Old 09-29-2018, 13:20   #1 (permalink)
Member: 2683243
Sonork: not using
Thanks Meter: 48
G610f screen lock problem
Hii team now in my hand samsung g610f with screen lock data is very imp
i am try but where i am wrong plz suggest me
mobile frp is on . mobile runing on 7.0
i am download 6.0.1 firmware and flash sboot from BL tab.
mobile is complately on.
then reset frp emmc method. frp off success.
then i go eft tab and select sm-g610f u1 RD1 7.0.
and flash the phone .but mobile warning reset phone .
i make kernal for screen lock and flash .
after flash mobile not boot proper.
then i flash only system same version.
after flash only system mobile on but not on proper....
now problem is here .
..mobile screen.
to start up yor devices .enter your password .
.and i take mobile pattren lock . i make recovery remove screen lock but same ...
plz help how alive phone again ...
Old 09-29-2018, 23:26   #2 (permalink)
Thanks Meter: 21,930
Now your device firmware is mixed up ,
I suggest you to flash ur device with firmware without user-data and csc ,
So flash full BL and only boot, recovery and system from AP and flash CP,
Then Do the procedure again >>
Flash Sboot 6.0.1 then frp off using FRP EMMC method then make recovery to bypass screen lock.. (Recovery must be taken from firmware you already flashed.)
The Following User Says Thank You to easy-team For This Useful Post:
Old 10-01-2018, 06:23   #3 (permalink)
Member: 2683243
Sonork: not using
Thanks Meter: 48
bro i allredy flash all firmware untic userdata and cache but same problam..
and i allredy frp off with eft using 6.0.1 sboot
any other way bro..
Old 10-01-2018, 06:50   #4 (permalink)
Member: 2683243
Sonork: not using
Thanks Meter: 48
all try but no luck any other solution plz
Old 01-07-2020, 19:21   #5 (permalink)
Member: 1674096
Thanks Meter: 50
same problem here screen lock u1 6.0.1 how to remove it
Old 01-08-2020, 11:53   #6 (permalink)
First check if your device is DD or XX from recovery mode
Upgrade to 8.1.0 then use One click method !
Page generated in 0.14316 seconds with 8 queries
