06-04-2022, 22:03 | #1 (permalink) |
Registered User Join Date: Apr 2015 Location: Cuba
Member: 2381725 Status: Offline Thanks Meter: 126 | FAIL Boot Passcode iOS 15.x every 2 explois you run disconnects and the cell phone power on to the passcode Preparing.....OK Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 8 (GSM) Product NAME: iPhone10,4 Device ECID: 0x1296e10e8a02e Device CPID: 8015 Device SRTG: IBOOT-3332.0.0.1.23 Device MODE: DFU Device CPU: A11 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (adc.img4).....OK Sending File (rdtrust.img4).....OK Sending File (kernel.img4).....OK Failed! Check Drivers and Re-enter in PWNDFU and Try Again Operation {Boot Passcode IOS 15.x} ID: A15C5BD2C4CAA108 Elapsed time 15:35 -- Version 4.3.3 Last edited by Emsel; 06-04-2022 at 22:12. |
The Following 3 Users Say Thank You to Emsel For This Useful Post: |
07-01-2022, 02:18 | #3 (permalink) |
Junior Member Join Date: Sep 2015 Location: Quintana Roo
Member: 2460513 Status: Offline Thanks Meter: 37 | just press the power button when disconnected from PC Preparing.....OK Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone X (GSM) Product NAME: iPhone10,6 Device ECID: 0x1828323830202e Device CPID: 8015 Device SRTG: IBOOT-3332.0.0.1.23 Device MODE: DFU Device CPU: A11 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (adc.img4).....OK Sending File (rdtrust.img4).....OK Sending File (kernel.img4).....OK Successfully! Operation {Boot Passcode IOS 11.x Up 15.x} ID: 798A2D8E2F00AC00 Elapsed time 01:32 -- Version 4.3.5 |
The Following User Says Thank You to S1errax For This Useful Post: |
07-02-2022, 22:22 | #7 (permalink) |
Major Poster Join Date: Jan 2015 Location: Armenia
Member: 2325301 Status: Offline Thanks Meter: 15 | Preparing.....OK Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 8 Plus (Global) Product NAME: iPhone10,2 Device ECID: 0x1424e604a2efae Device CPID: 8015 Device SRTG: IBOOT-3332.0.0.1.23 Device MODE: DFU Device CPU: A11 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4)..... and dont send files |
07-02-2022, 22:22 | #8 (permalink) |
07-03-2022, 08:12 | #9 (permalink) |
No Life Poster Join Date: May 2004 Location: Peru Age: 54
Member: 67240 Status: Offline Thanks Meter: 45 | same error, all time. What can I do?, how can I solve?, plese help Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (kernel.img4).....OK Failed! Check Drivers and Re-enter in PWNDFU and Try Again Operation {Boot Passcode IOS 11.x Up 15.x} ID: 920E7BA2AE56B7DB Elapsed time 03:27 -- Version 4.3.5 |
07-05-2022, 10:07 | #10 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,230 | Everyone who encounters a problem in making pwnd properly ✅ First, fix the drivers using 3utools PWND Program Link 👇 ****************************/file/ebnbu...YsYnZJ5vHJx410 https://mega.nz/file/y6wAVShR#ENGrbt...aoaLtdwQw8-pPM ………… Burn the PWND with this program https://www.balena.io/etcher/?fbclid...46ifuuSvKCUTQs ……. Explain the method of operation from 7 to X https://*********/G-43ZXXfIRU ………. Explain the method of operation from 6s to 6s+ https://*********/xBb8EY-ulgI …….. For the success of the PWND process for devices 6s/6s Install this Drive https://github.com/daynix/UsbDk/rele...ml6bS15Pw82MFU ……… In the event of a backup and errors occur Update the phone first without wiping data and repeat the process …. In the event that a bot works and an error occurs Failed Re-Enter in PWNDFU and try Again Update the phone first without wiping data and repeat the process |
07-05-2022, 10:08 | #11 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,230 | bypass passcode With Signal IOS 15....x https://www.youtube.com/watch?v=Mqxr...nel=calmsystem |
07-07-2022, 11:34 | #12 (permalink) |
Freak Poster Join Date: Feb 2010 Location: sharjha
Member: 1236922 Status: Offline Sonork: sajer007 Thanks Meter: 101 | Checking iDevices.....Error: Please connect only one iDevice Operation {Backup Passcode IOS 11.x Up 15.x} ID: AAA5DCC43EA9B955 Elapsed time 00:00 -- Version 4.3.5 |
07-11-2022, 18:17 | #14 (permalink) | ||
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | Same error here: Quote:
BR | ||
07-11-2022, 20:49 | #15 (permalink) | |
Member: 1484663 Status: Offline Thanks Meter: 344 | And somehow, I don't know what I did, I didn't do much really. EFT worked like a charm again: Quote:
The Following User Says Thank You to Bscaine For This Useful Post: |
