05-14-2020, 10:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | A307fn root failed (Solved) Decompressing LZ4.....OK Checking output file.....OK File to process [C:/Users/ABULAY~1/AppData/Local/Temp/Rar$EXa6904.30322/recovery.img] Unpacking image.....OK Checking ramdisk status.....OK Patching ramdisk.....OK Patching dm-verity flags.....OK Patching protections.....OK Repacking image.....OK Repacking second image.....OK Rooted image saved to [D:/Z3X BOX/OS 10Q/A307FNXXU2BTD1-(XSG) (Firmware 4 Files) (Android 10 Q)/A307FNXXU2BTD1-(XSG)/RootedBoot.oEFT] Analyzing [D:/Z3X BOX/OS 10Q/A307FNXXU2BTD1-(XSG) (Firmware 4 Files) (Android 10 Q)/A307FNXXU2BTD1-(XSG)/RootedBoot.oEFT].....OK Searching for Samsung ODIN protocol.....Detected {COM23} Connecting to device.....OK Reading PIT.....OK Flashing [data 1].....OK Flashing [data 2]...OK Flashing [data 3]...OK Rebooting device.....OK Operation {Make Rooted boot} ID: D91899BC4C5C99CC Elapsed time 01:04 -- Version 2.4 AFTER ROOT Connecting to device.....OK Reading device info.....OK Baseband Version: A307FNXXU2BTD1,A307FNXXU2BTD1 Serial Number: RZ8MA1ZVFBL Device Arch: exynos7904 Device bootloader: A307FNXXU2BTD1 Device selinux: enforcing Device warranty bit: 1 Device Firmware: A307FNXXU2BTD1 Android version: 10 Device SDK: 29 Device data encryption: encrypted Firmware Country: SOUTH AFRICA Device Hardware: exynos7904 Device CPU: arm64-v8a Device Factory: samsung Device Model: SM-A307FN Device IMEI: 351771113885405 Root status.....Not Rooted Operation {Read Info} ID: 8CA1FD41200C7E92 Elapsed time 00:00 -- Version 2.4 |
05-15-2020, 07:06 | #3 (permalink) | |
Member: 430612 Status: Offline Thanks Meter: 301 | Quote: Connecting to device.....OK Reading device info.....OK Baseband Version: A307FNXXU2BTD1,A307FNXXU2BTD1 Serial Number: RZ8MA1ZVFBL Device Arch: exynos7904 Device bootloader: A307FNXXU2BTD1 Device selinux: enforcing Device warranty bit: 1 Device Firmware: A307FNXXU2BTD1 Android version: 10 Device SDK: 29 Device data encryption: encrypted Firmware Country: SOUTH AFRICA Device Hardware: exynos7904 Device CPU: arm64-v8a Device Factory: samsung Device Model: SM-A307FN Device IMEI: 357721306354036 Root status.....Rooted { 3.19:EFTSU } Rebooting to recovery.....OK Operation {Reboot} ID: 29D4DF89705F73CD Elapsed time 00:00 -- Version 2.4 Chimera Mobile Phone Utility version: 24.78.1447 @ 2020-05-15 Printing phone history Reboot 5/14/2020 1:39:14 PM Repair IMEI 5/14/2020 11:23:34 AM Repair IMEI 5/14/2020 11:14:11 AM Repair IMEI 5/14/2020 10:55:47 AM Repair IMEI 5/14/2020 10:50:58 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Mar 30 15:46:08 KST 2020 PDA Version: A307FNXXU2BTD1 [april 2020, rev1] Phone Version: A307FNXXU2BTD1 [april 2020, rev1] CSC Version: A307FNOJM2BTD1 [april 2020, rev1] Product Code: XFA HIDSw Version: A307FNXXU2BTD1/A307FNOJM2BTD1/A307FNXXU2BTD1/A307FNXXU2BTD1 Board Platform: UNIVERSAL7904 Modem Platform: SHANNON327 Serial Number: RZ8MA1ZVFBL Imei: 357721306354036 Unique Number: CDU00880D53CBA6 Connections: AT,MTP Network Type: GSM SIM Status: LOADED,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-03-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.15.20 08:04:25] WorkID: 95304294 | |
The Following User Says Thank You to luyanda For This Useful Post: |
