Old 05-29-2018, 03:30   #1 (permalink)
Elgendi's Avatar
Member: 2821459
Thanks Meter: 799
Smile How To Remove FRP G935F S7 Edge Android 8.0
All Ways Not work with Android 8.0
I Install COMBINATION Rom
COMBINATION_FA60_G935FXXU2ARA1 After Enable Developer option and and enable usb debugging and Do Factory data Reset FRP in Download Mode Stay On..
2: Rset FRP UFS With EFT Dongol FRP In Download Mode OFF
3: Flash Rom Android V8.0
And Flash Full Rom .. Congratulations...
COMBINATION Rom Link On Mega
https://mega.nz/#!N9smhIIS!P04AL84Af...bUky0QB_ctJ5Zk
Key:!P04AL84AfO1qpzP3Mmcly-tXaqydEbUky0QB_ctJ5Zk
Oreo Rom : https://androidfilehost.com/?fid=674106145207484646
Firmware Combination For S7 EDGE G930 G935 G935A G935W
COMBINATION_FA60_G930FXXU1API2_CL7964511
https://drive.google.com/uc?id=1Zmrw...xport=download
COMBINATION_FA60_G930FXXU1AQI4_CL7964511
https://drive.google.com/uc?id=1FlCc...xport=download
ـــــــــــــــــــــــــــــــــــــــــــــ ـــــ
COMBINATION_FA60_G930W8VLU2API2_CL7964511
https://drive.google.com/uc?id=1NsfF...xport=download
COMBINATION_FA60_G935AUCU4APL1_CL9617040
https://drive.google.com/uc?id=1VAVR...xport=download
ـــــــــــــــــــــــــــــــــــــــــــــ ـــــ ــــ
COMBINATION_FA60_G935FXXU1AQI2_CL7964511
https://drive.google.com/uc?id=1hqfZ...xport=download
COMBINATION_FA60_G935FXXU2ARA1_CL7964511
https://drive.google.com/uc?id=1yqCv...xport=download
COMBINATION_FA60_G935W8VLU2API2
https://drive.google.com/uc?id=13H_W...xport=download
First U Need to Flash combination rom And do Reset FRP UFS U Will check FRP In Download U Will See It A OFF And Last Flash Rom 8.0 Will Done
The Following 2 Users Say Thank You to Elgendi For This Useful Post:
Old 05-29-2018, 06:57   #2 (permalink)
OBEDAKHARAT@EFT's Avatar
Member: 2706092
Thanks Meter: 1,552
With EFt Dongle Only One Click Without Flash Reset frp ufs via uart cable supported v8
The Following 5 Users Say Thank You to [email protected] For This Useful Post:
Old 06-25-2018, 15:29   #3 (permalink)
Mohsin_josh's Avatar
Member: 78884
Sonork: mohsin111
Thanks Meter: 92
not support atm iam check many time but same issue z3x and octuplus and eft dongel report is sucess but frp lock on
Old 06-25-2018, 17:05   #4 (permalink)
CHEZRACHID's Avatar
Member: 136492
Thanks Meter: 252
agree you brother me too i've tested with no success !
Old 06-25-2018, 19:46   #5 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,132
same not support with oreo 8 , also be careful flash rev2 combination phone make dead , you need replug battary and put in download mode and reflash stock
The Following User Says Thank You to raulka2003 For This Useful Post:
Old 06-26-2018, 00:03   #6 (permalink)
Elgendi's Avatar
Member: 2821459
Thanks Meter: 799
Wink
Yes Brother U Are Right I Tryed Many Time But UFS Working Only with Combnition rom ...
Old 06-26-2018, 05:27   #7 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,132
So easy ways :
1. Flash stock 7.0 rev 2 it’s work tested without combination
2. Flash Eng kernel (boot.img) from Oreo (eng kernel is not from combination )
Old 06-26-2018, 08:25   #8 (permalink)
Elgendi's Avatar
Member: 2821459
Thanks Meter: 799
Cool
So easy ways :
1. Flash stock 7.0 rev 2 itís work tested without combination
Thank U Brother This Post From 29/5/18
And THank For U replayed For Me
Old 07-03-2018, 12:07   #9 (permalink)
Member: 2314755
Thanks Meter: 80
So easy ways :
where did you get eng kernel
Old 07-03-2018, 20:25   #10 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,132
here download it free
The Following 4 Users Say Thank You to raulka2003 For This Useful Post:
Old 07-03-2018, 22:54   #11 (permalink)
Thanks Meter: 18,880
Nice share buddy !
The Following 2 Users Say Thank You to easy-team For This Useful Post:
Old 07-04-2018, 03:00   #12 (permalink)
Elgendi's Avatar
Member: 2821459
Thanks Meter: 799
Smile
Thank U Brother .......
Old 07-06-2018, 18:57   #13 (permalink)
Member: 1853844
Thanks Meter: 8
help
Hello
I have a s7 edge with oreo and 'frp on
you can explain to me the procedure to disable frp.
thank you
Old 07-06-2018, 19:17   #14 (permalink)
Member: 2849041
Thanks Meter: 14
1- Flash V7 after after reset frp by ufs working 100% i tested
Old 07-06-2018, 19:47   #15 (permalink)
Member: 1853844
Thanks Meter: 8
Hello
I tried with odin latest version does not go "fail"
oreo does not allow to return to 7.0
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.20020 seconds with 7 queries
