02-08-2021, 17:23 | #91 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Sudan
Member: 1648903 Status: Offline Thanks Meter: 158 | Fail Searching for Samsung ODIN protocol.....Detected {COM9} Connecting to device.....OK Reading PIT.....OK Flashing [data].....OK Rebooting device.....OK Operation {Reset FRP} ID: DCE9AEF941F8C791 Elapsed time 00:11 -- Version 3.9.1 ---- but still frp on. -------- 250F EFT.png Analyzing file.....OK Searching for Samsung ODIN protocol.....Detected {COM43} Connecting to device.....OK Reading PIT.....OK Flashing [data 1].....OK Rebooting device.....Failed Operation {Reset [ScreenLock - FRP - MDM - Call Me - Samsung Account] -- FRP / OEM: ON} ID: 073807B428C98443 Elapsed time 00:24 -- Version 3.9.1 |
02-11-2021, 09:43 | #93 (permalink) |
Freak Poster Join Date: May 2015 Location: Pakistan
Member: 2401943 Status: Offline Thanks Meter: 182 | Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM38} Switching to Meta Mode.....OK Waiting for Meta port.....Detected {COM38} Connecting to Meta port.....OK Reading info.....OK Device SDK: 25 Android version: 7.1.1 Device CPU: arm64-v8a Device Factory: OPPO Device Model: OPPO A83js Device Factory: OPPO Device Firmware: A83jsEX_11_A.35_200903 Executing Erase command.....OK - Note: if device not entered to recovery and process format automatically then - Boot to recovery manually and perform factory reset Operation {Factory Reset META Recovery} ID: E22EAEE50E45F784 Elapsed time 00:20 -- Version 3.9.1 |
02-11-2021, 10:17 | #95 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Albania -Durres
Member: 154346 Status: Offline Thanks Meter: 37 | Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM3} Switching to Meta Mode.....Failed: ? Operation {Factory Reset META} ID: 318FD319E82B5F8F Elapsed time 00:09 -- Version 3.9.1 |
02-11-2021, 10:44 | #96 (permalink) |
Member: 154346 Status: Offline Thanks Meter: 37 | Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM3} Switching to Meta Mode.....OK Waiting for Meta port.....Detected {COM3} Connecting to Meta port.....OK Reading info.....OK Device SDK: 28 Android version: 9 Device CPU: arm64-v8a Device Factory: OPPO Executing Erase command.....OK - Note: if device not entered to recovery and process format automatically then - Boot to recovery manually and perform factory reset Operation {Factory Reset META Recovery} ID: 862DDDE2D22C19A8 Elapsed time 01:03 -- Version 3.9.1 finally is done |
02-11-2021, 10:44 | #97 (permalink) |
02-13-2021, 15:06 | #98 (permalink) |
Freak Poster Join Date: Jun 2020 Location: Mashhad Age: 31
Member: 2960206 Status: Offline Thanks Meter: 29 | Hey team i couldnt repair Meizu M3 Note L681H phone with MT6755 chipset , mtk port is fine but couldnt switch to Meta Mode ! I tried Alternative switch meta mode and i add secure DA and auth file for this model too but its not working Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM7} Switching to Meta Mode.....Failed: ? Operation {Repair IMEI META} ID: 859AE48837C6A0F4 Elapsed time 00:35 -- Version 3.9.1 |
02-14-2021, 13:29 | #100 (permalink) |
No Life Poster Join Date: Jun 2013 Location: BANGLADESH+UAE Age: 34
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM4} Switching to Meta Mode.....OK Waiting for Meta port.....Detected {COM4} Connecting to Meta port.....Failed: Target/IPC process had no response Operation {Factory Reset META Recovery} ID: CFA2AC316B4DA43D Elapsed time 00:43 -- Version 3.9.1 |
02-22-2021, 18:54 | #103 (permalink) |
Insane Poster Join Date: Aug 2015
Member: 2443309 Status: Offline Thanks Meter: 14 | Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM43} Switching to Meta Mode.....OK Waiting for Meta port.....Detected {COM54} Connecting to Meta port.....Failed: Target/IPC process had no response Operation {Factory Reset META} ID: 452EF99C5A35C52A Elapsed time 00:56 -- Version 3.9.1 oppo f11 |
02-22-2021, 18:54 | #104 (permalink) |
02-23-2021, 12:21 | #105 (permalink) |
Freak Poster Join Date: Feb 2000 Location: Slovakia Age: 53
Member: 965 Status: Offline Thanks Meter: 36 | Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM52} Switching to Meta Mode.....OK Waiting for Meta port.....Detected {COM19} Connecting to Meta port.....OK Reading info.....OK Device SDK: 29 Device data encryption: encrypted Device Hardware: mt6768 Device CPU: arm64-v8a Device Factory: realme Device Factory: realme Device Factory: realme Device Model: RMX2020 Android version: 10 Device Firmware: RMX2020_11_A.16 Executing Erase command.....OK - Note: if device not entered to recovery and process format automatically then - Boot to recovery manually and perform factory reset Operation {Factory Reset META Recovery} ID: E6E87920B93DDD32 Elapsed time 02:34 -- Version 3.9.1 Realme C3 ok |
