Old 09-25-2018, 14:14   #1 (permalink)
Member: 1520741
Sonork: zboubdepanda
Thanks Meter: 65
G950n dm verity issue
Hello bra's i have an issue ...
I got a G950N that had firstly a CALL ME problem , i flashed EFS file and everything was okay...
But now the phone is on recovery DM VERITY fail,
when i try to create rooted adb recovery i got a fail extracting file error cauz the recovery file extracting is on RECOVERY.IMG.LZ4 which i renamed to .IMG...
can someone help me to fix dm verity for this device ? G950N U2
thanks
Old 09-25-2018, 14:38   #2 (permalink)
Member: 1665184
Sonork: sainani
Thanks Meter: 162
bro use "LZ4" extractor.....
The Following User Says Thank You to sainani For This Useful Post:
Old 09-25-2018, 14:38   #3 (permalink)
Member: 2500215
Thanks Meter: 267
I think you shouldn't rename the recovery to .img. There is a section to convert to img from that format. I also think you can work on that without converting. Just explore more
The Following User Says Thank You to Southsider2009 For This Useful Post:
Old 09-25-2018, 15:46   #4 (permalink)
Member: 1520741
Thanks Meter: 65
Does Anyone knows which tool can convert LZ4 to img correctly ?
Old 09-25-2018, 18:47   #5 (permalink)
Mohammed Aamri's Avatar
Member: 2536614
Thanks Meter: 2,766
Check this :
BR,
Mohammed Aamri
The Following User Says Thank You to Mohammed Aamri For This Useful Post:
Old 09-25-2018, 19:32   #6 (permalink)
Member: 1520741
Thanks Meter: 65
Thank you ,
i've done it but after flashing the custom recovery i can't access to recovery phone get RECOVERY IMAGE SIGNATURE CHECK FAIL, and reboot and reboot ...
What can i do please
Thank you
hostings pic
Old 09-26-2018, 11:14   #7 (permalink)
Member: 1520741
Thanks Meter: 65
After flashing full firmware, and custom recovery .eft , i still get DM VERITTY VERIFICATION FAILED..;; is there any step to follow ?
Old 09-26-2018, 15:28   #8 (permalink)
Member: 2500215
Thanks Meter: 267
I may be wrong with the step I gave but I think first, you make ADB enabled/rooted recovery from stock recovery.
Then flash. After flash, reboot to recovery mode. Connect to system (in this case, software should be able to detect it in adb mode).
Then try to repair it.
After process. Flash stock firmware again
Page generated in 0.28457 seconds with 7 queries
