factory Reset} ID: 173AEF297461392C
Elapsed time 00:16 -- Version 4.6.1 Build 001
The Following User Says Thank You to y_info2004 For This Useful Post:
Old 11-29-2023, 12:09   #13 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 549
nice update easy team..............
The Following User Says Thank You to Malik Shani G For This Useful Post:
Old 11-30-2023, 19:31   #14 (permalink)
Member: 853308
Thanks Meter: 61
Post Iphone 8 plus pwndfu boot and passcode backup done
Test Signed Drivers is....OFF
Preparing.....OK
Check BOOT.....NO
Device NAME: iPhone 8 Plus (GSM)
Product NAME: iPhone10,5
Device MODEL: d211ap
Device ECID: 0x419c02853002e
Device CPID: 8015
Device SRTG: IBOOT-3332.0.0.1.23
Device MODE: DFU
Device CPU: A11
Sending File (iboot).....Failed
Sending File (iboot).....OK
Sending File (adc).....OK
Successfully!
Checking SSH......P:16..P:15..P:8..OK
BuildID:B9088990-69B6-11EE-9749-2E52F3561178
ProductBuildVersion:20H115
ProductVersion:16.7.2
SystemImageID:EEE91B28-38AD-4851-9CD4-F3B04FCFF3DF
Checking SSH......P:8..OK
Path:Backups/419c02853002e
SIMPhoneNumber:+2335481
PhoneNumber:23354818
LastKnownICCID:8923301004049321972
NetworkPhoneNumberICCID:8923301004049321972
NetworkPhoneNumber:+23354818
imei:352977092380339
Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: 4CA9C93CA8510F52
Elapsed time 02:41 -- Version 4.6.1 Build 001
The Following User Says Thank You to candelwizzy For This Useful Post:
Old 11-30-2023, 20:18   #15 (permalink)
Member: 853308
Thanks Meter: 61
Post Iphone 8 plus pwndfu boot and passcode restore done
Preparing.....OK
Check BOOT.....NO
Device CPID: 8015
Device MODE: DFU
Device CPU: A11
Successfully!
Checking SSH......P:15..P:16..P:8..OK
Activation Files Restoring .......OK
Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: CE8D24E4A36C8CD6
Elapsed time 01:59 -- Version 4.6.1 Build 001
Page generated in 0.31001 seconds with 8 queries
