Old 11-05-2023, 12:00   #1 (permalink)
Member: 2746053
Thanks Meter: 49
Generate Activation files Failed
hecking iDevices.....OK
Reading iDevice info.....OK
Activation Status: Unactivated
BuildVersion: 19H365
CPU Arch: arm64
Device Class: iPhone
Device Name: iPhone
Firmware Version: iBoot-7459.140.15
Device IMEI: 35xxxxxxxxxxxxxx
Device MEID: 35xxxxxxxxxxxxxxxx
Product Name: iPhone OS
Product Type: iPhone 6s Plus
IOS Version: 15.7.9
SIM Status: kCTSIMSupportSIMStatusNotInserted
Device Serial Number: FCxxxxxxxxxxx
DeviceID: 3a879fce51dabb203c410e4b34ea58384bcc05ba
MEID Status: Supported
Preparing Hello....OK
Generating Activation Files....Failed
Operation {Hello Screen: Generate Activation files ios 15.x/16.x} ID: D6584A180069D6F9
Elapsed time 00:08 -- Version 4.5.9 Build 002
Old 11-05-2023, 13:08   #2 (permalink)
Member: 2746053
Thanks Meter: 49
Hellow Bypass Done With Serial Change Method
CPU Arch: arm64
Device Name: iPhone
IOS Version: 15.7.9
est Signed Drivers is....ON
Preparing.....OK
Fix Drivers.........OK
Check BOOT.....NO
Device NAME: iPhone 6s Plus
Product NAME: iPhone8,2
Device MODEL: n66ap
Device ECID: 0x40e8bb83d68
Device CPID: 8000
Device SRTG: IBOOT-2234.0.0.3.3
Device MODE: DFU
Device CPU: A9
Waiting for server.....OK
Checking PWNDFU.....OK
Exploiting Device [1]....
Sending File (iBSS.img4).....OK
Sending File (iBEC.img4).....OK
Sending File (devicetree).....OK
Sending File (ramdisk).....OK
Sending File (trustcache).....OK
Sending File (kernel).....OK
Successfully!
Checking iDevices.....OK
Checking SSH......P:15..P:16..OK
Mounting IPhone/Ipad partition (Hello/Passcode).......OK
BuildID413ED2C-4AFF-11EE-A8F4-3DF0E6E934E0
ProductBuildVersion:19H365
ProductCopyright:1983-2023 Apple Inc.
ProductName:iPhone OS
ProductVersion:15.7.9
SystemImageID:7165DEDB-DA99-4FF6-9FB6-F615C3BB3C20
Preparing paths.....OK
Checking SSH......P:16..OK
Path:Backups/71b44e84212f8ea1126f0cee2a6623edcc580be7
Wildcard File:OK
Activation Files (Hello Screen).......OK
Disable Reset Settings and Updates....OK
Skip Setup...OK
Operation {Boot Passcode/Hello IOS 11.x Up 16.x One Click} ID: 9D4F9585B4FE1E8C
Elapsed time 02:01 -- Version 4.5.9 Build 002
The Following User Says Thank You to bilalkhan11 For This Useful Post:
Old 12-07-2023, 17:26   #3 (permalink)
Member: 323481
Thanks Meter: 43
How you changed serial number?
Old 12-08-2023, 01:53   #4 (permalink)
Thanks Meter: 22,297
From apple sir .......
Old 12-08-2023, 14:56   #5 (permalink)
Member: 323481
Thanks Meter: 43
iPad Air 2 WiFi Only A1566 IOS 15.8 - Bypass Hello Screen Done With Serial Change Method - EFT Dongle (manual method).
Serial number changed with FREE HFZ SN Writer Purple mode Tool and DCSD Cable (MAC Needed).
https://mega.nz/folder/JBEQSBaK#P-MMA1LGZergdz2-3vec6A
Path:Backups/f90bbf045152216127a07f427e754ec4ff968d77
Wildcard File:OK
Skip Setup...OK
Operation {Hello Screen:Activate device iCloud 15.x/16.x} ID: D8A59EE14C10EC1E
Elapsed time 00:10 -- Version 4.6.1 Build 003
The Following User Says Thank You to kosta25 For This Useful Post:
Page generated in 0.15268 seconds with 8 queries
