Old 12-12-2017, 14:19   #1 (permalink)
OBEDAKHARAT@EFT's Avatar
Member: 2706092
Thanks Meter: 1,556
How to Fix Dongle Not Found Message (All Windows)
Hello ,
Some users are facing Dongle not found message !
This is a driver problem Most of the times and to make it work you need two things .
Step 1- If you are using Windows 8/10 You have to disable Windows Driver Signature Enforcement !
How to do that ?
Look @ the YouTube tutorial
If you are working on Window 7 or earlier, then move to Step 2
http://www.youtube.com/watch?v=71YAIw7_-kg
Step 2- Download and try one of These Drivers:
A-Driver A Mediafire Link
B-Driver B For windows 10 64bit
C-Driver C Universal CardReader Driver and works on all Systems !
If you still face the same problem after doing steps above plz do this :
1- Make sure that smart card is placed correctly ( Not inserted too much)
2- Turn off your Windows Defender or Antivirus Then Install EFT again and Add EFT folder to exclusions on Windows Defender or Anti virus
3- Try to use our smart card with another reader or vice versa
4- Try to use the Dongle on another PC so we can identify where is the problem.
Also check how to update EFT Dongle Smart Card
http://www.youtube.com/watch?v=uypIpe2dwIc
Feel free to contact us any time @ Facebook Official Page
Best Regards
easy Team
The Following 19 Users Say Thank You to OBEDAKHARAT@EFT For This Useful Post:
Old 12-20-2017, 16:12   #2 (permalink)
globaltelecom's Avatar
Member: 358717
Sonork: 100.1648649
Thanks Meter: 44
sir i cant downloed this driver
Old 12-20-2017, 16:32   #3 (permalink)
Member: 358717
Sonork: 100.1648649
Thanks Meter: 44
try to send in miderfire
Old 12-20-2017, 17:47   #4 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
Thanks Meter: 3,944
Hello
SmartCardReader (Blue Reader)
BR,
BEHBOODI
The Following 2 Users Say Thank You to BEHBOODI For This Useful Post:
Old 01-03-2018, 10:40   #5 (permalink)
Member: 2114107
Sonork: 100.1652044
Thanks Meter: 15
same pb weed help
dongle not not found
i change dongle and no succès
reistal driver alsow same
test dongle with auther sim work fine
The Following User Says Thank You to kaibous44 For This Useful Post:
Old 07-05-2018, 10:47   #6 (permalink)
Member: 2652430
Originally Posted by kaibous44 View Post
same pb weed help
Hello did someone found a solution a have same problem, tried drivers posted before and still dongle not found !
Old 07-10-2018, 15:51   #7 (permalink)
Registered User
Member: 1209576
Thanks Meter: 35
i contact your team by PM
for installation driver
Old 08-02-2018, 11:24   #8 (permalink)
Thanks Meter: 21,229
Originally Posted by abdullah142 View Post
eft team have bad support
i tray all steps but dongle not work
dongle not found
team is give you excuse
eft cell cheap dongal that why damaged
Dongle not found has so many reasons , where did you ask for help and we dont respond to you ?
any way contact us here (2) EFT Dongle - Home
The Following User Says Thank You to easy-team For This Useful Post:
Old 08-02-2018, 15:34   #9 (permalink)
Member: 1393230
Thanks Meter: 6
eft dongal
thanks help
i get done
The Following 2 Users Say Thank You to abdullah142 For This Useful Post:
Old 09-24-2018, 12:34   #10 (permalink)
Member: 2846109
Thanks Meter: 2
thanks help
The Following User Says Thank You to ziktamurt For This Useful Post:
Old 09-24-2018, 14:14   #11 (permalink)
thanks help
Make sure is sim is inserted correctly also try on another PC
and stop all antivirus and reinstall software
The Following 2 Users Say Thank You to easy-team For This Useful Post:
Old 10-03-2018, 14:01   #12 (permalink)
Member: 740513
Thanks Meter: 2,544
need driver for eft dongel
it show EMV Smartcard Reader
Old 10-08-2018, 13:42   #13 (permalink)
Member: 345974
Thanks Meter: 23
dongle not found
dongle not found
https://www.4shared.com/s/fUopE2RbMgm
https://www.4shared.com/photo/UopE2RbMgm/Capture.html
Old 10-08-2018, 15:24   #14 (permalink)
Member: 1705075
Thanks Meter: 2
can not open EFT
Old 10-08-2018, 19:02   #15 (permalink)
Member: 2117938
Thanks Meter: 2
my EFT PROGRAM not run after update pleas fix it
Page generated in 0.23359 seconds with 10 queries
